Is this news to you?
For as long as I remember the basic take has been “manjaro’s grub boots anything, but manjaro wont be booted by anyone elses grub”
As in - true today and true 5 years ago.
[manjaro /]# grub-install --recheck --no-rs-codes --modules="part_gpt part_msdos" --target="i386-pc" /dev/sda
Installing for i386-pc platform.
grub-install: error: cannot find a device for /boot/grub (is /dev mounted?).
[manjaro /]# umount /dev
umount: /dev: not mounted.
[manjaro /]# mount /dev
mount: /dev: can't find in /etc/fstab.
sudo fdisk -l ✔
Disk /dev/sda: 447.13 GiB, 480103981056 bytes, 937703088 sectors
Disk model: KINGSTON SA400S3
Disklabel type: gpt
Disk identifier: DD7DB4FF-03E1-C84E-AFEB-5CE0A07FCA5C
Device Start End Sectors Size Type
/dev/sda1 2048 1026047 1024000 500M EFI System
/dev/sda2 1042432 210757631 209715200 100G Linux filesystem
/dev/sda3 210757632 378529791 167772160 80G Linux filesystem
/dev/sda4 378529792 937703054 559173263 266.6G Linux filesystem
/dev/sda5 1026048 1042431 16384 8M BIOS boot
Partition table entries are not in disk order.
Disk /dev/sdb: 167.68 GiB, 180045766656 bytes, 351651888 sectors
Disk model: INTEL SSDSC2BF18
Disklabel type: dos
Disk identifier: 0x8bb05186
Device Boot Start End Sectors Size Id Type
/dev/sdb1 * 2048 104447 102400 50M 7 HPFS/NTFS/exFAT
/dev/sdb2 104448 350581687 350477240 167.1G 7 HPFS/NTFS/exFAT
/dev/sdb3 350582784 351647743 1064960 520M 27 Hidden NTFS WinRE
Disk /dev/loop0: 19.03 MiB, 19955712 bytes, 38976 sectors
Disk /dev/loop1: 785.64 MiB, 823803904 bytes, 1608992 sectors
Disk /dev/loop2: 2.06 GiB, 2217250816 bytes, 4330568 sectors
Disk /dev/loop3: 790.88 MiB, 829292544 bytes, 1619712 sectors
Disk /dev/sdc: 7.45 GiB, 8004304896 bytes, 15633408 sectors
Disk model: Cruzer Blade
Disklabel type: dos
Disk identifier: 0x00000000
/dev/sdc1 * 64 7754399 7754336 3.7G 0 Empty
/dev/sdc2 7754400 7762591 8192 4M ef EFI (FAT-12/16/32)
sudo parted -l ✔
Model: ATA KINGSTON SA400S3 (scsi)
Disk /dev/sda: 480GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 525MB 524MB fat32 efi boot, esp
5 525MB 534MB 8389kB bios_grub
2 534MB 108GB 107GB btrfs
3 108GB 194GB 85.9GB btrfs
4 194GB 480GB 286GB btrfs
Model: ATA INTEL SSDSC2BF18 (scsi)
Disk /dev/sdb: 180GB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 1049kB 53.5MB 52.4MB primary ntfs boot
2 53.5MB 179GB 179GB primary ntfs
3 179GB 180GB 545MB primary ntfs msftres
Model: SanDisk Cruzer Blade (scsi)
Disk /dev/sdc: 8004MB
Disk Flags:
2 3970MB 3974MB 4194kB primary esp
sudo blkid ✔
/dev/loop1: TYPE="squashfs"
/dev/sdb2: BLOCK_SIZE="512" UUID="FE64C54064C4FD01" TYPE="ntfs" PARTUUID="8bb05186-02"
/dev/sdb3: BLOCK_SIZE="512" UUID="0E6CE3BB6CE39BA9" TYPE="ntfs" PARTUUID="8bb05186-03"
/dev/sdb1: LABEL="Riservato per il sistema" BLOCK_SIZE="512" UUID="E2209BC5209B9EDB" TYPE="ntfs" PARTUUID="8bb05186-01"
/dev/loop2: TYPE="squashfs"
/dev/loop0: TYPE="squashfs"
/dev/sdc2: SEC_TYPE="msdos" LABEL_FATBOOT="MISO_EFI" LABEL="MISO_EFI" UUID="01B3-DEA1" BLOCK_SIZE="512" TYPE="vfat"
/dev/sdc1: BLOCK_SIZE="2048" UUID="2022-01-23-13-30-08-00" LABEL="MANJARO_KDE_2122" TYPE="iso9660"
/dev/sda4: UUID="a9b7a5d3-a91c-4c2e-a305-fe74f6663216" UUID_SUB="59ddbe04-bb49-47b0-9f90-ee66f57b79d3" BLOCK_SIZE="4096" TYPE="btrfs" PARTUUID="145c6721-4cb3-a346-98d7-98b04fa7963d"
/dev/sda2: UUID="c819836c-fb84-42b9-a250-5280945e60b0" UUID_SUB="a67dd949-88ac-4f3c-9671-1741f502872f" BLOCK_SIZE="4096" TYPE="btrfs" PARTUUID="2ed1b72c-61f2-0043-89d8-2525b6573ee4"
/dev/sda5: PARTUUID="327464d9-9cf7-bc43-80f6-c65629026c63"
/dev/sda3: UUID="8155e4cd-8519-4ac6-907d-b7ff564c12d9" UUID_SUB="ac4bf734-18a8-43de-82c8-c9ee5c94ed47" BLOCK_SIZE="4096" TYPE="btrfs" PARTUUID="8be92d1c-4ee2-c24e-9193-55038567d369"
/dev/sda1: LABEL_FATBOOT="EFI" LABEL="EFI" UUID="DE6A-AE14" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="efi" PARTUUID="008ddd5f-2bab-9b44-8ae9-e22a16acb2ef"
/dev/loop3: TYPE="squashfs"
I’m sorry guys, but I’m tired and need to get it working tomorrow morning, so I reinstalled keeping data safe not formatting the /home partition and recreating the same user with same pw.
Manjaro’s GRUB has overwrited the Mint’s one and it recognised all the OSs as well.
Thank you all
