I just bought the Billboard Carbon ANC headphones and when pairing the Bluetooth or connecting the cable only the headset is detected but Headphones mic doesn’t. I’m using Manjaro KDE and replaced pulseaudio with piperwire since I installed the system.
After experimenting a bit I noticed that if I changed the default codec in plasma settings from High Fidelity Playback A2DP Sink, codec SBC
to Headset Head Unit (HSP/HPF, codec CVSD)
then the mic is detected and works but no sound is coming to the headset.
inxi -Faxzy :
Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-5.15-x86_64
root=UUID=e487773a-b1e3-4e44-a01d-7342409f572e rw rootflags=subvol=@ quiet
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
vt: 1 dm: SDDM Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Dell product: Inspiron 5570 v: N/A
Mobo: Dell model: 09NFWR v: A00 serial: <superuser required> UEFI: Dell
v: 1.7.0 date: 10/06/2021
ID-1: BAT0 charge: 12.6 Wh (100.0%) condition: 12.6/42.0 Wh (29.9%)
volts: 12.7 min: 11.4 model: BYD DELL FW8KR87 type: Li-ion serial: <filter>
status: Full
Info: model: Intel Core i5-8250U bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xEA
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 700 min/max: 400/3400 scaling: driver: intel_pstate
governor: powersave cores: 1: 700 2: 700 3: 700 4: 700 5: 700 6: 700 7: 700
8: 700 bogomips: 28808
Type: l1tf
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:5917 class-ID: 0300
Device-2: AMD Topaz XT [Radeon R7 M260/M265 / M340/M360 / M440/M445 /
530/535 / 620/625 Mobile]
vendor: Dell driver: amdgpu v: kernel bus-ID: 01:00.0 chip-ID: 1002:6900
class-ID: 0380
Device-3: Realtek Integrated Webcam type: USB driver: uvcvideo
bus-ID: 1-5:4 chip-ID: 0bda:568a class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
loaded: amdgpu,ati,modesetting alternate: fbdev,vesa display-ID: :0
screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142
size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 21.2.5
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0403
Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
driver: r8169 v: kernel port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8136
class-ID: 0200
Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
vendor: Dell driver: ath10k_pci v: kernel bus-ID: 03:00.0 chip-ID: 168c:0042
class-ID: 0280
IF-ID-1: wgpia0 state: unknown speed: N/A duplex: N/A mac: N/A
Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 1-7:7
chip-ID: 0cf3:e009 class-ID: e001
Local Storage: total: 447.15 GiB used: 23.71 GiB (5.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT240BX500SSD1
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: R013 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WDS240G2G0B-00EPW0 size: 223.58 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 0000
scheme: GPT
ID-1: / raw-size: 223.28 GiB size: 223.28 GiB (100.00%)
used: 19.08 GiB (8.5%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 572 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
ID-3: /home raw-size: 223.28 GiB size: 223.28 GiB (100.00%)
ID-4: /var/log raw-size: 223.28 GiB size: 223.28 GiB (100.00%)
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swap/swapfile
System Temperatures: cpu: 45.0 C pch: 42.0 C mobo: 42.0 C sodimm: SODIMM C
gpu: amdgpu temp: 45.0 C
Fan Speeds (RPM): cpu: 2770
Processes: 321 Uptime: 24m wakeups: 3 Memory: 15.53 GiB
used: 3.9 GiB (25.1%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1360 lib: 371 flatpak: 0 Shell: Zsh v: 5.8
running-in: konsole inxi: 3.3.11
Any advice is welcomed, thank you in advance
