mbod
2 September 2020 09:42
1
I try to create a btrfs filesystem on a luks partition and it fails. Everything is properly setup and mkfs.xfs
or mkfs.ext4
work fine with the luks partition but not so mkfs.btrfs
13# mkfs.btrfs -f /dev/mapper/lukswd1
btrfs-progs v5.7
See http://btrfs.wiki.kernel.org for more information.
ERROR: cannot check mount status of /dev/mapper/lukswd1: Not a directory
This is on Manjaro testing with btrfs-progs v5.7
and kernel 5.8. Any idea what is going wrong here?
thht
2 September 2020 10:07
2
hi,
can you please post the output of ls /dev/mapper
, please?
and btw. do you run this command as root or using sudo
mbod
2 September 2020 10:16
3
This was the right question to ask!
19# ll /dev/mapper
insgesamt 0
crw------- 1 root root 10, 236 2. Sep 12:09 control
lrwxrwxrwx 1 root root 7 2. Sep 12:10 lukswd1 -> ../dm-0
lrwxrwxrwx 1 root root 7 2. Sep 12:10 lukswd2 -> ../dm-1
So /dev/mapper/lukswd1
is actually a link to /dev/dm-0
When I use /dev/dm-0
mkfs.btrfs has no problem:
10# mkfs.btrfs -f /dev/dm-0
btrfs-progs v5.7
Label: (null)
UUID: 6102f3bc-6094-4c5b-b585-40af501db349
Node size: 16384
Sector size: 4096
Filesystem size: 3.64TiB
Block group profiles:
Data: single 8.00MiB
Metadata: DUP 1.00GiB
System: DUP 8.00MiB
SSD detected: no
Incompat features: extref, skinny-metadata
Runtime features:
Checksum: crc32c
Number of devices: 1
Devices:
ID SIZE PATH
1 3.64TiB /dev/dm-0
Thank you. Problem solved.
How did you create the Luks device?
mbod
2 September 2020 10:41
5
I am using a keyfile instead of a password:
cryptsetup luksFormat /dev/sdg1 --key-file=my-key-file
cryptsetup open /dev/sdg1 --key-file=my-key-file lukswd1
system
Closed
5 September 2020 10:41
6
