Missing ethernet Qualcomm E2400 driver / slow download and upload
Hello,
I’ve been using Manjaro for a while now but the system always felt slugish when connecting trough google remote desktop.
I now pinpointed the problem to a missing ethernet driver, but I can’t seem to connect the dots how to install the driver:
inxi --admin --verbosity=7 --filter --width
  Kernel: 6.5.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.5-x86_64
    root=UUID=29649f05-10b5-4df2-9d3a-46c207e3f665 rw quiet splash apparmor=1
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
    v: 4.18.0 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
  Type: Desktop Mobo: MSI model: Z170A GAMING M7 (MS-7976) v: 1.0
    serial: <superuser required> UEFI: American Megatrends v: 1.F0
    date: 09/26/2016
  System RAM: total: 32 GiB available: 31.24 GiB used: 12.11 GiB (38.8%)
  Info: model: Intel Core i7-6700 bits: 64 type: MT MCP arch: Skylake-S
    gen: core 6 level: v3 note: check built: 2015 process: Intel 14nm family: 6
    model-id: 0x5E (94) stepping: 3 microcode: 0xF0
    L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 800 min/max: 800/4000 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 bogomips: 54417
    dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
    intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
    movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
    pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
    rep_good sdbg sep smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
  Type: gather_data_sampling status: Vulnerable: No microcode
    vulnerable
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: conditional,
    RSB filling, PBRSB-eIBRS: Not affected
  Device-1: Intel HD Graphics 530 vendor: Micro-Star MSI driver: i915 v: kernel
    arch: Gen-9 process: Intel 14n built: 2015-16 ports: active: none empty: DP-1,
    HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:1912
    class-ID: 0300
  Display: x11 server: X.Org v: 21.1.8 compositor: xfwm v: 4.18.0 driver: X:
    loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915
    display-ID: :20.0 screens: 1
  Screen-1: 0 s-res: 2048x1018 s-dpi: 96 s-size: 541x269mm (21.30x10.59")
    s-diag: 604mm (23.79")
  Monitor-1: DUMMY0 res: 2048x1018 hz: 60 size: N/A modes: N/A
    device: 1 drv: swrast surfaceless: drv: iris x11: drv: swrast
    inactive: gbm,wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 23.1.9-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: llvmpipe (LLVM 16.0.6 256 bits)
    device-ID: ffffffff:ffffffff memory: 30.5 GiB unified: yes
  Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170
    class-ID: 0403
  API: ALSA v: k6.5.3-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 0.3.81 status: active (process) tools: pw-cli
  Server-3: PulseAudio v: 16.1 status: off with: pulseaudio-alsa type: plugin
    tools: pacat,pactl,pavucontrol
  Device-1: Qualcomm Atheros Killer E2400 Gigabit Ethernet
    vendor: Micro-Star MSI driver: alx v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: e000 bus-ID: 02:00.0 chip-ID: 1969:e0a1 class-ID: 0200
  IF: enp2s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: br-0bfc52e7b7d8 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IP v6: <filter> virtual: proto kernel_ll scope: link
  IF-ID-2: br-0eecd4510b18 state: up speed: 10000 Mbps duplex: unknown
    mac: <filter>
  IF-ID-3: docker0 state: down mac: <filter>
  IF-ID-4: veth024e77b state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-5: veth2804395 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-6: veth3f0b2e8 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-7: veth4e4ff0f state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-8: veth620fea7 state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-9: veth95500cc state: up speed: 10000 Mbps duplex: full mac: <filter>
  IF-ID-10: vetha8a5b5c state: up speed: 10000 Mbps duplex: full
    mac: <filter>
  Local Storage: total: 3.76 TiB used: 824.08 GiB (21.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EZEX-08WN4A0
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 1A02 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 840 PRO Series
    size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 6B0Q scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD10EZRX-00L4HB0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
    fw-rev: 1A01 scheme: GPT
  ID-4: /dev/sdd maj-min: 8:48 vendor: Seagate model: ST2000DM008-2FR102
    tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: GPT
  ID-1: / raw-size: 118.95 GiB size: 116.52 GiB (97.96%)
    used: 20.28 GiB (17.4%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
    uuid: 29649f05-10b5-4df2-9d3a-46c207e3f665
  ID-2: /amp_saves raw-size: 931.51 GiB size: 931.51 GiB (100.00%)
    used: 187.72 GiB (20.2%) fs: ntfs dev: /dev/sdc3 maj-min: 8:35
    label: AMP saves uuid: 64A84D6EA84D3FB2
  ID-3: /backup raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
    used: 615.71 GiB (33.0%) fs: ntfs dev: /dev/sdd2 maj-min: 8:50 label: Backup
    uuid: 14C6922BC6920CDC
  ID-4: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
    uuid: 4A5E-CA9F
  ID-5: /docker_data raw-size: 843.33 GiB size: 829.52 GiB (98.36%)
    used: 382.9 MiB (0.0%) fs: ext4 dev: /dev/sda3 maj-min: 8:3
    label: docker_data uuid: e31e2c90-8760-46ab-bd82-c125532fb276
  ID-1: /dev/sdd1 maj-min: 8:49 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  Device-1: 1-7:5 info: Corsair K63 Wireless USB Receiver type: mouse,HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1b1c:1b8f class-ID: 0300
    serial: <filter>
  Hub-2: 2-0:1 info: super-speed hub ports: 10 rev: 3.0
  System Temperatures: cpu: 24.0 C pch: 32.5 C mobo: N/A
  Fan Speeds (rpm): N/A
  Processes: 404 Uptime: 33d 23h 13m wakeups: 0 Init: systemd v: 254
  default: system-update tool: systemctl Compilers: gcc: 13.2.1 clang: 16.0.6
  Packages: pm: pacman pkgs: 1069 libs: 317 tools: pamac pm: flatpak pkgs: 0
  Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.30
When I run mhwd it can’t find a driver
$ sudo mhwd -a pci free 0200
Warning: No config found for device: 0000:02:00.0 (0200:1969:e0a1) Network controller Qualcomm Atheros Killer E2400 Gigabit Ethernet Controller
$ sudo mhwd -a pci nonfree 0200
Can someone help me understand how / what I have to do to install it?
According to linux hardware org it should be compattible?
The driver is already installed. It’s included in the kernel.
ok, then why is my download speed 5 Mbit/s?
First, update!
If still no improvement - You could try other kernels.
okay, a simple restart did the trick :slight_smile:
kinda odd that after a few weeks of uptime and updates this happens.
Time to make a crontab that restarts the server every week I suppose :person_shrugging:
