Hi just installed Linux Mint alongside my Manjaro default system, but Mint’s GRUB doesn’t recognize Manjaro, How to make it appare?
Forgot to mention some details:
I’m using GPT partition table without UEFI and all the partitions are BTRFS.
Os-prober & update-grub doesn’t solve.
Wollie
2 February 2022 10:09
2
Use Manjaro’s grub to boot Mint instead. To do so, restore the boot loader from manjaro’s side.
if you want Mint’s grub boot Manjaro better ask in a Mint forum.
Yep, that’s what I would like to do, but Mint’s GRUB overwritten the Manjaro’s one, so not possible
Wollie
2 February 2022 10:13
4
As I said, restore the boot loader from Manjaro’s side. That’s always possible.
You could boot from a live ISO. Then use manjaro-chroot .
And how can I boot Manjaro if there’s not that option in the actual GRUB?
Seen your update above. Thanks
philm
2 February 2022 10:17
6
Is the tool os-prober installed on Mint?
Sure it is. Boot up from the Manjaro install USB or DVD in live mode and open up a terminal window. Then issue the following commands…
sudo su -
manjaro-chroot -a
Pick your Manjaro installation from the menu. Then issue the following command…
nano /etc/default/grub
Make sure that you have these two lines, by modifying the existing ones…
GRUB_TIMEOUT_STYLE=menu
GRUB_DISABLE_OS_PROBER=false
Next, save the file with Ctrl+O and exit nano
with Ctrl+X . Then run the following two commands…
grub-install --recheck --no-rs-codes
update-grub
It should be safe now to cleanly reboot. Don’t forget to remove the USB/DVD in time in order to reboot into the installed system.
Yes, but like I said don’t recognize M.
Downloading M right now, then will do it.
Thanks.
~ sudo su - ✔
[manjaro ~]# manjaro-chroot -a
grub-probe: error: cannot find a GRUB drive for /dev/sdc1. Check your device.map.
==> ERROR: No Linux partitions detected!
[manjaro ~]#
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 19M 1 loop /run/miso/sfs/livefs
loop1 7:1 0 785.6M 1 loop /run/miso/sfs/mhwdfs
loop2 7:2 0 2.1G 1 loop /run/miso/sfs/desktopfs
loop3 7:3 0 790.9M 1 loop /run/miso/sfs/rootfs
sda 8:0 0 447.1G 0 disk
├─sda1 8:1 0 500M 0 part
├─sda2 8:2 0 100G 0 part
├─sda3 8:3 0 80G 0 part
├─sda4 8:4 0 266.6G 0 part
└─sda5 8:5 0 8M 0 part
sdb 8:16 0 167.7G 0 disk
├─sdb1 8:17 0 50M 0 part
├─sdb2 8:18 0 167.1G 0 part
└─sdb3 8:19 0 520M 0 part
sdc 8:32 1 7.5G 0 disk /run/miso/bootmnt
├─sdc1 8:33 1 3.7G 0 part
└─sdc2 8:34 1 4M 0 part
Manjaro’s root directory is /sda2
Wollie
2 February 2022 11:59
13
Please provide output of
sudo fdisk -l
sudo parted -l
sudo blkid
I’m at work right now.
Will answer tonight.
/home
is not important in that regard. But what drive do you boot from? That’s the one we need to write GRUB to from within the chroot
, and we’re going to have to talk you through a manual chroot
, given that the automatic one doesn’t work…
Manjaro has those 2 partitions only and bl must to be on /dev/sda.
It’s always booted from there.
In that case, and given that it’s a legacy BIOS boot, the procedure is less complicated than with UEFI boot.
Boot up from the install medium in live mode and open up a terminal window. Issue the following commands…
sudo su -
mkdir /mnt
mount -t btrfs -o subvol=@ /dev/sda2 /mnt
mount --bind /dev /mnt/dev
mount -t proc proc /mnt/proc
mount -t sysfs sysfs /mnt/sys
chroot /mnt /usr/bin/bash
grub-install --recheck --no-rs-codes --modules="part_gpt part_msdos" --target="i386-pc" /dev/sda
update-grub
exit
After this, things should work, and you should be able to reboot into Manjaro.
I’ll try tonight.
Thank you so much for now.
