Microphone requires highest setting to be heard on other end
To be heard on zoom, had to set microphone setting to max (153% = 11dB) to be heard on other end.
Should be able to do this at just 20 - 30% setting…
inxi -Fazy
$ inxi -Fazy
  Kernel: 5.14.21-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.14-x86_64
    root=UUID=ed756325-b10b-4f60-b2b2-58401ad6c6b3 rw rootflags=subvol=@ quiet
    udev.log_priority=3
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
    vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
  Type: Desktop System: Gigabyte product: N/A v: N/A
    serial: <superuser required> Chassis: type: 3 serial: <superuser required>
  Mobo: Gigabyte model: F2A88XM-D3H serial: <superuser required>
    UEFI: American Megatrends v: F8 date: 04/09/2015
  Info: model: AMD A6-6400K APU with Radeon HD Graphics bits: 64 type: MT MCP
    arch: Piledriver family: 0x15 (21) model-id: 0x13 (19) stepping: 1
    microcode: 0x6001119
  Topology: cpus: 1x cores: 2 smt: enabled cache: L1: 96 KiB
    desc: d-2x16 KiB; i-1x64 KiB L2: 1024 KiB desc: 1x1024 KiB
  Speed (MHz): avg: 2976 high: 3529 min/max: 1800/3900 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2423 2: 3529
    bogomips: 15579
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  Type: spectre_v2
    mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
  Device-1: AMD Richland [Radeon HD 8470D] vendor: Gigabyte driver: radeon
    v: kernel bus-ID: 00:01.0 chip-ID: 1002:9996 class-ID: 0300
  Display: x11 server: X.Org 1.21.1.2 compositor: xfwm4 v: 4.16.1 driver:
    loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
    display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 1600x1200 s-dpi: 96 s-size: 423x317mm (16.7x12.5")
    s-diag: 529mm (20.8")
  Device-1: AMD Trinity HDMI Audio vendor: Gigabyte driver: snd_hda_intel
    v: kernel bus-ID: 00:01.1 chip-ID: 1002:9902 class-ID: 0403
  Device-2: AMD FCH Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel
    bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
  Sound Server-1: ALSA v: k5.14.21-2-MANJARO running: yes
    vendor: Gigabyte driver: r8169 v: kernel port: e000 bus-ID: 01:00.0
  IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
  Local Storage: total: 238.47 GiB used: 41.22 GiB (17.3%)
  ID-1: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T253X2256G
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    type: SSD serial: <filter> rev: 0A0 scheme: GPT
  ID-1: / raw-size: 30 GiB size: 30 GiB (100.00%) used: 17.26 GiB (57.5%)
    fs: btrfs dev: /dev/sda3 maj-min: 8:3
    used: 568 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
  ID-3: /home raw-size: 40 GiB size: 40 GiB (100.00%)
    used: 23.96 GiB (59.9%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
  ID-4: /var/log raw-size: 30 GiB size: 30 GiB (100.00%)
    used: 17.26 GiB (57.5%) fs: btrfs dev: /dev/sda3 maj-min: 8:3
  ID-1: swap-1 type: partition size: 24 GiB used: 0 KiB (0.0%) priority: -2
    dev: /dev/sda2 maj-min: 8:2
  System Temperatures: cpu: 2.5 C mobo: N/A
  Processes: 216 Uptime: 5h 23m wakeups: 0 Memory: 22.69 GiB
  used: 1.87 GiB (8.2%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1250 lib: 310 Shell: Bash
  v: 5.1.12 running-in: xfce4-terminal inxi: 3.3.11
Have you checked the microphone input level in alsamixer?
https://wiki.archlinux.org/title/Advanced_Linux_Sound_Architecture/Troubleshooting#Microphone
