Microphone internal not working. Only noise
Hi guys.
I’m running manjaro on mac-mini and on external ssd.
Manjaro that’s fine but I have a problem with the microphone.
I tried to touch pulse audio, alsa mixer but the only thing I hear when I record with the microphone is a background noise, like a rustle
I’ve tried using both the internal microphone and the webcam microphone, but none of them work. I’ll post all the specifics and I hope you can help me.
Thank you!
pacmd list-cards
        1 card(s) available.
    index: 0
	driver: <module-alsa-card.c>
	owner module: 6
	properties:
		alsa.card = "0"
		alsa.long_card_name = "HDA Intel PCH at 0xa0900000 irq 50"
		device.bus_path = "pci-0000:00:1b.0"
		sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card0"
		device.bus = "pci"
		device.vendor.id = "8086"
		device.product.id = "1c20"
		device.product.name = "6 Series/C200 Series Chipset Family High Definition Audio Controller (Apple MacBookPro8,2 [Core i7, 15\", 2011])"
		device.string = "0"
		device.description = "Audio interno"
		module-udev-detect.discovered = "1"
		device.icon_name = "audio-card-pci"
	profiles:
		input:analog-stereo: Ingresso «Stereo analogico» (priority 65, available: unknown)
		input:iec958-stereo: Ingresso «Stereo digitale (IEC958)» (priority 55, available: unknown)
		output:analog-stereo: Uscita «Stereo analogico» (priority 6500, available: unknown)
		output:analog-stereo+input:analog-stereo: Duplex stereo analogico (priority 6565, available: unknown)
		output:analog-stereo+input:iec958-stereo: Uscita «Stereo analogico» + Ingresso «Stereo digitale (IEC958)» (priority 6555, available: unknown)
		output:iec958-stereo: Uscita «Stereo digitale (IEC958)» (priority 5500, available: unknown)
		output:iec958-stereo+input:analog-stereo: Uscita «Stereo digitale (IEC958)» + Ingresso «Stereo analogico» (priority 5565, available: unknown)
		output:iec958-stereo+input:iec958-stereo: Duplex stereo digitale (IEC958) (priority 5555, available: unknown)
		output:hdmi-stereo: Uscita «Digital Stereo (HDMI)» (priority 5900, available: no)
		output:hdmi-stereo+input:analog-stereo: Uscita «Digital Stereo (HDMI)» + Ingresso «Stereo analogico» (priority 5965, available: no)
		output:hdmi-stereo+input:iec958-stereo: Uscita «Digital Stereo (HDMI)» + Ingresso «Stereo digitale (IEC958)» (priority 5955, available: no)
		output:hdmi-surround: Uscita «Digital Surround 5.1 (HDMI)» (priority 800, available: no)
		output:hdmi-surround+input:analog-stereo: Uscita «Digital Surround 5.1 (HDMI)» + Ingresso «Stereo analogico» (priority 865, available: no)
		output:hdmi-surround+input:iec958-stereo: Uscita «Digital Surround 5.1 (HDMI)» + Ingresso «Stereo digitale (IEC958)» (priority 855, available: no)
		output:hdmi-surround71: Uscita «Digital Surround 7.1 (HDMI)» (priority 800, available: no)
		output:hdmi-surround71+input:analog-stereo: Uscita «Digital Surround 7.1 (HDMI)» + Ingresso «Stereo analogico» (priority 865, available: no)
		output:hdmi-surround71+input:iec958-stereo: Uscita «Digital Surround 7.1 (HDMI)» + Ingresso «Stereo digitale (IEC958)» (priority 855, available: no)
		output:hdmi-stereo-extra1: Uscita «Digital Stereo (HDMI 2)» (priority 5700, available: no)
		output:hdmi-stereo-extra1+input:analog-stereo: Uscita «Digital Stereo (HDMI 2)» + Ingresso «Stereo analogico» (priority 5765, available: no)
		output:hdmi-stereo-extra1+input:iec958-stereo: Uscita «Digital Stereo (HDMI 2)» + Ingresso «Stereo digitale (IEC958)» (priority 5755, available: no)
		output:hdmi-surround-extra1: Uscita «Digital Surround 5.1 (HDMI 2)» (priority 600, available: no)
		output:hdmi-surround-extra1+input:analog-stereo: Uscita «Digital Surround 5.1 (HDMI 2)» + Ingresso «Stereo analogico» (priority 665, available: no)
		output:hdmi-surround-extra1+input:iec958-stereo: Uscita «Digital Surround 5.1 (HDMI 2)» + Ingresso «Stereo digitale (IEC958)» (priority 655, available: no)
		output:hdmi-surround71-extra1: Uscita «Digital Surround 7.1 (HDMI 2)» (priority 600, available: no)
		output:hdmi-surround71-extra1+input:analog-stereo: Uscita «Digital Surround 7.1 (HDMI 2)» + Ingresso «Stereo analogico» (priority 665, available: no)
		output:hdmi-surround71-extra1+input:iec958-stereo: Uscita «Digital Surround 7.1 (HDMI 2)» + Ingresso «Stereo digitale (IEC958)» (priority 655, available: no)
		output:hdmi-stereo-extra2: Uscita «Digital Stereo (HDMI 3)» (priority 5700, available: unknown)
		output:hdmi-stereo-extra2+input:analog-stereo: Uscita «Digital Stereo (HDMI 3)» + Ingresso «Stereo analogico» (priority 5765, available: unknown)
		output:hdmi-stereo-extra2+input:iec958-stereo: Uscita «Digital Stereo (HDMI 3)» + Ingresso «Stereo digitale (IEC958)» (priority 5755, available: unknown)
		off: Spento (priority 0, available: unknown)
	active profile: <output:analog-stereo+input:analog-stereo>
	sinks:
		alsa_output.pci-0000_00_1b.0.analog-stereo/#0: Audio interno Stereo analogico
	sources:
		alsa_output.pci-0000_00_1b.0.analog-stereo.monitor/#0: Monitor of Audio interno Stereo analogico
		alsa_input.pci-0000_00_1b.0.analog-stereo/#1: Audio interno Stereo analogico
	ports:
		analog-input-linein: Line In (priority 8100, latency offset 0 usec, available: yes)
			properties:
		iec958-stereo-input: Digital Input (S/PDIF) (priority 0, latency offset 0 usec, available: unknown)
			properties:
		analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: no)
			properties:
		analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: yes)
			properties:
	iec958-stereo-output: Digital Output (S/PDIF) (priority 0, latency offset 0 usec, available: unknown)
		properties:
	hdmi-output-0: HDMI / DisplayPort (priority 5900, latency offset 0 usec, available: no)
		properties:
	hdmi-output-1: HDMI / DisplayPort 2 (priority 5800, latency offset 0 usec, available: no)
		properties:
	hdmi-output-2: HDMI / DisplayPort 3 (priority 5700, latency offset 0 usec, available: yes)
		properties:
			device.product.name = "MSI G24C4"
[    6.839528] snd_hda_intel 0000:00:1b.0: enabling device (0000 -> 0002)
[    7.107096] snd_hda_intel 0000:00:1b.0: bound 0000:00:02.0 (ops i915_audio_component_bind_ops
[     7.235197] snd_hda_codec_cirrus hdaudioC0D0: autoconfig for CS4206: line_outs=1 (0xb/0x0 /0x0/0x0/0x0) type:speaker
[    7.235208] snd_hda_codec_cirrus hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[    7.235212] snd_hda_codec_cirrus hdaudioC0D0:    hp_outs=1 (0xa/0x0/0x0/0x0/0x0)
[    7.235216] snd_hda_codec_cirrus hdaudioC0D0:    mono: mono_out=0x0
[    7.235219] snd_hda_codec_cirrus hdaudioC0D0:    dig-out=0x10/0x0
[    7.235222] snd_hda_codec_cirrus hdaudioC0D0:    inputs:
[    7.235225] snd_hda_codec_cirrus hdaudioC0D0:      Line=0xc
[    7.235228] snd_hda_codec_cirrus hdaudioC0D0:    dig-in=0xf
  Kernel: 5.12.1-2-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
  parameters: ro root=UUID=b0c999f2-ca5a-4338-859b-26b3781c7c06
  initrd=boot\initramfs-5.12-x86_64.img
  Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
  Type: Laptop System: Apple product: Macmini5,3 v: 1.0 serial: <filter>
  Chassis: type: 16 v: Mac-7BA5B2794B2CDB12 serial: <filter>
  Mobo: Apple model: Mac-7BA5B2794B2CDB12 v: Macmini5,3 serial: <filter>
  UEFI: Apple v: 135.0.0.0.0 date: 06/13/2019
  Info: Quad Core model: Intel Core i7-2635QM bits: 64 type: MT MCP
  arch: Sandy Bridge family: 6 model-id: 2A (42) stepping: 7 microcode: 2F
  cache: L2: 6 MiB
  flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 31940
  Speed: 798 MHz min/max: 800/2900 MHz Core speeds (MHz): 1: 798 2: 798 3: 798
  4: 798 5: 798 6: 965 7: 888 8: 1044
  Type: l1tf
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
  vendor: Apple driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:0116
  class-ID: 0300
  Device-2: Chicony TOSHIBA Web Camera - FHD type: USB driver: uvcvideo
  bus-ID: 2-1.3.3:6 chip-ID: 04f2:b470 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.Org 1.20.11 driver: loaded: intel
  unloaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
  s-diag: 582mm (22.9")
  Monitor-1: HDMI3 res: 1920x1080 hz: 60 dpi: 94 size: 520x290mm (20.5x11.4")
  diag: 595mm (23.4")
  OpenGL: renderer: Mesa DRI Intel HD Graphics 3000 (SNB GT2)
  v: 3.3 Mesa 21.0.3 compat-v: 3.0 direct render: Yes
  driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
  class-ID: 0403
  Sound Server-1: ALSA v: k5.12.1-2-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.26 running: no
  Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
  v: kernel port: efa0 bus-ID: 02:00.0 chip-ID: 14e4:16b4 class-ID: 0200
  IF: enp2s0f0 state: down mac: <filter>
  Device-2: Broadcom BCM4331 802.11a/b/g/n driver: bcma-pci-bridge v: N/A
  modules: bcma port: efa0 bus-ID: 03:00.0 chip-ID: 14e4:4331 class-ID: 0280
  IF-ID-1: wlp3s0b1 state: up mac: <filter>
  Device-1: Apple Bluetooth Host Controller type: USB driver: btusb v: 0.8
  bus-ID: 1-1.1.3:7 chip-ID: 05ac:8281 class-ID: fe01
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Local Storage: total: 1.36 TiB used: 7.05 GiB (0.5%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST9500420ASG
  size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
  rotation: 7200 rpm serial: <filter> rev: APM1 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST9500420ASG
  ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk model: SSD PLUS 500GB
  size: 465.77 GiB block-size: physical: 4096 B logical: 512 B rotation: SSD
  serial: <filter> rev: 3005 scheme: MBR
  ID-1: / raw-size: 457.5 GiB size: 449.24 GiB (98.19%) used: 7.05 GiB (1.6%)
  fs: ext4 dev: /dev/sdc1 maj-min: 8:33
  ID-1: swap-1 type: partition size: 8.26 GiB used: 0 KiB (0.0%) priority: -2
  dev: /dev/sdc2 maj-min: 8:34
  System Temperatures: cpu: 69.0 C mobo: 50.0 C
  Processes: 245 Uptime: 32m wakeups: 1 Memory: 3.75 GiB
  used: 1.99 GiB (53.1%) Init: systemd v: 247 tool: systemctl Compilers:
  gcc: N/A Packages: pacman: 1071 lib: 298 flatpak: 0 Shell: Bash v: 5.1.4
  running-in: xfce4-terminal inxi: 3.3.04
pacmd dump
load-module module-device-restore
load-module module-stream-restore
load-module module-card-restore
load-module module-augment-properties
load-module module-switch-on-port-available
load-module module-udev-detect
load-module module-alsa-card device_id="0" name="pci-0000_00_1b.0" card_name="alsa_card.pci-0000_00_1b.0" namereg_fail=false tsched=yes fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1"
load-module module-jackdbus-detect channels=2
load-module module-bluetooth-policy
load-module module-bluetooth-discover
load-module module-bluez5-discover
load-module module-dbus-protocol
load-module module-native-protocol-unix
load-module module-gsettings
load-module module-default-device-restore
load-module module-always-sink
load-module module-intended-roles
load-module module-suspend-on-idle
load-module module-console-kit
load-module module-systemd-login
load-module module-position-event-sounds
load-module module-role-cork
load-module module-filter-heuristics
load-module module-filter-apply
load-module module-remap-source source_name=record_mono master=alsa_input.pci-0000_00_1b.0.analog-stereo master_channel_map=front-left channel_map=mono
load-module module-cli-protocol-unix
set-sink-volume alsa_output.pci-0000_00_1b.0.analog-stereo 0x9999
set-sink-mute alsa_output.pci-0000_00_1b.0.analog-stereo no
suspend-sink alsa_output.pci-0000_00_1b.0.analog-stereo yes
set-source-volume alsa_output.pci-0000_00_1b.0.analog-stereo.monitor 0x10000
set-source-mute alsa_output.pci-0000_00_1b.0.analog-stereo.monitor no
suspend-source alsa_output.pci-0000_00_1b.0.analog-stereo.monitor yes
set-source-volume alsa_input.pci-0000_00_1b.0.analog-stereo 0x16485
set-source-mute alsa_input.pci-0000_00_1b.0.analog-stereo no
suspend-source alsa_input.pci-0000_00_1b.0.analog-stereo yes
set-source-volume record_mono 0x10000
set-source-mute record_mono no
suspend-source record_mono yes
set-card-profile alsa_card.pci-0000_00_1b.0 output:analog-stereo+input:analog-stereo
set-default-sink alsa_output.pci-0000_00_1b.0.analog-stereo
set-default-source record_mono
There is no webcam audio device showing in data, and system does not appear to have an internal microphone
Data in dmesg shows the audio codec (Cirrus CS4206) has only a Line input and digital input
Hardware scans for other Macmini 5,3 systems show similar dmesg data
Apple Macmini 5,3 | linux-hardware.org
