Hello there! Recently I have bought a new laptop (ZenBook UX325UA_UM325UA) and installed my favorite manjaro distro :). And I have a separate monitor connected to this laptop. Here is the output of the xrandr --query
command:
Summary
Screen 0: minimum 320 x 200, current 5760 x 2160, maximum 16384 x 16384
HDMI-A-0 connected 3840x2160+1920+0 (normal left inverted right x axis y axis) 697mm x 392mm
3840x2160 60.00*+ 50.00 59.94 30.00 25.00 24.00 29.97 23.98
2560x1440 59.95
1920x1200 60.00
1920x1080 60.00 50.00 59.94 30.00 24.00 29.97 23.98
1600x1200 60.00
1680x1050 59.88
1600x900 60.00
1280x1024 75.02 60.02
1440x900 59.90
1280x800 59.91
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 75.03 70.07 60.00
832x624 74.55
800x600 72.19 75.00 60.32 56.25
720x576 50.00
720x480 60.00 59.94
640x480 75.00 72.81 66.67 60.00 59.94
720x400 70.08
eDP connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 294mm x 165mm
1920x1080 60.00*+
1680x1050 60.00
1280x1024 60.00
1440x900 60.00
1280x800 60.00
1280x720 60.00
1024x768 60.00
800x600 60.00
640x480 60.00
DisplayPort-0 disconnected (normal left inverted right x axis y axis)
DisplayPort-1 disconnected (normal left inverted right x axis y axis)
Now, I found out how to configure gamma for the specific monitor like this:
xrandr --current --output eDP --gamma 1.01:0.95:1.10
These are the settings I would love to apply but persistently, for example when I’m on the ssdm’s login screen, after logging into the system, back after hibernation etc. And to do so I tried many things, I went into the different config files like .xinitrc, .bashrc, /usr/share/sddm/scripts/Xsetup (and other its scripts), /etc/sddm.conf.d and more. I even tried to create such config file in the /etc/X11/xorg.conf.d directory:
Section "Monitor"
Identifier "eDP"
Gamma "1.01 0.95 1.10"
EndSection
But for some reason after applying this config the system does not boot. Perhaps it might be connected with the driver I’m using? Here are some details if needed:
System: Host: b0ysetsf1re-zenbookux325uaum325ua Kernel: 5.13.1-3-MANJARO x86_64 bits: 64 Desktop: KDE Plasma 5.22.3
Distro: Manjaro Linux
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Lucienne driver: amdgpu v: kernel
Device-2: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo
Display: x11 server: X.Org 1.20.11 driver: loaded: amdgpu,ati unloaded: modesetting resolution: 1: 3840x2160~60Hz
2: 1920x1080~60Hz
OpenGL: renderer: AMD RENOIR (DRM 3.41.0 5.13.1-3-MANJARO LLVM 12.0.0) v: 4.6 Mesa 21.1.4
I don’t know what else to try and I need some help. Perhaps there is a better way to calibrate display than tweaking gamma settings? I know there are some ICC profiles and different software (like displaycal), which requires colorimeter, but I am not a photographer so I don’t need it, just to make some simple adjustments to the display and that’s it. I would be very grateful for any help. Let me know if any additional details needed.
Thanks!
