Hello everyone
I had installed manjaro October and it was running perfectly fine.
Now i have upgraded from Manjaro Pahvo to Manjaro Qonos and im having issues(multiple settings missing).
How can I downgrade my manjaro version?
Thanks
Hello everyone
Thanks
i don’t think you can downgrade your system to a previous version once updated. you might want to grab a new image for manjaro pahvo in your case and do a fresh install and never update. Downloading File /xfce - Manjaro ISO Archive - OSDN
You can’t. Manjaro is a rolling release Distro.
https://wiki.manjaro.org/index.php/The_Rolling_Release_Development_Model
What issues? It would be better to fix things rather than trying to downgrade.
Since i updated from Pahvo to Qonos, I am missing a lot of settings such as appearance settings, keyboard shortcuts, display settings etc
Do you mean that your settings have been removed? Or that you don’t have the new settings?
Geeze in which desktop environment? See the post above mine.
Sorry i was frustrated
So im using Manjaro xfce latest version
im on HP Pavillion 14 with nvidia drivers(GeForce 940mx)
Usually when i right click on my desktop, theres a menu and in that menu there are my display, appearance customization etc…
now when i right click, i can no longer see them.
Also, i cannot see where i can change my keyboard shortcuts. i cannot find those settings.
some of my settings are here, some are not.
may i know what new settings are there?
So missing Menu entries to configuration settings, rather than missing settings.
This is not necessarily abnormal:
It seems you indeed lack the usual Xfce settings entries. Do you have xfce4-settings installed?
yes i do have xfce4-settings installed.
i have found the required settings(appearance, display, etc…), it was in my whisker menu. However i still dont understand why it doesnt show up when i right click
AFAIK the desktop menu and Whisker use the same entries, weird indeed…
I’ll put this documentation, maybe something will inspire you.
https://wiki.archlinux.org/title/Xfce#Menu
okayy i will try that…
if it doesnt work, i might do a reinstallation
