I’m sorry if I’m in the wrong section my problem is kinda weird.
I few hours ago I tried to delete some big files the total was higher than 30 go so dolphin told me to delete by small bits. I do that but what happens is that the file disappears but the disk still is full.
here’s what -df returns:
[> stormer@stormer Trash]$ df
> df: /run/user/1000/doc: Opération non permise
> Sys. de fichiers Taille Utilisé Dispo Uti% Monté sur
> dev 3,9G 0 3,9G 0% /dev
> run 3,9G 1,7M 3,9G 1% /run
> /dev/sda1 293G 268G 9,8G 97% /
> tmpfs 3,9G 307M 3,6G 8% /dev/shm
> tmpfs 3,9G 60M 3,9G 2% /tmp
> /dev/loop3 374M 374M 0 100% /var/lib/snapd/snap/anbox/186
> /dev/loop4 357M 357M 0 100% /var/lib/snapd/snap/clementine/1292
> /dev/loop1 263M 263M 0 100% /var/lib/snapd/snap/citra-emu/116
> /dev/loop7 56M 56M 0 100% /var/lib/snapd/snap/core18/2066
> /dev/loop6 56M 56M 0 100% /var/lib/snapd/snap/core18/1997
> /dev/loop5 100M 100M 0 100% /var/lib/snapd/snap/core/11187
> /dev/loop8 62M 62M 0 100% /var/lib/snapd/snap/core20/1026
> /dev/loop2 357M 357M 0 100% /var/lib/snapd/snap/clementine/1289
> /dev/loop0 263M 263M 0 100% /var/lib/snapd/snap/citra-emu/117
> /dev/loop9 62M 62M 0 100% /var/lib/snapd/snap/core20/975
> /dev/loop10 67M 67M 0 100% /var/lib/snapd/snap/csbooks/41
> /dev/loop11 44M 44M 0 100% /var/lib/snapd/snap/custom-screen-resolution/27
> /dev/loop12 163M 163M 0 100% /var/lib/snapd/snap/gnome-3-28-1804/145
> /dev/loop14 219M 219M 0 100% /var/lib/snapd/snap/gnome-3-34-1804/72
> /dev/loop13 219M 219M 0 100% /var/lib/snapd/snap/gnome-3-34-1804/66
> /dev/loop15 244M 244M 0 100% /var/lib/snapd/snap/gnome-3-38-2004/39
> /dev/loop17 66M 66M 0 100% /var/lib/snapd/snap/gtk-common-themes/1515
> /dev/loop19 156M 156M 0 100% /var/lib/snapd/snap/joplin-james-carroll/62
> /dev/loop16 65M 65M 0 100% /var/lib/snapd/snap/gtk-common-themes/1514
> /dev/loop18 156M 156M 0 100% /var/lib/snapd/snap/joplin-james-carroll/61
> /dev/loop20 435M 435M 0 100% /var/lib/snapd/snap/lutris-mts/65
> /dev/loop21 11M 11M 0 100% /var/lib/snapd/snap/sc-controller/77
> /dev/loop22 51M 51M 0 100% /var/lib/snapd/snap/snap-store/542
> /dev/loop23 51M 51M 0 100% /var/lib/snapd/snap/snap-store/547
> /dev/loop24 33M 33M 0 100% /var/lib/snapd/snap/snapd/12057
> /dev/loop25 33M 33M 0 100% /var/lib/snapd/snap/snapd/12159
> /dev/loop26 173M 173M 0 100% /var/lib/snapd/snap/spotify/43
> /dev/loop28 73M 73M 0 100% /var/lib/snapd/snap/youtube-music-desktop-app/6
> /dev/loop27 180M 180M 0 100% /var/lib/snapd/snap/spotify/46
> tmpfs 792M 104K 792M 1% /run/user/1000
> /dev/sdb4 596G 589G 6,8G 99% /run/media/stormer/B4BAADAEBAAD6D94
> [stormer@stormer Trash]$ S
I also tried using ncdu to calculate the missing data and comparing it to mi disk size 30 go or so are missing
I also got this using filelight
And the kde particition manager
Thanks in advance
