I have problem searching packages in pamac and yay
I was looking for team viewer15 … but no matter how i enter the search keyword, the result just none.
These yield no result.
$ yay -Ss teamviewer15
$ yay -Ss teamviewer 15
$ yay -Ss ‘teamviewer 15’
However, when i do grep, the result comes out:
$ yay -Ss teamviewer | grep 'teamviewer 15'
aur/teamviewer 15.19.3-1 (+1423 5.39)
But there is no way for me to sync the package to my pc, because $ yay -Ss teamviewer 15 does not work.
When i use pamac to the search for the same package above,
teamviewer15
teamviewer 15
‘teamviewer 15’
Pamac just return “no package found”.
There are so many teamviewer version… i have to dig thru … There is no way easier ? *just asking, if there is, i rather use the easier method, because sometime the search result can be perplexing… especially with all the cli file name…
How do i use yay to download the teamviewer version 15 then ? can you write to me ? Thanks
If i just type “teamviewer” there are teamviewer 10 all the way up to 15… which will it download ?
Is there no one command to download ?
I think if i just type $yay -S teamviewer without version number, it will still prompts me to enter the number of choice… which is no good…
It will ask me to enter number of choice… Is there no 1 commandline and get it down with thingy ?
And when i use pamac… i have to scroll thru the whole list… some package is not direct related to teamviewer is among the list… i have to scroll thru them all… that’s not efficient…
Not in this case, no. The teamviewer package is the latest version ─ version 15 ─ but yay will list all packages with a matching name, which includes all the other versions from version 8 to 14.
$ yay -Sq teamviewer
:: There are 8 providers available for teamviewer:
:: Repository AUR
1) teamviewer 2) teamviewer-beta 3) teamviewer-preview 4) teamviewer11 5) teamviewer12 6) teamviewer14 7) teamviewer8 8) teamviewer9
Enter a number (default=1): ```
Not difficult. I just thought linux is all about command line to get it done… for example, if i need to help someone to install teamviewer, i just issue him/her with that 1 cli and it is done…
I don’t have to tell him/her to wait until yay ask you to choose the 1 number to enter…
Isn’t that defeat the purpose ?
Don’t understand the explaination of this pamac build… what is the different between use pamac gui to select and build / install… or what is the different between yay -S package ?
$ pamac build --help
Build packages from AUR and install them with their dependencies
If no package name is given, use the PKGBUILD file in the current directory
The build directory will be the parent directory, --builddir option will be ignored
and --no-clone option will be enforced
pamac build [options] [package(s)]
options:
--builddir <dir> : build directory, if no directory is given the one specified in pamac.conf file is used
--keep, -k : keep built packages in cache after installation
--no-keep : do not keep built packages in cache after installation
--dry-run, -d : only print what would be done but do not run the transaction
--no-clone : do not clone build files from AUR, only use local files
--no-confirm : bypass any and all confirmation messages
Is pamac build package the same as using pamac gui to “install” a package ?
Some software in pamac gui shows “install” instead of “build”… What is the difference ?
