Microphone signal is lagging video signal on video calls
I encounter troubles regarding my microphone signal, when making video calls via the browser.
In fact, my voice is very much delayed (approx 2s), which is pretty annoying.
I already tried different input sources, i.e.
  • Bluetooth mic from headset
  • usb mic from web cam.
Unfortunately, both lead to the same delay.
This is my system:
~ >>> inxi --admin --verbosity=8 --filter --no-host --width
  Kernel: 6.12.64-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    root=UUID=4c2ea2f1-3cfa-4377-8778-97f19f2453fe rw quiet
    cryptdevice=UUID=ac37595d-5b67-408c-82b8-547a678e97e6:luks-ac37595d-5b67-408c-82b8-547a678e97e6
    root=/dev/mapper/luks-ac37595d-5b67-408c-82b8-547a678e97e6
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A info: frameworks v: 6.21.0
  Type: Desktop System: MSI product: MS-7798 v: 1.0
    serial: <superuser required>
  Mobo: MSI model: B75MA-P45 (MS-7798) v: 1.0 serial: <superuser required>
    uuid: <superuser required> Firmware: UEFI vendor: American Megatrends v: 1.9
    date: 09/30/2013
  Device-1: hidpp_battery_0 model: Logitech M720 Triathlon Multi-Device Mouse
    status: discharging
  System RAM: total: 24 GiB available: 23.4 GiB used: 5.57 GiB (23.8%)
  Array-1: capacity: 32 GiB slots: 4 modules: 4 EC: None
  Device-1: ChannelA-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
    speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Corsair part-no: CML8GX3M2A1600C9 serial: N/A
  Device-2: ChannelA-DIMM1 type: DDR3 detail: synchronous size: 8 GiB
    manufacturer: Hynix/Hyundai part-no: HMT41GU6AFR8A-PB serial: <filter>
  Device-3: ChannelB-DIMM0 type: DDR3 detail: synchronous size: 4 GiB
  Device-4: ChannelB-DIMM1 type: DDR3 detail: synchronous size: 8 GiB
  Info: model: Intel Core i5-3450S bits: 64 type: MCP arch: Ivy Bridge
    gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
    model-id: 0x3A (58) stepping: 9 microcode: 0x21
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 2463 min/max: 1600/3500 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 2463 2: 2463 3: 2463 4: 2463 bogomips: 22409
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
    ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
    ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx
    pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
    rdrand rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
    syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid xsave
    xsaveopt xtopology xtpr
    disabled
    STIBP: disabled; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Type: srbds status: Vulnerable: No microcode
  Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate]
    vendor: Micro-Star MSI driver: nvidia v: 590.48.01
    alternate: nouveau,nvidia_drm non-free: 550-580.xx+ status: current (as of
    2025-11; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
    built: 2020-2023 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
    speed: 16 GT/s ports: active: HDMI-A-1 empty: DP-1,DP-2,DP-3
    bus-ID: 01:00.0 chip-ID: 10de:2504 class-ID: 0300
  Device-2: Logitech BRIO Ultra HD Webcam driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 4-1.5.2:5
    chip-ID: 046d:085e class-ID: 0102 serial: <filter>
    compositor: kwin_wayland driver: X: loaded: nvidia
    gpu: nv_platform,nvidia,nvidia-nvswitch display-ID: 0
  Monitor-1: HDMI-A-1 model: Idek Iiyama PL2792Q serial: <filter> built: 2021
    res: mode: 2560x1440 hz: 60 scale: 100% (1) dpi: 109 gamma: 1.2 chroma: red:
    x: 0.671 y: 0.333 green: x: 0.298 y: 0.627 blue: x: 0.141 y: 0.051 white:
    x: 0.322 y: 0.329 size: 597x336mm (23.5x13.23") diag: 685mm (27")
    ratio: 16:9 modes: 2560x1440, 2048x1280, 1920x1200, 1920x1080, 1600x1200,
    1680x1050, 1600x900, 1280x1024, 1440x900, 1280x720, 1024x768, 800x600,
    720x576, 720x480, 640x480
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
    x11: drv: nvidia inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 25.3.3-arch1.1
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
    memory: 11.72 GiB display-ID: :1.0
  API: Vulkan v: 1.4.335 layers: 4 device: 0 type: discrete-gpu
    name: NVIDIA GeForce RTX 3060 driver: nvidia v: 590.48.01
    device-ID: 10de:2504 surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: corectrl, nvidia-settings, nvidia-smi
  Device-1: Intel 7 Series/C216 Family High Definition Audio
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:1e20 class-ID: 0403
  Device-2: NVIDIA GA106 High Definition Audio vendor: Micro-Star MSI
    link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:228e
    class-ID: 0403
  Device-3: GN Netcom Jabra Link 380 driver: jabra,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.1:13
    chip-ID: 0b0e:24c8 class-ID: 0300 serial: <filter>
  Device-4: Logitech BRIO Ultra HD Webcam driver: snd-usb-audio,uvcvideo
  API: ALSA v: k6.12.64-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
    status: active 2: pipewire-media-session status: active 3: pipewire-alsa
    type: plugin tools: pactl,pw-cat,pw-cli
    vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: AVM GmbH FRITZ!WLAN AC 860 driver: mt76x2u type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:9 chip-ID: 057c:8503
    class-ID: 0000 serial: <filter>
  IF: wlp0s20u3 state: up mac: <filter>
  Device-1: bitlk_mobi_stick maj-min: 254:3 type: Crypto dm: dm-3
  Components:
  p-1: sdd1 maj-min: 8:49 size: 119.01 GiB
  Device-2: bitlk_daniel_stick maj-min: 254:4 type: Crypto dm: dm-4
  Components:
  p-1: sdd2 maj-min: 8:50 size: 30 GiB
  Device-3: bitlk_bibliothek_stick maj-min: 254:5 type: Crypto dm: dm-5
  Components:
  p-1: sdd3 maj-min: 8:51 size: 30 GiB
  Device-4: bitlk_wiki_stick maj-min: 254:6 type: Crypto dm: dm-6
  Components:
  p-1: sdd4 maj-min: 8:52 size: 30 GiB
  Device-5: bitlk_work_stick maj-min: 254:7 type: Crypto dm: dm-7
  Components:
  p-1: sdd5 maj-min: 8:53 size: 30 GiB
  Device-6: luks-ac37595d-5b67-408c-82b8-547a678e97e6 maj-min: 254:0
    type: LUKS dm: dm-0 size: 232.59 GiB
  Components:
  p-1: sda2 maj-min: 8:2 size: 232.59 GiB
  Device-7: luks-8e70af97-5288-4227-b43f-15c7ae8b158e maj-min: 254:2
    type: LUKS dm: dm-2 size: 931.51 GiB
  Components:
  p-1: sdb1 maj-min: 8:17 size: 931.51 GiB
  Device-8: luks-97478fb5-267e-493d-8774-49eef2f55050 maj-min: 254:1
    type: LUKS dm: dm-1 size: 465.76 GiB
  Components:
  p-1: sdc1 maj-min: 8:33 size: 465.76 GiB
  Local Storage: total: 1.83 TiB used: 1.09 TiB (59.8%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 1TB
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
  ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: Flash Drive FIT
    size: 239.02 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 2.1 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: SSD serial: <filter>
    fw-rev: 1100 scheme: GPT
  ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
    used: 122.3 GiB (53.7%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-ac37595d-5b67-408c-82b8-547a678e97e6 label: System
    uuid: 4c2ea2f1-3cfa-4377-8778-97f19f2453fe
    used: 472 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
    uuid: 04E7-F02F
  ID-3: /mnt/org/bibliothek raw-size: 30 GiB size: 30 GiB (100.00%)
    used: 8.54 GiB (28.5%) fs: fuseblk dev: /dev/dm-5 maj-min: 254:5
    mapped: bitlk_bibliothek_stick label: N/A uuid: N/A
  ID-4: /mnt/org/daniel raw-size: 30 GiB size: 30 GiB (100.00%)
    used: 15.6 GiB (52.0%) fs: fuseblk dev: /dev/dm-4 maj-min: 254:4
    mapped: bitlk_daniel_stick label: N/A uuid: N/A
  ID-5: /mnt/org/mobi raw-size: 119.01 GiB size: 119.01 GiB (100.00%)
    used: 34.43 GiB (28.9%) fs: fuseblk dev: /dev/dm-3 maj-min: 254:3
    mapped: bitlk_mobi_stick label: N/A uuid: N/A
  ID-6: /mnt/org/wiki raw-size: 30 GiB size: 30 GiB (100.00%)
    used: 6.18 GiB (20.6%) fs: fuseblk dev: /dev/dm-6 maj-min: 254:6
    mapped: bitlk_wiki_stick label: N/A uuid: N/A
  ID-7: /mnt/org/work raw-size: 30 GiB size: 30 GiB (100.00%)
    used: 83.5 MiB (0.3%) fs: fuseblk dev: /dev/dm-7 maj-min: 254:7
    mapped: bitlk_work_stick label: N/A uuid: N/A
  ID-8: /run/media/schatzi/Data raw-size: 465.76 GiB
    size: 457.38 GiB (98.20%) used: 353.89 GiB (77.4%) fs: ext4 dev: /dev/dm-1
    maj-min: 254:1 mapped: luks-97478fb5-267e-493d-8774-49eef2f55050
    label: Data uuid: aea89950-6192-4055-8c45-0991f2477684
  ID-9: /run/media/schatzi/Extra raw-size: 931.51 GiB
    size: 915.81 GiB (98.31%) used: 576.45 GiB (62.9%) fs: ext4 dev: /dev/dm-2
    maj-min: 254:2 mapped: luks-8e70af97-5288-4227-b43f-15c7ae8b158e
    label: Extra uuid: a584c501-ec7f-44d1-8912-433590b0e4a3
  ID-1: swap-1 type: file size: 8 GiB used: 0 KiB (0.0%) priority: -2
    file: /swapfile
  ID-1: /dev/sdd1 maj-min: 8:49 size: 119.01 GiB fs: bitlocker
    label: 20IAV502790N-0 Mobi 20.06.2023
    uuid: 19a7082b-3c22-4c74-b120-5145a4be6aea
  ID-2: /dev/sdd2 maj-min: 8:50 size: 30 GiB fs: bitlocker
    label: 20IAV502790N-0 Daniel 22.06.2023
    uuid: 31203ad1-da38-4cc3-a989-36c1904f0ce1
  ID-3: /dev/sdd3 maj-min: 8:51 size: 30 GiB fs: bitlocker
    label: 20IAV502790N-0 Bibliothek 20.06.2023
    uuid: 2cf5acb6-cd16-469d-9969-fe23c47bfb15
  ID-4: /dev/sdd4 maj-min: 8:52 size: 30 GiB fs: bitlocker
    label: 20IAV502790N-0 Wiki 20.06.2023
    uuid: 02985be4-7822-4688-af77-2b2f231f9ec5
  ID-5: /dev/sdd5 maj-min: 8:53 size: 30 GiB fs: bitlocker
    label: 20IAV502790N-0 Iav 20.06.2023
    uuid: 40082e01-5629-41e6-9622-4efe2c06129c
  Hub-2: 1-1:12 info: Cambridge Silicon Radio Mpow HC5 Headset in charging
    mode - USB Hub ports: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 0a12:4010 class-ID: 0900
  Device-1: 1-1.1:13 info: GN Netcom Jabra Link 380 type: audio,HID
    driver: jabra,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0b0e:24c8
  Device-2: 1-3:9 info: AVM GmbH FRITZ!WLAN AC 860 type: Network
    driver: mt76x2u interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 200mA chip-ID: 057c:8503 class-ID: 0000 serial: <filter>
  Hub-3: 1-4:4 info: Huasheng USB2.0 HUB ports: 4 rev: 2.0
    chip-ID: 214b:7250 class-ID: 0900
  Hub-4: 1-4.3:5 info: Monterey BakkerElkhuizen Wired Keyboard S-board 840
    Design USB-Hub ports: 3 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 100mA chip-ID: 0566:3020 class-ID: 0900
  Device-1: 1-4.3.2:6 info: Logitech Unifying Receiver
    type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
    rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
    chip-ID: 046d:c52b class-ID: 0300
  Device-2: 1-4.3.3:7 info: Monterey BakkerElkhuizen Wired Keyboard S-board
    840 Design type: keyboard,HID driver: hid-generic,usbhid interfaces: 2
    rev: 1.1 speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 100mA
    chip-ID: 0566:3013 class-ID: 0300
  Hub-5: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-6: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
  Hub-7: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
  Hub-8: 4-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-9: 4-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Hub-10: 4-1.5:3 info: Realtek 4-Port USB 2.0 Hub ports: 2 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bda:5412
  Device-1: 4-1.5.1:4 info: Silicon Motion - Taiwan (formerly Feiya ) Flash
    Drive type: mass storage driver: usb-storage interfaces: 1 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 300mA
    chip-ID: 090c:1000 class-ID: 0806 serial: <filter>
  Device-2: 4-1.5.2:5 info: Logitech BRIO Ultra HD Webcam type: video,audio
    driver: snd-usb-audio,uvcvideo interfaces: 5 rev: 2.1
  System Temperatures: cpu: 45.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 2059 libs: 464 tools: pamac pm: flatpak pkgs: 0
    1: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    2: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    3: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    4: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    5: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
    6: https://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    7: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 365
  1: cpu: 36.2% command: firefox pid: 2679 mem: 900.9 MiB (3.7%)
  2: cpu: 25.2% command: firefox pid: 7390 mem: 330.5 MiB (1.3%)
  3: cpu: 8.9% command: kwin_wayland pid: 977 mem: 323.9 MiB (1.3%)
  4: cpu: 6.6% command: firefox pid: 2796 mem: 57.6 MiB (0.2%)
  5: cpu: 5.0% command: firefox pid: 8045 mem: 355.4 MiB (1.4%)
  Memory top: 5 of 365
  1: mem: 900.9 MiB (3.7%) command: firefox pid: 2679 cpu: 36.2%
  2: mem: 631.3 MiB (2.6%) command: plasmashell pid: 1159 cpu: 1.5%
  3: mem: 622.9 MiB (2.5%) command: thunderbird pid: 2413 cpu: 0.8%
  4: mem: 456.3 MiB (1.9%) command: firefox pid: 3099 cpu: 3.2%
  5: mem: 422.6 MiB (1.7%) command: firefox pid: 6179 cpu: 0.8%
  Processes: 365 Power: uptime: 1h 31m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 9.33 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 258 default: graphical
    tool: systemctl
  Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.3.9 running-in: konsole inxi: 3.3.40
Can someone kindly provide some help/ ideas?
Thanks!
Hi, I’m no expert with audio issues but have frequently had problems with audio lag during e.g. Skype calls (Teams seems better in that respect).
It could of course be down to network latency, browser overheads etc.; is it consistently 2s?
Is it just with the browser (which one?) and which “service” are you using? … have you tried a standalone program? (Usually preferred, if available).
@BG405 , thanks for the ideas!
Finally, I varied the following setups:
  1. Browser: Firefox, Chrome
  2. App: Browser, OBS Studio
  3. Microphone: BT, USB, Analog
  4. Even the OS: Manjaro, Android
On the one hand, I always observe the same (long!) delay, when using any browser, even on my Android phone. On the other hand, the delay is much smaller, when using some other app in Manjaro (like OBS Studio) for audio delay testing purposes.
Consequently, I think this topic does not belong here, since Manjaro is doing a fine job in combination with e.g. OBS. I’ll forward the issue to the support of the video platform.
Thanks again!
It does seem like a browser issue then. Maybe some add-on interfering or, as mentioned, overheads causing the lag.
I suppose it wouldn’t hurt to have htop running in a Terminal to see what resources are being used. (You might need to install this first; I find it better than the regular top).
