Hey everyone,
After using my internal laptop mic I decided to get a cool attachable mic for my headphones which connects via 3.5mm input. However, input settings only show “Internal Microphone” Or “Microphone (unplugged)”. Testing “Internal Microphone” in discord confirmed to me that this indeed was the internal microphone. After some research I tried the solution in mic-from-jack-not-working/111444 that stated to install pipewire with sudo pacman -Ru --nodeps pulseaudio pulseaudio-equalizer pulseaudio-jack pulseaudio-lirc pulseaudio-rtp pulseaudio-zeroconf pulseaudio-bluetooth pulseaudio-pa pulseaudio-alsa pulseaudio-ctl manjaro-pulse && sudo pacman -S manjaro-pipewire
. However, no change. I then tried the first proposed solution by reinstalling manjaro-pulse
and now I don’t have any sound . Interestingly enough,
speaker-test
does work in my headphones. However, trying to use the headphone tester in System Settings shows this:
Error trying to play a test sound.
The system said: “Invalid state”
pacmd list-cards shows:
index: 0
driver: <module-alsa-card.c>
owner module: 6
properties:
alsa.card = "1"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0xbc080000 irq 17"
device.bus_path = "pci-0000:01:00.1"
sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1"
device.bus = "pci"
device.vendor.id = "10de"
device.vendor.name = "NVIDIA Corporation"
device.product.id = "1aeb"
device.product.name = "TU116 High Definition Audio Controller"
device.string = "1"
device.description = "TU116 High Definition Audio Controller"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
output:hdmi-stereo: Digital Stereo (HDMI) Output (priority 38668, available: unknown)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (priority 5700, available: no)
output:hdmi-surround-extra1: Digital Surround 5.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-surround71-extra1: Digital Surround 7.1 (HDMI 2) Output (priority 600, available: no)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (priority 5700, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (priority 600, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (priority 5700, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (priority 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (priority 600, available: no)
off: Off (priority 0, available: unknown)
active profile: <output:hdmi-stereo>
sinks:
alsa_output.pci-0000_01_00.1.hdmi-stereo/#0: TU116 High Definition Audio Controller Digital Stereo (HDMI)
sources:
alsa_output.pci-0000_01_00.1.hdmi-stereo.monitor/#0: Monitor of TU116 High Definition Audio Controller Digital Stereo (HDMI)
ports:
hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: yes)
properties:
device.product.name = "XB241YU
hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
properties:
hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: no)
properties:
hdmi-output-3: HDMI / DisplayPort 4 (priority 5600, latency offset 0 usec, available: no)
properties:
index: 1
owner module: 7
properties:
alsa.card = "0"
alsa.long_card_name = "HDA Intel PCH at 0xba210000 irq 165"
sysfs.path = "/devices/pci0000:00/0000:00:1f.3/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "a348"
device.product.name = "Cannon Lake PCH cAVS"
device.string = "0"
device.description = "Built-in Audio"
profiles:
input:analog-stereo: Analog Stereo Input (priority 32833, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 39268, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 39333, available: unknown)
active profile: <output:analog-stereo+input:analog-stereo>
sinks:
alsa_output.pci-0000_00_1f.3.analog-stereo/#1: Built-in Audio Analog Stereo
sources:
alsa_output.pci-0000_00_1f.3.analog-stereo.monitor/#1: Monitor of Built-in Audio Analog Stereo
alsa_input.pci-0000_00_1f.3.analog-stereo/#2: Built-in Audio Analog Stereo
ports:
analog-input-internal-mic: Internal Microphone (priority 8900, latency offset 0 usec, available: unknown)
properties:
analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: no)
properties:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: no)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: yes)
properties:
device.icon_name = "audio-headphones"```.
Thanks!
