There are no ISO profiles that contain it. Where you’re seeing it is commented out. ![]()
Yes, it is. It caused more problems than it solved and is no longer developed.
You should…
You should…
I seem to be able to replicate lacking of version number in the filename on an unstable gnome vm with EUFI. Output of the first time installation of linux69 & installation of linux61after removing the linux61 kernel (with a edited preset without fallback)
sudo mhwd-kernel --install linux69 \ue0b2 \u2714 \ue0b2 8s \uf252
core is up to date
extra is up to date
multilib is up to date
resolving dependencies...
Packages (1) linux69-6.9.0rc7-1
Total Installed Size: 139,49 MiB
:: Proceed with installation? [Y/n] y
(1/1) checking keys in keyring [######################] 100%
(1/1) checking package integrity [######################] 100%
(1/1) loading package files [######################] 100%
(1/1) checking for file conflicts [######################] 100%
(1/1) checking available disk space [######################] 100%
(1/1) installing linux69 [######################] 100%
Optional dependencies for linux69
wireless-regdb: to set the correct wireless channels of your country
[installed]
(1/4) Arming ConditionNeedsUpdate...
(2/4) Updating module dependencies...
(3/4) Updating linux initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux69.preset: 'default'
==> Using default configuration file: '/etc/mkinitcpio.conf'
-> -k /boot/vmlinuz- -g /boot/initramfs-.img
==> Starting build: '6.9.0-rc7-1-MANJARO'
-> Running build hook: [systemd]
-> Running build hook: [kms]
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
-> Running build hook: [sd-vconsole]
-> Running build hook: [fsck]
==> Creating zstd-compressed initcpio image: '/boot/initramfs-.img'
-> Early uncompressed CPIO image generation successful
==> Initcpio image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux69.preset: 'fallback'
-> -k /boot/vmlinuz- -g /boot/initramfs--fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: 'ast'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing '/bin/sh' for script: /usr/bin/fsck.xfs
==> Creating zstd-compressed initcpio image: '/boot/initramfs--fallback.img'
(4/4) Updating Grub-Bootmenu
Found linux image: /boot/vmlinuz-
Found initrd image: /boot/amd-ucode.img /boot/initramfs-.img
Found initrd fallback image: /boot/initramfs--fallback.img
Found linux image: /boot/vmlinuz-6.8-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-6.8-x86_64.img
Found linux image: /boot/vmlinuz-6.1-x86_64
Found initrd image: /boot/amd-ucode.img /boot/initramfs-6.1-x86_64.img
Warning: os-prober will not be executed to detect other bootable partitions.
Systems on them will not be added to the GRUB boot configuration.
Check GRUB_DISABLE_OS_PROBER documentation entry.
done
ls /boot -l
total 181720
-rw-r--r-- 1 root root 81920 4 mei 00:15 amd-ucode.img
drwx------ 3 root root 4096 1 jan 1970 efi
drwxr-xr-x 6 root root 4096 12 mei 19:31 grub
-rw------- 1 root root 11298565 12 mei 19:30 initramfs-6.1-x86_64.img
-rw------- 1 root root 11175172 12 mei 19:30 initramfs-6.8-x86_64.img
-rw------- 1 root root 114389927 12 mei 19:31 initramfs--fallback.img
-rw------- 1 root root 11175195 12 mei 19:31 initramfs-.img
-rw-r--r-- 1 root root 21 3 mei 05:58 linux61-x86_64.kver
-rw-r--r-- 1 root root 20 9 mei 19:01 linux68-x86_64.kver
-rw-r--r-- 1 root root 23 6 mei 04:47 linux69-x86_64.kver
-rw-r--r-- 1 root root 13197824 12 mei 19:30 vmlinuz-
-rw-r--r-- 1 root root 11670016 12 mei 19:25 vmlinuz-6.1-x86_64
-rw-r--r-- 1 root root 13050368 12 mei 19:25 vmlinuz-6.8-x86_64
sudo mhwd-kernel --install linux61
core is up to date
extra is up to date
Packages (1) linux61-6.1.90-1
Total Installed Size: 143,42 MiB
(1/1) installing linux61 [######################] 100%
Optional dependencies for linux61
[installed]
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'default'
==> WARNING: Deprecated option 'ALL_microcode' found. Update '/etc/mkinitcpio.d/linux61.preset' to use the 'microcode' hook instead.
-> -k /boot/vmlinuz-6.1-x86_64 -g /boot/initramfs-6.1-x86_64.img
==> Starting build: '6.1.90-1-MANJARO'
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.1-x86_64.img'
done
ls /boot -l
total 181720
drwxr-xr-x 6 root root 4096 12 mei 19:34 grub
-rw------- 1 root root 11298565 12 mei 19:34 initramfs-6.1-x86_64.img
-rw-r--r-- 1 root root 11670016 12 mei 19:34 vmlinuz-6.1-x86_64
inxi -Fazi \ue0b2 \u2714
Kernel: 6.8.8-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
clocksource: kvm-clock avail: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-6.8-x86_64
root=UUID=29304a65-1f4d-48f7-8b15-f6a6cdfe5187 rw
Desktop: GNOME v: 46.1 tk: GTK v: 3.24.41 wm: gnome-shell
tools: gsd-screensaver-proxy dm: GDM v: 46.0 Distro: Manjaro
base: Arch Linux
Type: Kvm System: QEMU product: Standard PC (Q35 + ICH9, 2009) v: pc-q35-7.2
serial: <superuser required> Chassis: type: 1 v: pc-q35-7.2
Mobo: N/A model: N/A serial: N/A uuid: <superuser required> UEFI: EDK II
v: N/A date: 2/2/2022
Info: model: AMD Ryzen 5 3600 bits: 64 type: SMP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
Topology: cpus: 6x cores: 1 smt: <unsupported> cache:
L1: 6x 128 KiB (768 KiB) desc: d-1x64 KiB; i-1x64 KiB L2: 6x 512 KiB (3 MiB)
desc: 1x512 KiB L3: 6x 16 MiB (96 MiB) desc: 1x16 MiB
Speed (MHz): avg: 3593 min/max: N/A cores: 1: 3593 2: 3593 3: 3593 4: 3593
5: 3593 6: 3593 bogomips: 43139
Flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
Type: spec_rstack_overflow status: Vulnerable: Safe RET, no microcode
Device-1: Red Hat Virtio 1.0 GPU driver: virtio-pci v: N/A ports:
active: Virtual-1 empty: none bus-ID: 00:01.0 chip-ID: 1af4:1050
class-ID: 0300
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.6
compositor: gnome-shell driver: X: loaded: modesetting alternate: fbdev,vesa
dri: virtio_gpu gpu: virtio-pci display-ID: 0
Monitor-1: Virtual-1 model: QEMU Monitor built: 2014 res: 3440x1300
dpi: 109 gamma: 1.2 size: 800x297mm (31.5x11.69") diag: 851mm (33.5") modes:
max: 3440x1300 min: 640x480
API: EGL v: 1.5 platforms: device: 0 egl: 1.4 drv: virtio_gpu device: 1
drv: swrast surfaceless: egl: 1.4 drv: virtio_gpu wayland: egl: 1.4
drv: virtio_gpu x11: egl: 1.4 drv: virtio_gpu inactive: gbm
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.0.6-manjaro1.1
glx-v: 1.4 direct-render: yes renderer: virgl (AMD Radeon RX 6600 (radeonsi
navi23 LLVM 17.0.6 D...) device-ID: 1af4:1010 memory: 7.81 TiB
unified: yes display-ID: :0.0
Device-1: Intel 82801I HD Audio vendor: Red Hat QEMU Virtual Machine
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:293e
class-ID: 0403
API: ALSA v: k6.8.8-2-MANJARO status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
Device-1: Red Hat Virtio 1.0 network driver: virtio-pci v: N/A pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 01:00.0 chip-ID: 1af4:1041
class-ID: 0200
IF-ID-1: enp1s0 state: up speed: -1 duplex: unknown mac: <filter>
Local Storage: total: 50 GiB used: 12.17 GiB (24.3%)
ID-1: /dev/vda maj-min: 254:0 model: N/A size: 50 GiB block-size:
physical: 512 B logical: 512 B speed: <unknown> tech: N/A serial: N/A
scheme: GPT
ID-1: / raw-size: 49.7 GiB size: 48.62 GiB (97.82%) used: 12.17 GiB (25.0%)
fs: ext4 dev: /dev/vda2 maj-min: 254:2
used: 312 KiB (0.1%) fs: vfat dev: /dev/vda1 maj-min: 254:1
Src: lm-sensors+/sys Message: No sensor data found using /sys/class/hwmon
or lm-sensors.
Memory: total: 4 GiB available: 3.81 GiB used: 1.21 GiB (31.8%)
Processes: 251 Power: uptime: 17m states: freeze,mem,disk suspend: s2idle
wakeups: 0 hibernate: shutdown avail: reboot,suspend,test_resume
image: 1.52 GiB services: gsd-power,upowerd Init: systemd v: 255
Packages: pm: pacman pkgs: 896 libs: 260 tools: gnome-software,pamac
Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Zsh v: 5.9
running-in: gnome-terminal inxi: 3.3.34
Version : 39-6
Okay, but it is contained in the repo. I noticed when packages get removed from repo there are appear in pacman -Qm
I remove these packages if I have not installed them myself (AUR).
But I install it on my systems as soon as kernel-alive get removed to don’t mess up things
regarding mkinitcpio … has anyone checked the contents of:
/usr/share/mkinitcpio/hook.preset of the effected vm’s?
Yes.
Just because something is in the repos does not mean you should have it installed. But its your system.
It seems it was not the source of this issue though.
I do find it interesting that most (if not all?) of the reported issues are in VM.
Pacnews may be another thing?
pacdiff -o
@scarwire did you also removed the pacsave files? Cos of this:
+install_preset() {
+ local pkgbase="$1" preset="$2"
+ if [[ ! -e "$preset" ]]; then
+ if [[ -e "$preset.pacsave" ]]; then
+ # move the pacsave to the template
+ mv -- "${preset}.pacsave" "$preset"
+ else
+ # create the preset from the template
+ sed "s|%KERNELBASE%|${kernelbase}|g" /usr/share/mkinitcpio/hook.preset \
+ | install -Dm644 /dev/stdin "$preset"
+ fi
+ fi
@Hanzel please remove the following from your system and call
mkinitcpio -P
again.
/boot/vmlinuz-
Edit: I misread, updating in a sec
$ cd /etc/mkinitcpio.d/
$ ls
linux61.preset linux68.preset linux69.preset
$ sudo rm *.preset
$ ls
$ sudo mkinitcpio -P
==> ERROR: No presets found in /etc/mkinitcpio.d
We are ’ clean’ so now update
Download of linux69 (6.9.0-1) started
Download of manjaro-hello (0.7.2-6) started
Download of manjaro-release (24.0.0-1) started
Download of manjaro-release (24.0.0-1) finished
Download of manjaro-hello (0.7.2-6) finished
Download of linux69 (6.9.0-1) finished
Checking keyring... [3/3]
Checking integrity... [3/3]
Loading packages files... [3/3]
Checking file conflicts... [3/3]
Checking available disk space... [3/3]
Running pre-transaction hooks...
Removing linux initcpios... [1/1]
Upgrading linux69 (6.9.0rc7-1 -> 6.9.0-1)... [1/3]
Upgrading manjaro-hello (0.7.2-5 -> 0.7.2-6)... [2/3]
Upgrading manjaro-release (23.1.4-1 -> 24.0.0-1)... [3/3]
Arming ConditionNeedsUpdate... [1/5]
Updating module dependencies... [2/5]
Updating linux initcpios... [3/5]
==> Starting build: '6.9.0-1-MANJARO'
Updating Grub-Bootmenu [4/5]
done
Updating the desktop file MIME type cache... [5/5]
A restart is required for the changes to take effect.
$ ls
linux69.preset
$ sudo mhwd-kernel --install linux61
core is up to date
extra is up to date
warning: linux61-6.1.90-1 is up to date -- reinstalling
Net Upgrade Size: 0,00 MiB
(1/1) reinstalling linux61 [######################] 100%
==> Building image from preset: /etc/mkinitcpio.d/linux61.preset: 'fallback'
done
$ sudo mhwd-kernel --install linux68
core is up to date
extra is up to date
warning: linux68-6.8.9-3 is up to date -- reinstalling
Packages (1) linux68-6.8.9-3
Total Installed Size: 138,74 MiB
(1/1) reinstalling linux68 [######################] 100%
==> Building image from preset: /etc/mkinitcpio.d/linux68.preset: 'default'
==> Starting build: '6.8.9-3-MANJARO'
==> Building image from preset: /etc/mkinitcpio.d/linux68.preset: 'fallback'
done
$ ls /boot -l
total 181148
drwxr-xr-x 6 root root 4096 13 mei 20:00 grub
-rw------- 1 root root 113949480 13 mei 20:00 initramfs--fallback.img
-rw------- 1 root root 11175101 13 mei 20:00 initramfs-.img
-rw-r--r-- 1 root root 20 13 mei 07:30 linux69-x86_64.kver
-rw-r--r-- 1 root root 13050368 13 mei 20:00 vmlinuz-
To make sure I’m up to date/right brach:
$ pamac upgrade
Preparing...
Nothing to do.
$ pacman-mirrors -G
unstable
Edit:
$ cd /boot
$ ls -l
total 181148
drwxr-xr-x 6 root root 4096 13 mei 20:10 grub
$ sudo rm vmlinuz-
$ sudo rm initramfs-.img
$ sudo rm initramfs--fallback.img
==> ERROR: specified kernel image does not exist: '/boot/vmlinuz-'
I can trigger the issue again by installing linux69 as well
Upgrading Kernels is fine ![]()
Installing Kernels is not ![]()
I have to edit the preset manually.
my /etc/mkinitcpio.d/ is empty and happen same as @pheiduck.
Let me correct my information: I didn’t try to reinstall the other kernels. It happens when I install linux69.
okay used manjaro system settings to install kernel 6.9.0-1 … before rebooting I checked the /etc/mkinitcpio.d/linux69.preset file … no kernel version info present … checked boot also no kernel versioning info… for most recently installed kernel 6.9 … in file names …
/usr/share/mkinitcpio/hook.preset file was normal …
I made the appropriate edits to file names in /boot and modified linux69.preset … and kernel 6.9 does boot, after mkinitcpio -P and update-grub…
mkinitcpio is verion 39-6
okay as 39.1-1 is coming – rebooted into linux6.8 and removed linux6.9 install
will test new version as soon as it appears on mirrors… also moved linux69.preset.pacsave out of /etc/mkinitcpio.d/
okay installed mkinitcpio version 39.1-1 reinstalled linux6.9 via manjaro settings manager … same as before … linux69.preset contains no version info will remove again and try mkhw-kernel to install as well
ok did a mkhw-kernel install (cleaned out linux69.preset.pacsave first) same as before no kernel versioning… uninstalled … cleaned out linux69.preset.pacsave … replaced with an edited kernel-versioned edition… of linux69.preset (derived from linux68.preset) …
did the: sudo mkhw-kernel -i linux69 and everything works … so the problem is due to incorrect generation of linux69.preset … I suspect any attempt to install “any new” kernels will fail in the same way!
... mkinitcpio version 39.1-1 does not fix the issue ...
@pheiduck @servimo I just pushed mkinitcpio 39.1-1.
I’m wondering if the issue is now fixed upstream:
lsinitcpio: show out-of-tree modules (from the extramodules directory)
in module list. This was accidentally lost in mkinitcpio v33
– v39.1 · Arch Linux / Mkinitcpio / mkinitcpio · GitLab
Mind you, I can’t reproduce the issue on two machines, so I’m flying blind here.
EDIT: I can now reproduce it on both systems after installing linux69.
Oh… interesting so it was an upstream bug and not by Manjaro. Will check new version of mkinitcpio tomorrow and give feedback.
@Yochanan I think systems with legacy bios mode make something different? Haven’t checked on UEFI mode.
I have this issue since adding 6.9 kernel today. The issue still exists with mkinitcpio 39.1-1
==> Building image from preset: /etc/mkinitcpio.d/linux66.preset: 'default'
-> -k /boot/vmlinuz-6.6-x86_64 -g /boot/initramfs-6.6-x86_64.img
==> Starting build: '6.6.30-2-MANJARO'
-> Running build hook: [microcode]
==> Decompressing zstd-compressed firmware files
-> Fixing firmware file symlinks
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.6-x86_64.img'
-> -k /boot/vmlinuz-6.8-x86_64 -g /boot/initramfs-6.8-x86_64.img
==> Creating zstd-compressed initcpio image: '/boot/initramfs-6.8-x86_64.img'
amd-ucode.img
efi
grub
initramfs-.img
linux66-x86_64.kver
linux68-x86_64.kver
linux69-x86_64.kver
memtest86+
vmlinuz-
vmlinuz-6.6-x86_64
vmlinuz-6.8-x86_64
Version : 39.1-1
xfce Unstable, not a VM. I don’t have fallback.img (my choice)
I didn’t say that. I was only wondering if what I quoted from the changelog would help.
I can’t even boot into linux69 after installing it. My AMD laptop:
amd-ucode.img
efi
grub
initramfs-6.1-x86_64-fallback.img
initramfs-6.6-x86_64-fallback.img
initramfs-6.8-x86_64-fallback.img
initramfs-.img
linux61-x86_64.kver
linux66-x86_64.kver
linux68-x86_64.kver
linux69-x86_64.kver
memdisk
memtest86+
vmlinuz-
vmlinuz-6.1-x86_64
vmlinuz-6.6-x86_64
vmlinuz-6.8-x86_64
# mkinitcpio preset file for the '' package
#ALL_config="/etc/mkinitcpio.conf"
ALL_kver="/boot/vmlinuz-"
PRESETS=('default' 'fallback')
#default_config="/etc/mkinitcpio.conf"
default_image="/boot/initramfs-.img"
#default_uki="/efi/EFI/Linux/manjaro-.efi"
#default_options="--splash /usr/share/systemd/bootctl/splash-manjaro.bmp"
#fallback_config="/etc/mkinitcpio.conf"
fallback_image="/boot/initramfs--fallback.img"
#fallback_uki="/efi/EFI/Linux/manjaro--fallback.efi"
fallback_options="-S autodetect"
I’m at a loss here. I’ve pinged @philm, so when he’s available hopefully he will be able to find the issue.
Well OK then here I go for the plunge. ![]()
Or … not. I can see it did the thing already.
(5/5) Updating linux initcpios...
==> Using drop-in configuration file: 'mine.conf'
==> Creating lzop-compressed initcpio image: '/boot/initramfs-.img'
==> Creating lzop-compressed initcpio image: '/boot/initramfs--fallback.img'
installing mkinitpcio 39.1-2 fixes the issue … thank you !
Will check afternoon!
Yes, now it works good! ![]()
No, since Arch doesn’t even add any versions to initramfses or kernels.
All is fine now with mkinitcpio only the grub menu seams incorrect (on unstable)
