My mic worked fine until last week. yesterday I found out when I try to record something it only records noises, like this one :https://gofile.io/d/Ot2ONP
(I suggest you do not listen with a headset), I thought its because my internal mic has damaged but I was wrong. when I plugged in external mic and Manjaro requgnized it, result didn’t change. again I only recorded noise.
what can cause this problem? I also tried kubuntu. it had same result. but im sure its not a hardware problem.
I should add that external sounds doesn’t effect on recording result.
pacmd list-cards output:
1 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 6
properties:
alsa.card = “0”
alsa.card_name = “HDA Intel PCH”
alsa.long_card_name = “HDA Intel PCH at 0xf7a10000 irq 36”
alsa.driver_name = “snd_hda_intel”
device.bus_path = “pci-0000:00:1b.0”
sysfs.path = “/devices/pci0000:00/0000:00:1b.0/sound/card0”
device.bus = “pci”
device.vendor.id = “8086”
device.vendor.name = “Intel Corporation”
device.product.id = “1e20”
device.product.name = “7 Series/C216 Chipset Family High Definition Audio Controller”
device.form_factor = “internal”
device.string = “0”
device.description = “Built-in Audio”
module-udev-detect.discovered = “1”
device.icon_name = “audio-card-pci”
profiles:
input:analog-stereo: Analog Stereo Input (priority 65, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 6500, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 6565, available: unknown)
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (priority 5965, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround+input:analog-stereo: Digital Surround 5.1 (HDMI) Output + Analog Stereo Input (priority 865, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround71+input:analog-stereo: Digital Surround 7.1 (HDMI) Output + Analog Stereo Input (priority 865, available: no)
off: Off (priority 0, available: unknown)
active profile: output:analog-stereo+input:analog-stereo
sinks:
alsa_output.pci-0000_00_1b.0.analog-stereo/#2: Built-in Audio Analog Stereo
sources:
alsa_output.pci-0000_00_1b.0.analog-stereo.monitor/#4: Monitor of Built-in Audio Analog Stereo
alsa_input.pci-0000_00_1b.0.analog-stereo/#6: Built-in Audio Analog Stereo
ports:
analog-input-headset-mic: Headset Microphone (priority 8800, latency offset 0 usec, available: unknown)
properties:
device.icon_name = “audio-input-microphone”
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: no)
properties:
device.icon_name = “audio-speakers”
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: unknown)
properties:
device.icon_name = “audio-headphones”
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
device.icon_name = “video-display”
