Missing title bars on Compiz Reloaded with Xfce
I’m trying to run Compiz Reloaded and my Xce window title bars aren’t showing.
Even though I’ve installed Emerald, when clicking fusion-icon in the systray, Emerald is not listed as an option for widow decorator.
I also tried a few things like:
$ compiz --replace ccp
$ compiz --replace ccp & emerald --replace &
$ emerald --replace
Emerald still doesn’t start.
How do I get my window borders back?
I haven’t got compiz installed anymore, but I think you set the decorator in the settings??? Let me install back in a minute.
This is compiz-manjaro, not reloaded, but should be the same.
Here is an image of my CompizConfig Settings Manager:
As you can see, in this image it appears gtk window decorator applies to more than one window, including GIMP and Discord, but for some reason I still can’t click their title bars and drag any of these windows. It’s like they are permanently stuck on their position.
I even tried replacing gtk-window-decorator with emerald and nothing seemed to change.
What would any of you recommend I try next?
emerald --replace ??
Sorry out of ideas, if you use the gtk decorator and select a theme with compiz-gtk-decorator-theme-selector does that work?
Hi Xircon!
I was hanging out in #compiz-reloaded on FreeNode and soreau pointed out that the “Move” plugin needs to be toggled in comiz settings manager. That fixed it. :wink:
Glad you got it sorted :smiley: Will mark it solved.
