Microphone on headphones doesn't work Acer Aspire E5-571G
Hello, i have a trouble with microphone on my headphones (they’re wired). Driver (snd-hda-intel) just doesn’t see it. Logs:
pacmd list-sources:
❯ pacmd list-sources
2 source(s) available.
    index: 0
	driver: <module-alsa-card.c>
	flags: DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
	state: SUSPENDED
	suspend cause: IDLE
	priority: 1030
	volume: front-left: 65536 / 100% / 0.00 dB,   front-right: 65536 / 100% / 0.00 dB
	        balance 0.00
	base volume: 65536 / 100% / 0.00 dB
	volume steps: 65537
	muted: no
	current latency: 0.00 ms
	max rewind: 0 KiB
	sample spec: s16le 2ch 44100Hz
	channel map: front-left,front-right
	             Stereo
	used by: 0
	linked by: 0
	configured latency: 0.00 ms; range is 0.50 .. 2000.00 ms
	monitor_of: 0
	card: 1 <alsa_card.pci-0000_00_1b.0>
	module: 7
	properties:
		device.description = "Monitor of Built-in Audio Analog Stereo"
		device.class = "monitor"
		alsa.card = "1"
		alsa.long_card_name = "HDA Intel PCH at 0xb3614000 irq 50"
		device.bus_path = "pci-0000:00:1b.0"
		sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card1"
		device.bus = "pci"
		device.vendor.id = "8086"
		device.product.id = "9c20"
		device.product.name = "8 Series HD Audio Controller"
		device.string = "1"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card-pci"
  * index: 1
	flags: HARDWARE HW_MUTE_CTRL HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY DYNAMIC_LATENCY
	state: SUSPENDED
	suspend cause: IDLE
	priority: 9039
	volume: front-left: 9628 /  15% / -49.98 dB,   front-right: 9628 /  15% / -49.98 dB
	        balance 0.00
	base volume: 5206 /   8% / -66.00 dB
	volume steps: 65537
	muted: no
	max rewind: 0 KiB
	             Stereo
	used by: 0
	linked by: 0
	module: 7
	properties:
		alsa.resolution_bits = "16"
		device.api = "alsa"
		device.class = "sound"
		alsa.class = "generic"
		alsa.subclass = "generic-mix"
		alsa.name = "ALC283 Analog"
		alsa.id = "ALC283 Analog"
		alsa.subdevice = "0"
		alsa.subdevice_name = "subdevice #0"
		alsa.device = "0"
		alsa.card = "1"
		device.bus = "pci"
		device.string = "front:1"
		device.buffering.buffer_size = "352800"
		device.buffering.fragment_size = "176400"
		device.access_mode = "mmap+timer"
		device.profile.name = "analog-stereo"
		device.profile.description = "Analog Stereo"
		device.description = "Built-in Audio Analog Stereo"
	ports:
		analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: unknown)
			properties:
	active port: <analog-input-mic>
arecord --list-devices :
❯ arecord --list-devices
**** List of CAPTURE Hardware Devices ****
card 1: PCH [HDA Intel PCH], device 0: ALC283 Analog [ALC283 Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
I found that help(dot)ubuntu(dot)com/community/HdaIntelSoundHowto and that list www(dot)kernel(dot)org/doc/html/latest/sound/hd-audio/models.html#alc22x-23x-25x-269-27x-28x-29x-and-vendor-specific-alc3xxx-models
My audio card:
❯ cat /proc/asound/card1/codec* | grep Codec
Codec: Realtek ALC283
So I wrote in /etc/modprobe.d/alsa-base.conf:
options snd-hda-intel mode=aspire-headset-mic
But after that in dmesg I see:
❯ sudo dmesg | grep -i snd_hda_intel
[   15.096570] snd_hda_intel: unknown parameter 'mode' ignored
[   16.230835] snd_hda_intel 0000:00:03.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
Which means that my driver just ignore any mode, I think. There isn’t parameter mode in /sys/module/snd_hda_intel/parameters/:
❯ ls /sys/module/snd_hda_intel/parameters
align_buffer_size  beep_mode    enable      id     jackpoll_ms  patch         position_fix  power_save_controller  probe_only  snoop
bdl_pos_adj        dmic_detect  enable_msi  index  model        pm_blacklist  power_save    probe_mask             single_cmd
Is it bug or my hardware isn’t supported or what?
P.S. I tested my setup on Windows and it works fine
