Hello
I’m getting some errors using GPU apps(mostly games), when I run DRI_PRIME=1 LIBGL_DEBUG=verbose glxgears
the same applies for my iGPU
libGL: using driver amdgpu for 5
libGL: Can't open configuration file /etc/drirc: No such file or directory.
libGL: pci id for fd 5: 1002:6900, driver radeonsi
libGL: MESA-LOADER: dlopen(/usr/lib/dri/radeonsi_dri.so)
/usr/share/libdrm/amdgpu.ids version: 1.0.0
libGL: Using DRI3 for screen 0
Running synchronized to the vertical refresh. The framerate should be
approximately the same as the monitor refresh rate.
308 frames in 5.0 seconds = 61.415 FPS
301 frames in 5.0 seconds = 60.006 FPS
301 frames in 5.0 seconds = 60.004 FPS
I made some research and reintalling drivers libraries or using LIBGL_ALWAYS_INDIRECT=1
(this give me others errors) not work
Here my spects:
System: Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0 Desktop: KDE Plasma 5.20.4 tk: Qt 5.15.2
wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Laptop System: TOSHIBA product: N/A v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: TOSHIBA model: CA10SU serial: <filter> UEFI: TOSHIBA v: 1.40 date: 12/05/2014
Battery: ID-1: BAT0 charge: 25.6 Wh condition: 25.6/44.7 Wh (57%) volts: 16.1/14.8 model: PEGA G71C000HS110 type: Li-ion
serial: N/A status: Not charging
CPU: Info: Dual Core model: Intel Core i5-4210U bits: 64 type: MT MCP arch: Haswell rev: 1 L2 cache: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 19162
Speed: 1696 MHz min/max: 800/2700 MHz Core speeds (MHz): 1: 1696 2: 1696 3: 1696 4: 1696
Graphics: Device-1: Intel Haswell-ULT Integrated Graphics vendor: Toshiba driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:0a16
Device-2: Chicony TOSHIBA Web Camera - HD type: USB driver: uvcvideo bus ID: 2-6:3 chip ID: 04f2:b446
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: amdgpu,intel resolution: 1366x768~60Hz s-dpi: 96
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2) v: 4.5 Mesa 20.3.1 compat-v: 3.0 direct render: Yes
Audio: Device-1: Intel Haswell-ULT HD Audio vendor: Toshiba driver: snd_hda_intel v: kernel bus ID: 00:03.0
chip ID: 8086:0a0c
Device-2: Intel 8 Series HD Audio vendor: Toshiba driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:9c20
Sound Server: ALSA v: k5.9.16-1-MANJARO
Network: Device-1: Qualcomm Atheros QCA9565 / AR9565 Wireless Network Adapter vendor: Lite-On driver: ath9k v: kernel
port: f040 bus ID: 02:00.0 chip ID: 168c:0036
Drives: Local Storage: total: 298.09 GiB used: 43.03 GiB (14.4%)
ID-1: /dev/sda vendor: Western Digital model: WD3200BEKT-60PVMT0 size: 298.09 GiB speed: 3.0 Gb/s serial: <filter>
rev: 1A01
Partition: ID-1: / size: 292.12 GiB used: 43.03 GiB (14.7%) fs: ext4 dev: /dev/sda2
ID-2: /boot/efi size: 299.4 MiB used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1
Swap: Alert: No Swap data was found.
Sensors: System Temperatures: cpu: 43.0 C mobo: N/A gpu: amdgpu temp: 40.0 C
Info: Processes: 218 Uptime: 6h 57m wakeups: 1 Memory: 7.69 GiB used: 5.82 GiB (75.7%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.0.0 Packages: 1319 pacman: 1310 snap: 9 Shell: Bash v: 5.1.0 running in: konsole inxi: 3.2.01
