Hi there,
I´ve got a really strange issue here: My microphone and headphones are both connected to my USB audio interface. My headphones are working fine, but microphone isn’t even detected in the settings as an input device. I don’t use my microphone super often in Linux, but I know that this configuration worked fine back in December. I also tested another microphone connected directly to my PC. That one worked fine. I´ve seen some other posts that asked for the output of pacmd list-cards, so I`m leaving that down below, but I don’t really know what to do with it.
Thanks for any help
johjoh
index: 0
driver: <module-alsa-card.c>
owner module: 6
properties:
alsa.card = "1"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0xf7080000 irq 60"
device.bus_path = "pci-0000:23:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:03.1/0000:23:00.1/sound/card1"
device.bus = "pci"
device.vendor.id = "10de"
device.vendor.name = "NVIDIA Corporation"
device.product.id = "228b"
device.string = "1"
device.description = "HDA NVidia"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 5900, available: no)
output:hdmi-surround: Digital Surround 5.1 (HDMI) Output (priority 800, available: no)
output:hdmi-surround71: Digital Surround 7.1 (HDMI) Output (priority 800, available: no)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: unknown)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (priority 5700, available: no)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (priority 600, available: no)
output:hdmi-stereo-extra5: Digital Stereo (HDMI 6) Output (priority 5700, available: no)
output:hdmi-surround-extra5: Digital Surround 5.1 (HDMI 6) Output (priority 600, available: no)
output:hdmi-surround71-extra5: Digital Surround 7.1 (HDMI 6) Output (priority 600, available: no)
output:hdmi-stereo-extra6: Digital Stereo (HDMI 7) Output (priority 5700, available: no)
output:hdmi-surround-extra6: Digital Surround 5.1 (HDMI 7) Output (priority 600, available: no)
output:hdmi-surround71-extra6: Digital Surround 7.1 (HDMI 7) Output (priority 600, available: no)
off: Off (priority 0, available: unknown)
active profile: <output:hdmi-stereo-extra1>
sinks:
alsa_output.pci-0000_23_00.1.hdmi-stereo-extra1/#0: HDA NVidia Digital Stereo (HDMI 2)
sources:
alsa_output.pci-0000_23_00.1.hdmi-stereo-extra1.monitor/#0: Monitor of HDA NVidia Digital Stereo (HDMI 2)
ports:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
properties:
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: yes)
properties:
device.product.name = "VX2758-Series"
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
properties:
hdmi-output-4: HDMI / DisplayPort 5 (priority 5500, latency offset 0 usec, available: no)
properties:
hdmi-output-5: HDMI / DisplayPort 6 (priority 5400, latency offset 0 usec, available: no)
properties:
hdmi-output-6: HDMI / DisplayPort 7 (priority 5300, latency offset 0 usec, available: no)
properties:
index: 1
owner module: 7
properties:
alsa.card = "0"
alsa.card_name = "USB Audio CODEC"
alsa.long_card_name = "Burr-Brown from TI USB Audio CODEC at usb-0000:24:00.3-3, full speed"
alsa.driver_name = "snd_usb_audio"
device.bus_path = "pci-0000:24:00.3-usb-0:3:1.0"
sysfs.path = "/devices/pci0000:00/0000:00:07.1/0000:24:00.3/usb3/3-3/3-3:1.0/sound/card0"
udev.id = "usb-Burr-Brown_from_TI_USB_Audio_CODEC-00"
device.bus = "usb"
device.vendor.id = "08bb"
device.vendor.name = "Texas Instruments"
device.product.id = "2902"
device.product.name = "PCM2902 Audio Codec"
device.serial = "Burr-Brown_from_TI_USB_Audio_CODEC"
device.string = "0"
device.description = "PCM2902 Audio Codec"
device.icon_name = "audio-card-usb"
profiles:
input:analog-stereo-input: Analog Stereo Input (priority 54, available: unknown)
input:analog-mono: Analog Mono Input (priority 33, available: unknown)
input:analog-mono-left: Analog Mono (Left) Input (priority 32, available: unknown)
input:analog-mono-right: Analog Mono (Right) Input (priority 31, available: unknown)
output:analog-stereo-output: Analog Stereo Output (priority 5000, available: unknown)
output:analog-stereo-output+input:analog-stereo-input: Analog Stereo Output + Analog Stereo Input (priority 5054, available: unknown)
output:analog-stereo-output+input:analog-mono: Analog Stereo Output + Analog Mono Input (priority 5033, available: unknown)
output:analog-stereo-output+input:analog-mono-left: Analog Stereo Output + Analog Mono (Left) Input (priority 5032, available: unknown)
output:analog-stereo-output+input:analog-mono-right: Analog Stereo Output + Analog Mono (Right) Input (priority 5031, available: unknown)
active profile: <output:analog-stereo-output+input:analog-stereo-input>
sinks:
alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo-output/#1: PCM2902 Audio Codec Analog Stereo
sources:
alsa_output.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo-output.monitor/#1: Monitor of PCM2902 Audio Codec Analog Stereo
alsa_input.usb-Burr-Brown_from_TI_USB_Audio_CODEC-00.analog-stereo-input/#2: PCM2902 Audio Codec Analog Stereo
ports:
analog-output: Analog Output (priority 9900, latency offset 0 usec, available: unknown)
properties:
index: 2
owner module: 8
properties:
alsa.card = "2"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xf7700000 irq 62"
device.bus_path = "pci-0000:25:00.3"
sysfs.path = "/devices/pci0000:00/0000:00:08.1/0000:25:00.3/sound/card2"
device.bus = "pci"
device.vendor.id = "1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "1457"
device.product.name = "Family 17h (Models 00h-0fh) HD Audio Controller"
device.string = "2"
device.description = "Family 17h (Models 00h-0fh) HD Audio Controller"
profiles:
input:analog-stereo: Analog Stereo Input (priority 65, available: no)
output:analog-stereo: Analog Stereo Output (priority 6500, available: no)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 6565, available: no)
active profile: <off>
ports:
analog-input-front-mic: Front Microphone (priority 8500, latency offset 0 usec, available: no)
properties:
analog-input-rear-mic: Rear Microphone (priority 8200, latency offset 0 usec, available: no)
properties:
analog-input-linein: Line In (priority 8100, latency offset 0 usec, available: no)
properties:
analog-output-lineout: Line Out (priority 9000, latency offset 0 usec, available: no)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
device.icon_name = "audio-headphones" ```
