How to install OBS and NDI plugin?
Hi form a noob. I know nothing about Linux and with the problem of win 11 I thought I would give it a try.
This is my problem. I try to in stall OBS Studio and the NDI plug in on Manjaro KDE Plasma I type “sudo apt install obs-studio” but apt is not a recognized command so I tried “sudo install obs-studio” it then asks for my password and then I get “install: missing destination file operand after “obs-studio” try install --help” I think its asking me to create a file for obs but how?
then I have the next problem how to install the plugin for NDI??
can you help Big THANK YOU.
Hi @IVG, and welcome!
Yes, Linux can be intimidating, but it is much, much, much better than the alternative. However, do not fear. Rather, look here:
Manjaro is not Debian, or Ubuntu, and as such doesn’t have *apt or apt-get or something in that line. Rather, Manjaro uses pamac.
Go ahead and reead up on that. It’s good knowledge. Also important knowledge.
to install obs you would have to
pamac install obs-studio
https://wiki.manjaro.org/index.php/Using_Manjaro_for_Beginners
As for ndi
install it the same way…
pamac install obs-ndi
