Minimum required java version
#1
I have 3 java programs available in the AUR and with Java 9 released there is a small problem.
I made my first package with inspiration from another java program in the AUR and used much of its structure, including the java version check, a check that will fail for Java 9.
So my question is, is there a really really good way to check for a minimum and possible maximum java version?
#!/bin/sh
if ! /usr/bin/java -version 2>&1 | grep 'version "1.8' >/dev/null
then
	echo "mapollage requires Java 8" >&2
	exit 1
fi
#unset JAVA_TOOL_OPTIONS
exec /usr/bin/java -jar '/usr/share/java/mapollage/mapollage.jar' "$@"
#2
Where is run the java version check? I might not completely understood the question
For a PKGBUILD I would like to use this for example
depends=(‘java-environment>=7’
‘java-environment<9’)
Require Java 7 or 8 but not 6 or 9
#3
Thank you!
Today, in https://aur.archlinux.org/cgit/aur.git/tree/PKGBUILD?h=mapollage I have
depends=(‘java-runtime=8’) but I will change that.
Is there a good way to check the java version in the shell script too?
#4
That is beyond my knowledge
#5
You’ve already got a version check in the shell script. It will work fine.
#6
