Mirrorlist timer: how to disable?
How can I permanently! disable the mirrorlist-timer or best uninstall it completely? I don’t like it when my created mirrorlist is messed up again and again by a program without asking.
sudo systemctl disable pamac-mirrorlist.timer
If that does not work, then mask the service
sudo systemctl mask pamac-mirrorlist.timer
thanks @jrichard326
