Hey everyone, so my microphone (just a pair of earbud put through a splitter to plug into my microphone jack) was working fine up until a faw days ago, but now when I record sound, all I get is uniform, high frequency noise.
I looked through Advanced Linux Sound Architecture/Troubleshooting - ArchWiki but couldn’t find anything that helped, so I’m wondering if someone here can help me figure out what’s going wrong.
Here is my pacmd list-sources
3 source(s) available.
index: 0
driver: <module-alsa-card.c>
flags: HARDWARE DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9040
volume: mono: 35389 / 54% / -16.06 dB
balance 0.00
base volume: 65536 / 100% / 0.00 dB
volume steps: 65537
muted: no
current latency: 0.00 ms
max rewind: 0 KiB
sample spec: s16le 1ch 16000Hz
channel map: mono
Mono
used by: 0
linked by: 0
configured latency: 0.00 ms; range is 0.50 .. 2000.00 ms
card: 1 <alsa_card.usb-Ruision_UVC_Camera_20200416-02>
module: 7
properties:
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "USB Audio"
alsa.id = "USB Audio"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "2"
alsa.card_name = "UVC Camera"
alsa.long_card_name = "Ruision UVC Camera at usb-0000:20:00.3-4, high speed"
alsa.driver_name = "snd_usb_audio"
device.bus_path = "pci-0000:20:00.3-usb-0:4:1.2"
sysfs.path = "/devices/pci0000:00/0000:00:07.1/0000:20:00.3/usb5/5-4/5-4:1.2/sound/card2"
udev.id = "usb-Ruision_UVC_Camera_20200416-02"
device.bus = "usb"
device.vendor.id = "12d1"
device.vendor.name = "Huawei Technologies Co., Ltd."
device.product.id = "4321"
device.product.name = "UVC Camera"
device.serial = "Ruision_UVC_Camera_20200416"
device.form_factor = "webcam"
device.string = "hw:2"
device.buffering.buffer_size = "64000"
device.buffering.fragment_size = "32000"
device.access_mode = "mmap+timer"
device.profile.name = "multichannel-input"
device.profile.description = "Multichannel"
device.description = "UVC Camera Multichannel"
module-udev-detect.discovered = "1"
device.icon_name = "camera-web-usb"
index: 10
flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: IDLE
suspend cause: (none)
priority: 1030
volume: front-left: 17988 / 27% / -33.69 dB, front-right: 17988 / 27% / -33.69 dB
balance 0.00
volume steps: 65537
muted: no
max rewind: 3 KiB
sample spec: s16le 2ch 48000Hz
channel map: front-left,front-right
Stereo
used by: 0
linked by: 0
configured latency: 2000.00 ms; range is 0.50 .. 2000.00 ms
monitor_of: 6
card: 2 <alsa_card.pci-0000_21_00.3>
module: 8
properties:
device.description = "Monitor of Family 17h (Models 00h-0fh) HD Audio Controller Analog Stereo"
device.class = "monitor"
alsa.card = "1"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xf7700000 irq 70"
device.bus_path = "pci-0000:21:00.3"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:21:00.3/sound/card1"
device.bus = "pci"
device.vendor.id = "1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "1457"
device.product.name = "Family 17h (Models 00h-0fh) HD Audio Controller"
device.string = "1"
device.icon_name = "audio-card-pci"
* index: 12
flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
state: SUSPENDED
suspend cause: IDLE
priority: 9039
volume: front-left: 22938 / 35% / -27.36 dB, front-right: 22938 / 35% / -27.36 dB
balance 0.00
base volume: 6554 / 10% / -60.00 dB
volume steps: 65537
muted: no
max rewind: 0 KiB
Stereo
used by: 0
linked by: 0
module: 8
properties:
device.api = "alsa"
alsa.name = "ALC892 Analog"
alsa.id = "ALC892 Analog"
alsa.device = "0"
alsa.card = "1"
device.bus = "pci"
device.string = "front:1"
device.buffering.buffer_size = "384000"
device.buffering.fragment_size = "192000"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
device.description = "Family 17h (Models 00h-0fh) HD Audio Controller Analog Stereo"
ports:
analog-input-front-mic: Front Microphone (priority 8500, latency offset 0 usec, available: yes)
properties:
analog-input-rear-mic: Rear Microphone (priority 8200, latency offset 0 usec, available: no)
properties:
analog-input-linein: Line In (priority 8100, latency offset 0 usec, available: no)
properties:
active port: <analog-input-front-mic>
I’m using the front microphone jack.
Here are my sinks
[mason@mason-pc ~]$ pacmd list-sinks
1 sink(s) available.
* index: 6
state: RUNNING
priority: 9039
volume: front-left: 32113 / 49% / -18.59 dB, front-right: 32113 / 49% / -18.59 dB
balance 0.00
volume steps: 65537
muted: no
current latency: 18.69 ms
max request: 3 KiB
max rewind: 3 KiB
monitor source: 10
Stereo
used by: 1
linked by: 2
configured latency: 18.75 ms; range is 0.50 .. 2000.00 ms
module: 8
properties:
device.api = "alsa"
alsa.device = "0"
alsa.card = "1"
device.bus = "pci"
ports:
analog-output-lineout: Line Out (priority 9000, latency offset 0 usec, available: yes)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: yes)
properties:
active port: <analog-output-headphones>
and here is my plusaudio-ctl
[mason@mason-pc ~]$ pulseaudio-ctl
pulseaudio-ctl v1.67
/usr/bin/pulseaudio-ctl {up,down,mute,mute-input,set,atmost,full-status} [n]
Where up and down adjust volume in ±5 % increments
Where up and down [n] adjust volume in ±n % increments
Where mute toggles the mute status on/off
Where mute-input toggles the input status on/off
Where set set the volume to [n] %
Where atmost only takes effect if current volume is higher than [n]
Where full-status prints volume level, sink and source mute state to stdout
Optionally, redefine an upper threshold in /home/mason/.config/pulseaudio-ctl/config
Volume level : 49 %
Is sink muted : no
Is source muted : no
Detected sink : 6
Detected source : 12
Any help you can provide would be greatly appreciated.
