After a week of looking through forums trying to fix my mic not sending any sound to apps, I decided to just reinstall manjaro and do things one-by-one to see what breaks it. And I found it almost immediately, since I had annoying popping sound when starting/stopping audio playback I followed the Advanced_Linux_Sound_Architecture guide from archwiki(sorry, I can’t post links) and popping sound disappeared after a reboot. And my mic stopped working. It’s still recognized as valid source, seen as plugged in, but no apps are getting any voice and even when using arecord -f s16_le -d 5 -r 44100 test.wav to test it, arecord just hangs in there, frozen in time. I let it be like this for around 10 minutes and interrupted it, file it created was just an empty 1 second audio file. The moment I enable power_save and reboot, mic is working again.
The question is - what should I do in order to use my mic normally and not deal with the annoying pop sound?
post output from:
inxi -Fazy
inxi -Fazy ✔
Kernel: 5.15.41-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
parameters: BOOT_IMAGE=/vmlinuz-5.15-x86_64
root=UUID=f8562208-a99c-43fe-a231-253bae0a6f48 rw quiet
udev.log_priority=3
Desktop: KDE Plasma v: 5.24.5 tk: Qt v: 5.15.4 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: P5QD TURBO v: Rev 1.xx
serial: <superuser required> BIOS: American Megatrends v: 0301
date: 08/04/2009
Info: model: Intel Xeon X5460 bits: 64 type: MCP arch: Core Yorkfield
family: 6 model-id: 0x17 (23) stepping: 6 microcode: 0x60F
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 256 KiB
desc: d-4x32 KiB; i-4x32 KiB L2: 12 MiB desc: 2x6 MiB
Speed (MHz): avg: 3166 min/max: N/A cores: 1: 3166 2: 3166 3: 3166 4: 3166
bogomips: 25343
Flags: ht lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2 mitigation: Retpolines, STIBP: disabled, RSB filling
Device-1: NVIDIA GK107 [GeForce GTX 650] vendor: Micro-Star MSI
driver: nvidia v: 470.129.06 alternate: nouveau,nvidia_drm non-free: 470.xx+
status: legacy-active (EOL ~2023/24) arch: Kepler pcie: gen: 2
speed: 5 GT/s lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:0fc6 class-ID: 0300
Display: x11 server: X.Org v: 21.1.3 compositor: kwin_x11 driver: X:
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1280x1024 s-dpi: 95 s-size: 342x271mm (13.46x10.67")
s-diag: 436mm (17.18")
Monitor-1: VGA-0 res: 1280x1024 hz: 60 dpi: 96
size: 338x270mm (13.31x10.63") diag: 433mm (17.03") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 650/PCIe/SSE2
v: 4.6.0 NVIDIA 470.129.06 direct render: Yes
Device-1: Intel 82801JI HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3a3e class-ID: 0403
Device-2: NVIDIA GK107 HDMI Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16
bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
Sound Server-1: ALSA v: k5.15.41-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.51 running: yes
Device-1: Qualcomm Atheros AR8121/AR8113/AR8114 Gigabit or Fast Ethernet
vendor: ASUSTeK driver: ATL1E v: N/A modules: atl1e pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: dc00 bus-ID: 02:00.0 chip-ID: 1969:1026
class-ID: 0200
IF: enp2s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL-8100/8101L/8139 PCI Fast Ethernet Adapter
driver: 8139too v: 0.9.28 modules: 8139cp port: e800 bus-ID: 04:00.0
chip-ID: 10ec:8139 class-ID: 0200
IF: enp4s0 state: down mac: <filter>
Local Storage: total: 1.82 TiB used: 209.93 GiB (11.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10EADS-00M2B0
size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
type: N/A serial: <filter> rev: 0A01 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: HGST (Hitachi) model: HTS541010B7E610
size: 931.51 GiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 1A01 scheme: MBR
ID-1: / raw-size: 60 GiB size: 58.76 GiB (97.93%) used: 22 GiB (37.4%)
fs: ext4 dev: /dev/sda3 maj-min: 8:3
ID-2: /boot raw-size: 1024 MiB size: 973.4 MiB (95.06%)
used: 68.1 MiB (7.0%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 870.5 GiB size: 855.76 GiB (98.31%)
used: 187.86 GiB (22.0%) fs: ext4 dev: /dev/sda4 maj-min: 8:4
ID-1: swap-1 type: file size: 10 GiB used: 44.6 MiB (0.4%) priority: -2
file: /swapfile
System Temperatures: cpu: 46.5 C mobo: 26.0 C gpu: nvidia temp: 39 C
Fan Speeds (RPM): cpu: 2109 psu: 0 case-1: 0 case-2: 0 gpu: nvidia
fan: 40%
Power: 12v: 12.38 5v: N/A 3.3v: 3.34 vbat: N/A
Processes: 242 Uptime: 18h 54m wakeups: 1 Memory: 7.76 GiB
used: 2.98 GiB (38.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: 1136 pacman: 1102 lib: 304 flatpak: 34
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16
click this icon in editor and paste the output inside of it: </>
Posted it
What he meant, was:
To provide terminal output, copy the text you wish to share, and paste it here, surrounded by three (3) backticks, a.k.a grave accents. Like this:
pasted text
Portaest sed
elementum
cursus nisl nisi
hendrerit ac quis
sit
adipiscing
tortor sit leo commodo.
Instead of like this:
Portaest sed elementum cursus nisl nisi hendrerit ac quis sit adipiscing tortor sit leo commodo.
Thereby improving legibility and making it much easier for those trying to be of assistance.
Thanks, it’s done
install this:
sudo pacman -S sof-firmware
reboot and test
It was installed by default. Tried to delete it and then install it again before, didn’t help
install pipewire:
sudo pacman -Ru --nodeps pulseaudio pulseaudio-equalizer pulseaudio-jack pulseaudio-lirc pulseaudio-rtp pulseaudio-zeroconf pulseaudio-bluetooth pulseaudio-pa pulseaudio-alsa pulseaudio-ctl manjaro-pulse && sudo pacman -S manjaro-pipewire
reboot and test
Just tried uninstalling sof-firmware, reboot and test, then installing it again, reboot and test. Mic is still not working with arecord just hanging/freezing. Will try pipewire now
since these packages were not installed giving this error
error: target not found: pulseaudio-equalizer
error: target not found: pulseaudio-jack
error: target not found: pulseaudio-lirc
error: target not found: pulseaudio-rtp
error: target not found: pulseaudio-pa
I removed them from the command you gave me and run it. tt’s still the same result. mic is not working, arecord is frozen. Also all of this was done with power_save set to 0. And another thing, if I go into alsamixer>F6>hda intel>F3>turn rear mic volume to max, I can hear myself in all cases.
i meant that you test if you still have cracking sound from speakers if using pipewire, and if you dont, you can use your mic normally
Oh, I didn’t think of that, will try now
Nope, after commenting out power_save in modprobe, I still get pop sound every time I start any audio playback. Though it might have gotten a bit quieter than it was.
so did you installed wireplumber? if yes install instead pipewire-media-session, if you have pipewire media session instal wireplumber, reboot and test speakers…
Installed wireplumber instead of pipewire-media-session, the pop sound is still there
Just read a post on stackexchange about a similar issue with fix being disabling/unloading module -suspend-on-idle in pulseaudio. I will try this right now
so instal back pulse with:
sudo pacman -S manjaro-pulse
it will remove pipewire, then reboot
navigate to: /etc/pulse/default.pa
and edit this line:
load-module module-udev-detect
to look like this:
load-module module-udev-detect tsched=0
then reboot and test speakers again
Unloading module suspend-on-idle didn’t work, same with adding tsched=0, pop sound is still there
