For mounting an webdav-drive I have to install davfs2.([root tip] [How To] systemd mount unit samples) But I don’t see davfs2 in PAMAC and can’t install it with $ sudo pacman -S davfs2.
Any help will be appreciated!
For example with gio mount that uses fuse. It is basically what a file-manager would use. Probably not better, just completely different. Since I’m not using KDE, I don’t know the name for the gio counterpart in KDE. But a gio (fuse) mount can be start with a systemd service (doesn’t need to be a user service).
However there is nothing wrong with using the AUR. Just understand the pros and cons.
