Missing PGP Keys into Discord installation
#1
I’m trying to install discord. But seems some pgp keys are missing:
==> Validando source arquivos com sha512sums…
llvm-7.0.0.src.tar.xz … Passou
llvm-7.0.0.src.tar.xz.sig … Ignorada
libcxx-7.0.0.src.tar.xz … Passou
libcxx-7.0.0.src.tar.xz.sig … Ignorada
libcxxabi-7.0.0.src.tar.xz … Passou
libcxxabi-7.0.0.src.tar.xz.sig … Ignorada
==> Verificando assinatura de arquivo fonte com gpg…
llvm-7.0.0.src.tar.xz … FALHOU (chave pública desconhecida 0FC3042E345AD05D)
libcxx-7.0.0.src.tar.xz … FALHOU (chave pública desconhecida 0FC3042E345AD05D)
libcxxabi-7.0.0.src.tar.xz … FALHOU (chave pública desconhecida 0FC3042E345AD05D)
==> ERRO: Uma ou mais assinaturas PGP não puderam ser verificadas!
==> ERRO: Makepkg não conseguiu compilar libc++.
I did a:
sudo pacman-key --refresh-keys --keyserver pgp.mit.edu
Got the new keys but:
llvm-7.0.0.src.tar.xz, libcxx-7.0.0.src.tar.xz and libcxxabi-7.0.0.src.tar.xz.
Are still unsigned, what am I missing?
#2
Did you try gpg --recv-keys 0FC3042E345AD05D in a Terminal window?
#3
Yes this was my first attempt.
 history | tail -n20
  266  pacman -Syu
  267  pacdiff
  268  pacman-key --init
  269  gpg --recv-key 0FC3042E345AD05D
  270  gpg --recv-key 0FC3042E345AD05D
  271  gpg --recv-key 0FC3042E345AD05D
  272  yaourt -Ss discord
  273  yaourt -Ss discord
#4
Try this in a Terminal window:
gpg --keyserver pgp.mit.edu --recv-keys A2C794A986419D8A
Also, a tutorial that may help you install Discord can be found here:
#5
Or use the flatpak version
#6
#7
@jonathon I did receive those keys with no success on the final output.
#8
Like me, sincerely.
#9
Please do not create “me too!” posts. These add nothing to the forum: https://wiki.manjaro.org/index.php?title=Forum_Rules#No_Power-Posting.2FEmpty_Posts
If you have further information, or want help, please post that instead.
