Microphone not reading input
Hi, hope everyone is doing good.
I am a manjaro user for a long time and lately i need to use a microphone for work, so i plug in the microphone, it does get detected by the system (i saw it in the pulseAudio Volume) however when i test the microphone by recording my audio, no audio get’s recorded (the audio does get recorded when i record without any mic plugged in)
I ran the following command (whilst the mic is plugged in):
pactl list cards; pacmd dump | grep -E 'source|profile'
and got the following output:
Card #0
	Driver: module-alsa-card.c
	Owner Module: 6
	Properties:
		alsa.card = "0"
		alsa.long_card_name = "HDA Intel PCH at 0xc3610000 irq 32"
		device.bus_path = "pci-0000:00:1b.0"
		sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card0"
		device.bus = "pci"
		device.vendor.id = "8086"
		device.product.id = "1e20"
		device.product.name = "7 Series/C216 Chipset Family High Definition Audio Controller"
		device.string = "0"
		device.description = "Built-in Audio"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card-pci"
	Profiles:
		input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 32833, available: yes)
		output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 39268, available: yes)
		output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 39333, available: yes)
		output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: no)
		output:hdmi-stereo+input:analog-stereo: Digital Stereo (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 5965, available: yes)
		output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
		output:hdmi-surround+input:analog-stereo: Digital Surround 5.1 (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 865, available: yes)
		output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (sinks: 1, sources: 0, priority: 800, available: no)
		output:hdmi-surround71+input:analog-stereo: Digital Surround 7.1 (HDMI) Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 865, available: yes)
		off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
	Active Profile: output:analog-stereo+input:analog-stereo
	Ports:
		analog-input-internal-mic: Internal Microphone (type: Mic, priority: 8900, latency offset: 0 usec, not available)
			Properties:
			Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-surround+input:analog-stereo, output:hdmi-surround71+input:analog-stereo
		analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, available)
			Properties:
		analog-output-speaker: Speakers (type: Speaker, priority: 10000, latency offset: 0 usec, availability unknown)
			Properties:
			Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo
		analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, not available)
			Properties:
		hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, not available)
			Properties:
			Part of profile(s): output:hdmi-stereo, output:hdmi-stereo+input:analog-stereo, output:hdmi-surround, output:hdmi-surround+input:analog-stereo, output:hdmi-surround71, output:hdmi-surround71+input:analog-stereo
set-source-volume alsa_output.pci-0000_00_1b.0.analog-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_00_1b.0.analog-stereo.monitor no
suspend-source alsa_output.pci-0000_00_1b.0.analog-stereo.monitor yes
set-source-volume alsa_input.pci-0000_00_1b.0.analog-stereo 0x10000
set-source-mute alsa_input.pci-0000_00_1b.0.analog-stereo no
suspend-source alsa_input.pci-0000_00_1b.0.analog-stereo yes
set-card-profile alsa_card.pci-0000_00_1b.0 output:analog-stereo+input:analog-stereo
set-default-source alsa_input.pci-0000_00_1b.0.analog-stereo
the following line specifically is what’s interesting (it’s saying not available):
here is what inxi command gave out:
  Kernel: 6.1.90-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=520478a3-c3f3-49cc-9923-0722bf32d899 rw quiet splash apparmor=1
    security=apparmor resume=UUID=9e7db7a1-b2ad-497f-84f6-d5d563009337
    udev.log_priority=3
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: Hewlett-Packard product: HP Pavilion g7 Notebook PC
    v: 088A120000305910000620100 serial: <superuser required> Chassis: type: 10
  Mobo: Hewlett-Packard model: 1842 v: 56.32 serial: <superuser required>
    part-nu: D5A18EA#ABF uuid: <superuser required> UEFI-[Legacy]: Insyde
    v: F.25 date: 05/29/2013
  ID-1: BAT0 charge: 15.9 Wh (100.0%) condition: 15.9/15.9 Wh (100.0%)
    volts: 12.3 min: 10.8 model: Hewlett-Packard Primary type: Li-ion
    serial: N/A status: full
  System RAM: total: 8 GiB available: 7.66 GiB used: 2.46 GiB (32.1%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: Bottom-Slot 1(top) type: DDR3 detail: synchronous size: 4 GiB
    speed: 1333 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Hynix part-no: HMT351S6CFR8C-H9 serial: <filter>
  Device-2: Bottom-Slot 2(under) type: DDR3 detail: synchronous size: 4 GiB
    manufacturer: Hynix part-no: HMT351S6EFR8A-PB serial: <filter>
  Info: model: Intel Core i3-3120M bits: 64 type: MT MCP arch: Ivy Bridge
    gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
    model-id: 0x3A (58) stepping: 9 microcode: 0x21
    L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 1906 high: 2199 min/max: 1200/2500 scaling:
    driver: intel_cpufreq governor: schedutil cores: 1: 1909 2: 2107 3: 1412
    4: 2199 bogomips: 19961
  Flags: acpi aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
    erms est f16c flush_l1d fpu fsgsbase fxsr ht ibpb ibrs lahf_lm lm mca mce
    md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
    pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdtscp rep_good
    sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tsc
    tsc_deadline_timer vme x2apic xsave xsaveopt xtopology xtpr
  Type: itlb_multihit status: KVM: VMX unsupported
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Intel 3rd Gen Core processor Graphics vendor: Hewlett-Packard
    driver: i915 v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
    active: LVDS-1,VGA-1 empty: DP-1,HDMI-A-1 bus-ID: 00:02.0
    chip-ID: 8086:0166 class-ID: 0300
  Device-2: AMD Thames [Radeon HD 7500M/7600M Series]
    vendor: Hewlett-Packard driver: radeon v: kernel alternate: amdgpu
    arch: TeraScale-2 code: Evergreen process: TSMC 32-40nm built: 2009-15
    pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 2 speed: 5 GT/s
    lanes: 16 bus-ID: 01:00.0 chip-ID: 1002:6840 class-ID: 0300 temp: 41.0 C
  Device-3: Chicony HP Truevision HD driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-1.5:3 chip-ID: 04f2:b34f
  Display: x11 server: X.Org v: 21.1.13 compositor: xfwm4 v: 4.18.0 driver:
    X: loaded: modesetting unloaded: radeon alternate: fbdev,vesa
    dri: crocus,r600 gpu: i915 display-ID: :0.0 screens: 1
  Screen-1: 0 s-res: 2966x900 s-dpi: 96 s-size: 784x238mm (30.87x9.37")
    s-diag: 819mm (32.26")
  Monitor-1: LVDS-1 pos: primary,left model: Seiko Epson 0x3454 built: 2011
    res: 1600x900 hz: 60 dpi: 106 gamma: 1.2 chroma: red: x: 0.616 y: 0.361
    green: x: 0.349 y: 0.624 blue: x: 0.145 y: 0.075 white: x: 0.314 y: 0.329
    size: 382x215mm (15.04x8.46") diag: 438mm (17.3") ratio: 16:9
    modes: 1600x900
  Monitor-2: VGA-1 pos: right model: Samsung S19C150 serial: <filter>
    built: 2013 res: 1366x768 hz: 60 dpi: 85 gamma: 1.2 chroma: red: x: 0.635
    y: 0.349 green: x: 0.333 y: 0.608 blue: x: 0.145 y: 0.059 white: x: 0.314
    y: 0.329 size: 410x230mm (16.14x9.06") diag: 470mm (18.5") ratio: 16:9
    modes: 1366x768, 1280x720, 1024x768, 832x624, 800x600, 640x480, 720x400
  API: OpenGL Message: Unable to show GL data. glxinfo is missing.
  Device-1: Intel 7 Series/C216 Family High Definition Audio
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:1e20 class-ID: 0403
  API: ALSA v: k6.1.90-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.5 status: off with: wireplumber status: off
    tools: pw-cat,pw-cli,wpctl
  Server-3: PulseAudio v: 17.0 status: active with: pulseaudio-alsa
    type: plugin tools: pacat,pactl,pavucontrol
  Device-1: Ralink RT5390R 802.11bgn PCIe Wireless Network Adapter
    vendor: Hewlett-Packard driver: rt2800pci v: 2.3.0 modules: wl pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 1814:539b class-ID: 0280
  IF: wlo1 state: down mac: <filter>
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet
    vendor: Hewlett-Packard driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 08:00.0 chip-ID: 10ec:8136 class-ID: 0200
  Info: services: httpd, mld, NetworkManager, systemd-timesyncd,
    wpa_supplicant
  Local Storage: total: 119.24 GiB used: 95.59 GiB (80.2%)
  ID-1: /dev/sda maj-min: 8:0 model: SSD 128GB size: 119.24 GiB block-size:
    physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter>
    fw-rev: 842 scheme: MBR
  Optical-1: /dev/sr0 vendor: hp model: DVD A DS8A9SH rev: EH61
    dev-links: cdrom
  ID-1: / raw-size: 110.44 GiB size: 108.15 GiB (97.92%)
    used: 95.59 GiB (88.4%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 520478a3-c3f3-49cc-9923-0722bf32d899
    dev: /dev/sda2 maj-min: 8:2 label: swap
    uuid: 9e7db7a1-b2ad-497f-84f6-d5d563009337
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
  Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
  Device-1: 2-1.5:3 info: Chicony HP Truevision HD type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b34f class-ID: 0e02
    serial: <filter>
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 3-2:2 info: Silicon Labs USB OPTICAL MOUSE type: mouse
    chip-ID: 10c4:8108 class-ID: 0301
  Hub-6: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 59.0 C mobo: N/A gpu: radeon temp: 41.0 C
  Fan Speeds (rpm): N/A
  Packages: 1333 pm: dpkg pkgs: 0 pm: pacman pkgs: 1311 libs: 440
    tools: pamac,yay pm: flatpak pkgs: 8 pm: snap pkgs: 14
    1: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    2: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    3: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    4: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    5: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    6: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    7: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    8: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    9: http://free.nchc.org.tw/manjaro/stable/$repo/$arch
    10: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    11: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    12: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    13: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    14: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    15: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    16: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    17: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    18: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    19: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    20: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    21: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    22: https://mirrors2.manjaro.org/stable/$repo/$arch
    23: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    24: https://mirror.erickochen.nl/manjaro/stable/$repo/$arch
    25: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    26: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    27: https://manjaro.kurdy.org/stable/$repo/$arch
    28: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    29: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    30: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    31: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    32: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    33: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    34: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    35: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    36: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    37: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    38: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    39: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    40: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    41: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    42: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    43: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    44: https://mirror.23m.com/manjaro/stable/$repo/$arch
    45: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    46: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    47: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    48: https://mirror.init7.net/manjaro/stable/$repo/$arch
    49: http://manjaro.mirrors.theom.nz/manjaro/stable/$repo/$arch
    50: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    51: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    52: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
    53: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    54: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    55: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    56: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    57: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    58: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    59: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    60: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    61: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    62: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    63: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    64: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    65: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    66: https://manjaro.ynh.ovh/stable/$repo/$arch
    67: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    68: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 220
  1: cpu: 20.3% command: chrome pid: 2835 mem: 205.4 MiB (2.6%)
  2: cpu: 15.8% command: chrome pid: 2825 mem: 186.7 MiB (2.3%)
  3: cpu: 14.0% command: chrome pid: 2371 mem: 200.9 MiB (2.5%)
  4: cpu: 10.4% command: chrome pid: 2010 mem: 340.4 MiB (4.3%)
  5: cpu: 7.7% command: Xorg pid: 1013 mem: 80.6 MiB (1.0%)
  Memory top: 5 of 220
  1: mem: 340.4 MiB (4.3%) command: chrome pid: 2010 cpu: 10.4%
  2: mem: 205.4 MiB (2.6%) command: chrome pid: 2835 cpu: 20.3%
  3: mem: 200.9 MiB (2.5%) command: chrome pid: 2371 cpu: 14.0%
  4: mem: 189.3 MiB (2.4%) command: chrome pid: 2226 cpu: 2.1%
  5: mem: 186.7 MiB (2.3%) command: chrome pid: 2825 cpu: 15.8%
  Processes: 220 Power: uptime: 13m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.05 GiB services: upowerd,xfce4-power-manager
    Init: systemd v: 255 default: graphical tool: systemctl
  Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: Bash v: 5.2.26
    running-in: xfce4-terminal inxi: 3.3.34
any help is welcomed, thank you
How? What?
Looks to me that you have 2 microphones:
There you have to set one to default. So the “Port”.
Another thing: What kind of jack connection is it? Headset or microphone symbol?
This ? grafik
If a headset, then a mic will not work on that port.
