I have recently read the article: How to make linux sound great and was convinced to go ahead and make the switch to pipewire, once I did this I got some problems. headphones would not connect to bluetooth, then it would connect and disconnect after 1-2 seconds. I worked through a lot of articles threads on the forum and the arch wiki at the end I was able to find a fix through claude by doing 2 things:
- making a bluetooth configuration in
~/.config/wireplumber/bluetooth.lua.d/50-bluez-config.lua
and adding the following
bluez_monitor.properties = {
["bluez5.enable-sbc-xq"] = true,
["bluez5.enable-msbc"] = true,
["bluez5.enable-hw-volume"] = true,
["bluez5.headset-roles"] = "[ hsp_hs hsp_ag hfp_hf hfp_ag ]"
- Typing this command after each boot
sudo systemctl restart bluetooth
There was also another issue with the latency when pressing on volume +/- on the headset, Claude mentioned that this was a common issue in pipewire.
The last issue that made me want to switch back was that I wasn’t getting the full audio from videos, it seems that some audio channels weren’t getting through?
I then decided to switch back to pulseaudio however that was a nightmare because I had already removed all the dependencies and everything related to pulseaudio as well as jack, I replaced all of them with pipewire.
I removed manjaro-pipewire
and replaced it with manjaro-pulse
. I also got jack2
installed again since I had replaced it with pipewire-jack
. I made sure that there were no pipewire libraries afterward and deleted all configs for pipewire and wireplumber.
I ended up having to install the libpipewire & pipewire packages without the other packages because a camera package needed them?
The microphone is not detected on vivaldi and I am getting multiple microphone profiles, I noticed the multiple profiles when I switched to pipewire. Initially It was only one microphone profile and I could choose the input device whether the headset or the laptop’s.
System Information:
yamo: ~ > inxi -zv8 <master*> 17:48
Kernel: 6.15.3-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.1.1
clocksource: hpet avail: acpi_pm
parameters: BOOT_IMAGE=/boot/vmlinuz-6.15-x86_64
root=UUID=b395b351-d6f7-40f1-88ff-43ee89d7e608 rw quiet acpi_osi=off
apparmor=1 security=apparmor udev.log_priority=3 acpi_backlight=native
nowatchdog
Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.15.0
Type: Laptop System: LENOVO product: 82B5 v: Lenovo Legion 5 15ARH05
serial: <superuser required> Chassis: type: 10 v: Lenovo Legion 5 15ARH05
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> part-nu: LENOVO_MT_82B5_BU_idea_FM_Legion 5
15ARH05 uuid: <superuser required> UEFI: LENOVO v: EUCN41WW
date: 09/20/2023
ID-1: BAT0 charge: 26.4 Wh (58.9%) condition: 44.8/60.0 Wh (74.7%)
volts: 15.8 min: 15.4 model: SMP L19M4PC0 type: Li-poly serial: <filter>
status: not charging cycles: 1264
System RAM: total: 16 GiB available: 14.99 GiB used: 10.75 GiB (71.7%)
(unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Kingston
part-no: LV32D4S2S8HD-8 serial: <filter>
min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: Samsung
part-no: M471A1G44AB0-CWE serial: <filter>
Info: model: AMD Ryzen 5 4600H with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 gen: 2 level: v3 note: check built: 2020-22
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x860010D
desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1242 min/max: 1400/3000 boost: enabled scaling:
driver: acpi-cpufreq governor: ondemand cores: 1: 1242 2: 1242 3: 1242
4: 1242 5: 1242 6: 1242 7: 1242 8: 1242 9: 1242 10: 1242 11: 1242 12: 1242
bogomips: 71868
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibrs
ibs irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pni popcnt pse pse36 rapl rdpid
rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca
smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock
syscall tce topoext tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif
vmcb_clean vme vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr
xsaveopt xtopology
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
Device-1: NVIDIA TU117M [GeForce GTX 1650 Ti Mobile] vendor: Lenovo
driver: nvidia v: 575.64 alternate: nouveau,nova_core,nvidia_drm
non-free: 550-570.xx+ status: current (as of 2025-04; EOL~2026-12-xx)
arch: Turing code: TUxxx process: TSMC 12nm FF built: 2018-2022 pcie:
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none empty: DP-1,HDMI-A-1,eDP-2 bus-ID: 01:00.0
chip-ID: 10de:1f95 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Renoir [Radeon Vega Series /
Radeon Mobile Series] vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: eDP-1 empty: none bus-ID: 05:00.0
chip-ID: 1002:1636 class-ID: 0300 temp: 40.0 C
Device-3: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2 chip-ID: 5986:212b
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
compositor: kwin_x11 driver: X: loaded: amdgpu,nvidia
unloaded: modesetting,nouveau alternate: fbdev,nv,vesa dri: radeonsi
gpu: amdgpu display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0xd1ed built: 2019 res:
mode: 1920x1080 hz: 120 scale: 100% (1) dpi: 142 gamma: 1.2 chroma: red:
x: 0.561 y: 0.341 green: x: 0.349 y: 0.573 blue: x: 0.161 y: 0.118 white:
x: 0.314 y: 0.329 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080, 1680x1050, 1280x1024, 1440x900, 1280x800,
1280x720, 1024x768, 800x600, 640x480
API: EGL v: 1.5 hw: drv: nvidia drv: amd radeonsi platforms: device: 0
drv: nvidia device: 2 drv: radeonsi device: 3 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia x11: drv: radeonsi inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: amd mesa v: 25.1.4-arch1.1
renoir ACO DRM 3.63 6.15.3-1-MANJARO) device-ID: 1002:1636 memory: 500 MiB
unified: no
API: Vulkan v: 1.4.313 layers: 6 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1650 Ti driver: nvidia v: 575.64 device-ID: 10de:1f95
surfaces: N/A device: 1 type: integrated-gpu name: AMD Radeon Graphics
(RADV RENOIR) driver: mesa radv v: 25.1.4-arch1.1 device-ID: 1002:1636
surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
x11: xdpyinfo, xprop, xrandr
Device-1: NVIDIA driver: snd_hda_intel v: kernel alternate: nova_core pcie:
gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
Device-2: Advanced Micro Devices [AMD] Audio Coprocessor vendor: Lenovo
driver: N/A alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x,
snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh,
snd_sof_amd_acp63, snd_sof_amd_acp70 pcie: gen: 4 speed: 16 GT/s lanes: 16
bus-ID: 05:00.5 chip-ID: 1022:15e2 class-ID: 0480
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: 05:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.15.3-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.5 status: off tools: pw-cli
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active with:
tools: pacat,pactl,pavucontrol,pulsemixer
vendor: Lenovo driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: 2000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp4s0 state: up mac: <filter>
IF-ID-1: vmnet1 state: unknown speed: N/A duplex: N/A mac: <filter>
IP v6: <filter> virtual: proto kernel_ll scope: link
IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Info: services: NetworkManager, systemd-networkd, systemd-timesyncd,
wpa_supplicant
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3:3 chip-ID: 8087:0029
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 4 state: up address: N/A
Local Storage: total: 1.14 TiB used: 719.11 GiB (61.5%)
model: MZVLB256HBHQ-000L2 size: 238.47 GiB block-size: physical: 512 B
fw-rev: 3L1QEXH7 temp: 41.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Western Digital model: WD10SPSX-08A6W
tech: HDD rpm: 7200 serial: <filter> fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 51.29 GiB size: 50.31 GiB (98.08%) used: 46.71 GiB (92.8%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: b395b351-d6f7-40f1-88ff-43ee89d7e608
used: 52.6 MiB (54.8%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
label: N/A uuid: 0C75-E2CB
ID-3: /home raw-size: 68.07 GiB size: 66.45 GiB (97.62%)
used: 60.68 GiB (91.3%) fs: ext4 dev: /dev/nvme0n1p7 maj-min: 259:7
label: N/A uuid: 8688e415-56b2-481d-827b-210e7dfd1197
ID-4: /run/media/yamo/9640794240792A5F raw-size: 97.64 GiB
size: 97.64 GiB (100.00%) used: 39.45 GiB (40.4%) fs: ntfs
dev: /dev/nvme0n1p3 maj-min: 259:3 label: N/A uuid: 4C924D4C924D3BA8
ID-5: /run/media/yamo/EDU raw-size: 292.97 GiB size: 292.97 GiB (100.00%)
used: 187.27 GiB (63.9%) fs: ntfs dev: /dev/sda3 maj-min: 8:3 label: EDU
uuid: 366C4A282D6F052F
ID-6: /run/media/yamo/Main raw-size: 638.53 GiB size: 638.53 GiB (100.00%)
used: 384.93 GiB (60.3%) fs: ntfs dev: /dev/sda2 maj-min: 8:2 label: Main
uuid: 3AEC09DCEC099375
ID-1: swap-1 type: partition size: 20.48 GiB used: 22.2 MiB (0.1%)
priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6 label: N/A
uuid: ae9bb7f8-1320-4d92-9e21-1ebd6e555f8a
ID-1: /dev/nvme0n1p2 maj-min: 259:2 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 897 MiB fs: ntfs label: N/A
uuid: 06C01B4FC01B43F9
ID-3: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
Device-1: 1-3:2 info: Bison Integrated Camera type: video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
power: 500mA chip-ID: 5986:212b class-ID: 0e02
Hub-4: 3-1:2 info: Genesys Logic Hub ports: 2 rev: 2.1
Device-1: 3-1.1:4 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
type: mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
chip-ID: 1bcf:08a0 class-ID: 0301
Device-2: 3-3:3 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Device-3: 3-4:5 info: Integrated Express ITE Device(8910) type: keyboard
lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:c100 class-ID: 0301
Hub-5: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
Hub-6: 4-1:2 info: Genesys Logic GL3523 Hub ports: 2 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 05e3:0620
System Temperatures: cpu: 44.9 C mobo: N/A gpu: amdgpu temp: 39.0 C
Fan Speeds (rpm): N/A
Packages: 2206 pm: dpkg pkgs: 0 pm: pacman pkgs: 2178 libs: 515
tools: pamac,yay pm: flatpak pkgs: 13 pm: snap pkgs: 15
1: http://manjaro.mirror.ac.za/stable/$repo/$arch
2: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
3: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
4: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
Processes:
CPU top: 5 of 408
1: cpu: 100% command: ps pid: 270612 mem: 4.18 MiB (0.0%)
2: cpu: 25.2% command: vivaldi-bin pid: 270534 mem: 159.5 MiB (1.0%)
3: cpu: 8.1% command: vivaldi-bin pid: 267085 mem: 565.1 MiB (3.6%)
4: cpu: 4.2% command: vivaldi-bin pid: 266645 mem: 413.9 MiB (2.6%)
5: cpu: 4.1% command: vivaldi-bin pid: 5184 mem: 962.2 MiB (6.2%)
Memory top: 5 of 408
1: mem: 1436.9 MiB (9.3%) command: cpptools pid: 8229 cpu: 0.4%
2: mem: 1173.2 MiB (7.6%) command: vivaldi-bin pid: 11303 cpu: 1.5%
3: mem: 962.2 MiB (6.2%) command: vivaldi-bin pid: 5184 cpu: 4.1%
4: mem: 661.6 MiB (4.3%) command: vivaldi-bin pid: 6908 cpu: 1.9%
5: mem: 565.1 MiB (3.6%) command: vivaldi-bin pid: 267085 cpu: 8.1%
Processes: 408 Power: uptime: 8h 52m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.96 GiB services: org_kde_powerdevil,upowerd
Compilers: clang: 20.1.6 gcc: 15.1.1 Shell: Zsh v: 5.9 running-in: kitty
inxi: 3.3.38
Sound Information:
yamo: ~ > aplay -L <master*> 17:54
null
Discard all samples (playback) or generate zero samples (capture)
lavrate
Rate Converter Plugin Using Libav/FFmpeg Library
samplerate
Rate Converter Plugin Using Samplerate Library
speexrate
Rate Converter Plugin Using Speex Resampler
jack
JACK Audio Connection Kit
oss
Open Sound System
pulse
PulseAudio Sound Server
speex
Plugin using Speex DSP (resample, agc, denoise, echo, dereverb)
upmix
Plugin for channel upmix (4,6,8)
vdownmix
Plugin for channel downmix (stereo) with a simple spacialization
default
Default ALSA Output (currently PulseAudio Sound Server)
hdmi:CARD=NVidia,DEV=0
HDA NVidia, HDMI 0
HDMI Audio Output
hdmi:CARD=NVidia,DEV=1
HDA NVidia, HDMI 1
HDMI Audio Output
hdmi:CARD=NVidia,DEV=2
HDA NVidia, HDMI 2
HDMI Audio Output
hdmi:CARD=NVidia,DEV=3
HDA NVidia, HDMI 3
HDMI Audio Output
usbstream:CARD=NVidia
HDA NVidia
USB Stream Output
sysdefault:CARD=Generic
HD-Audio Generic, ALC257 Analog
Default Audio Device
front:CARD=Generic,DEV=0
Front output / input
surround21:CARD=Generic,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Generic,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Generic,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Generic,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Generic,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Generic,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
usbstream:CARD=Generic
HD-Audio Generic
USB Stream Output
TLDR;
I made the mistake of touching something that was working and now I just want to get everything back the way it was.
My mics (laptops internal & Headset [Soundcore Q30] ) are not being detected by vivaldi even though they are shown already.
I also have to keep on typing sudo systemctl restart bluetooth
for my bluetooth headset to work even after making the switch back.
