I’ve just discovered Minder (mind maps) and really like it but on Manjaro KDE there are no document icons - only the document name appears.
I have GTK2 and GTK3 themes set to Breath-Dark under application style.
Is there anything I am missing?
Thx in advance.
True… there are no icons for the documents. But you can do these manually…
Here are the icons for the app:
/usr/share/icons/hicolor/128x128/apps/com.github.phase1geo.minder.svg
/usr/share/icons/hicolor/16x16/apps/com.github.phase1geo.minder.svg
/usr/share/icons/hicolor/24x24/apps/com.github.phase1geo.minder.svg
/usr/share/icons/hicolor/32x32/apps/com.github.phase1geo.minder.svg
/usr/share/icons/hicolor/48x48/apps/com.github.phase1geo.minder.svg
/usr/share/icons/hicolor/64x64/apps/com.github.phase1geo.minder.svg
you need to put these svgs also into a folder called mimetypes
at /usr/share/icons/hicolor/*/mimetypes.
cp /usr/share/icons/hicolor/*/apps/com.github.phase1geo.minder.svg /usr/share/icons/hicolor/*/mimetypes/com.github.phase1geo.minder.svg
then add
<generic-icon name="com.github.phase1geo.minder.svg"/>
to these files:
/usr/share/mime/application/com.github.phase1geo.minder.xml
/usr/share/mime/packages/com.github.phase1geo.minder.xml
between <mime-type> and </mime-type>.
Then recreate the icon cache:
sudo gtk-update-icon-cache -f -t /usr/share/icons/hicolor/
Hope that helps. Maybe someone fix it in the package.
I’m sorry megavolt but my terminal skills aren’t up to this…
seems to refer to a directory on my computer but I could only find:
/home/root/.local/share/icons/hicolor/
which has two folders inside: 48*48 and scalable.
Do I have to go to github and download them first?
