Use unicode when escaping a character doesn’t work
There doesn’t appear to be anyway to prevent a url name from being a hyperlink. A blackslash, quoting doesn’t work. So for example, it is either manjaro.org, manjaro dot org or manjaro․org. The later one uses Unicode: ctrl+shift+u2024spacebar.
Tables
Sometimes it would be nice to format text in columns or a table. However the table isn’t styled nicely.
A simple example:
|Ccommand | Documentation|
| pacman | man [pacman](https://man.archlinux.org/man/core/pacman/pacman.8.en) |
| inxi | man [rsync](https://man.archlinux.org/man/extra/rsync/rsync.1.en) |
