Hi everybody,
I’m completely new to Manjaro (and basically new to Linux itself). A friend of mine installed yesterday Manjaro on my laptop (previously I had windows 10) and today I had 3 random freezes by doing basic stuff like being connected over NordVPN, watching netflix and reading some pdfs,
inxi -fazy:
Info: Dual Core model: AMD Ryzen 3 2200U with Radeon Vega Mobile Gfx
bits: 64 type: MT MCP arch: Zen family: 17 (23) model-id: 11 (17)
stepping: 0 microcode: 8101007 cache: L1: 192 KiB L2: 1024 KiB L3: 4 MiB
bogomips: 19971
Speed: 1931 MHz min/max: 1600/2500 MHz boost: disabled Core speeds (MHz):
1: 2195 2: 1568 3: 1251 4: 1510
disabled, RSB filling
Hello,
syphracos:
inxi -fazy
is different than
inxi -Fazy
Provide that instead.
Hi,
thanks for the hint!
Kernel: 5.13.19-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=70e18c21-fe7a-4a2f-8ba8-8265a2427fc7 rw quiet apparmor=1
security=apparmor resume=UUID=261b295c-0f77-4c3f-a590-374b14c12beb
udev.log_priority=3
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: HP product: HP Laptop 15-db0xxx v: Type1ProductConfigId
Mobo: HP model: 84AE v: 86.19 serial: <superuser required> UEFI: Insyde
v: F.03 date: 04/26/2018
ID-1: BAT1 charge: 11.7 Wh (51.8%) condition: 22.6/41.0 Wh (55.1%)
volts: 10.5 min: 11.4 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: Discharging
flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
bogomips: 19970
Speed: 1417 MHz min/max: 1600/2500 MHz boost: enabled Core speeds (MHz):
1: 2226 2: 2176 3: 1679 4: 1785
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Vega Mobile Series]
vendor: Hewlett-Packard driver: amdgpu v: kernel bus-ID: 04:00.0
chip-ID: 1002:15dd class-ID: 0300
Device-2: Lite-On HP Webcam type: USB driver: uvcvideo bus-ID: 3-2.1:4
chip-ID: 04ca:707d class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.1 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6")
diag: 394mm (15.5")
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.1 chip-ID: 1002:15de
class-ID: 0403
Device-2: AMD Raven/Raven2/FireFlight/Renoir Audio Processor
vendor: Hewlett-Packard driver: snd_pci_acp3x v: kernel
alternate: snd_rn_pci_acp3x bus-ID: 04:00.5 chip-ID: 1022:15e2
class-ID: 0480
Device-3: AMD Family 17h HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 04:00.6 chip-ID: 1022:15e3
class-ID: 0403
Sound Server-1: ALSA v: k5.13.19-2-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.40 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 02:00.0
Device-2: Realtek RTL8821CE 802.11ac PCIe Wireless Network Adapter
vendor: Hewlett-Packard driver: rtw_8821ce v: N/A modules: rtw88_8821ce
port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:c821 class-ID: 0280
Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb
v: 0.8 bus-ID: 3-2.3:5 chip-ID: 0bda:b00a class-ID: e001 serial: <filter>
Local Storage: total: 1.03 TiB used: 27.93 GiB (2.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
type: HDD rpm: 5400 serial: <filter> rev: RSM7 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SD9SN8W-128G-1006
size: 119.24 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 3006 scheme: GPT
ID-1: / raw-size: 110.15 GiB size: 107.86 GiB (97.92%)
used: 27.93 GiB (25.9%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18
used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
dev: /dev/sdb3 maj-min: 8:19
System Temperatures: cpu: 48.6 C mobo: 20.0 C gpu: amdgpu temp: 48.0 C
Processes: 248 Uptime: 1m wakeups: 1 Memory: 7.43 GiB used: 1.67 GiB (22.4%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0
Packages: 1282 pacman: 1274 lib: 341 flatpak: 0 snap: 8 Shell: Zsh v: 5.8
default: Bash v: 5.1.12 running-in: konsole inxi: 3.3.09
