This is an older machine (04/08/2010), but it still has an external microphone plug (which I like to use with some other equipment from time to time).
The issue is with audio input using the microphone plug.
The microphone is detected in pavucontrol, but is not responsive – nothing is happening.
Audio output is fine.
Audio input via the microphone is not working.
I have just done a clean install of Xfce 4.16.0 (minimal) using proprietary drivers.
ALSA information is located at http://alsa-project.org/db/?f=0cdf78ef760c23e4b15c3ed35aed3c33c4c1afd4
Other info to get started with:
inxi -Faz:
Kernel: 5.4.159-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=4322124a-d077-4984-b834-b551bbbdd3c3 rw quiet
udev.log_priority=3
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: LENOVO product: 7734N3U v: ThinkPad R61
serial: <superuser required> Chassis: type: 10
Mobo: LENOVO model: 7734N3U serial: <superuser required> BIOS: LENOVO
v: 7LETC7WW (2.27 ) date: 04/08/2010
ID-1: BAT0 charge: 0 Wh condition: N/A volts: N/A min: 10.8 model: N/A
type: Unknown serial: N/A status: Unknown
Info: Dual Core model: Intel Core2 Duo T8100 bits: 64 type: MCP
arch: Penryn family: 6 model-id: 17 (23) stepping: 6 microcode: 60F cache:
L1: 128 KiB L2: 6 MiB
flags: ht lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx bogomips: 8382
Speed: 801 MHz min/max: 800/2101 MHz boost: enabled Core speeds (MHz):
1: 927 2: 1015
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Device-1: Intel Mobile GM965/GL960 Integrated Graphics vendor: Lenovo
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:2a02 class-ID: 0300
Display: x11 server: X.Org 1.21.1.1 compositor: xfwm4 v: 4.16.1 driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1280x800 s-dpi: 96 s-size: 338x211mm (13.3x8.3")
s-diag: 398mm (15.7")
OpenGL: renderer: Mesa DRI Intel 965GM (CL) v: 2.1 Mesa 21.2.5
direct render: Yes
Device-1: Intel 82801H HD Audio vendor: Lenovo ThinkPad T61/R61
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:284b
class-ID: 0403
Sound Server-1: ALSA v: k5.4.159-1-MANJARO running: yes
Device-1: Intel 82566MM Gigabit Network vendor: Lenovo ThinkPad T61/R61
driver: e1000e v: 3.2.6-k port: 1840 bus-ID: 00:19.0 chip-ID: 8086:1049
class-ID: 0200
IF: enp0s25 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 149.05 GiB used: 7.02 GiB (4.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Hitachi model: HTS542516K9SA00
size: 149.05 GiB block-size: physical: 512 B logical: 512 B
speed: 1.5 Gb/s type: N/A serial: <filter> rev: C3HP scheme: MBR
ID-1: / raw-size: 149.05 GiB size: 145.65 GiB (97.72%)
used: 7.02 GiB (4.8%) fs: ext4 dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
System Temperatures: cpu: 53.0 C mobo: 51.0 C
Fan Speeds (RPM): cpu: 0
Processes: 145 Uptime: 21m wakeups: 1 Memory: 2.9 GiB
used: 692.5 MiB (23.4%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 913 lib: 270 Shell: Bash v: 5.1.8
running-in: xfce4-terminal inxi: 3.3.09
lspci -k:
00:00.0 Host bridge: Intel Corporation Mobile PM965/GM965/GL960 Memory Controller Hub (rev 0c)
Subsystem: Lenovo ThinkPad T61/R61
Kernel modules: intel_agp
00:02.0 VGA compatible controller: Intel Corporation Mobile GM965/GL960 Integrated Graphics Controller (primary) (rev 0c)
Subsystem: Lenovo GM965 [X3100] on ThinkPad T61/R61
Kernel driver in use: i915
Kernel modules: i915
00:02.1 Display controller: Intel Corporation Mobile GM965/GL960 Integrated Graphics Controller (secondary) (rev 0c)
00:19.0 Ethernet controller: Intel Corporation 82566MM Gigabit Network Connection (rev 03)
Kernel driver in use: e1000e
Kernel modules: e1000e
00:1a.0 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #4 (rev 03)
Kernel driver in use: uhci_hcd
Kernel modules: uhci_hcd
00:1a.1 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #5 (rev 03)
Subsystem: Lenovo Thinkpad T61/R61
00:1a.7 USB controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #2 (rev 03)
Kernel driver in use: ehci-pci
Kernel modules: ehci_pci
00:1b.0 Audio device: Intel Corporation 82801H (ICH8 Family) HD Audio Controller (rev 03)
Kernel driver in use: snd_hda_intel
Kernel modules: snd_hda_intel
00:1c.0 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 1 (rev 03)
Kernel driver in use: pcieport
00:1c.2 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 3 (rev 03)
00:1c.3 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 4 (rev 03)
00:1c.4 PCI bridge: Intel Corporation 82801H (ICH8 Family) PCI Express Port 5 (rev 03)
00:1d.0 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #1 (rev 03)
00:1d.1 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #2 (rev 03)
00:1d.2 USB controller: Intel Corporation 82801H (ICH8 Family) USB UHCI Controller #3 (rev 03)
00:1d.7 USB controller: Intel Corporation 82801H (ICH8 Family) USB2 EHCI Controller #1 (rev 03)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev f3)
00:1f.0 ISA bridge: Intel Corporation 82801HEM (ICH8M-E) LPC Interface Controller (rev 03)
Kernel driver in use: lpc_ich
Kernel modules: lpc_ich
00:1f.1 IDE interface: Intel Corporation 82801HM/HEM (ICH8M/ICH8M-E) IDE Controller (rev 03)
Kernel driver in use: ata_piix
Kernel modules: ata_piix, pata_acpi, ata_generic
00:1f.2 SATA controller: Intel Corporation 82801HM/HEM (ICH8M/ICH8M-E) SATA Controller [AHCI mode] (rev 03)
Kernel driver in use: ahci
Kernel modules: ahci
00:1f.3 SMBus: Intel Corporation 82801H (ICH8 Family) SMBus Controller (rev 03)
Kernel driver in use: i801_smbus
Kernel modules: i2c_i801
15:00.0 CardBus bridge: Ricoh Co Ltd RL5c476 II (rev ba)
Subsystem: Lenovo ThinkPad R61/T400
Kernel driver in use: yenta_cardbus
Kernel modules: yenta_socket
15:00.1 FireWire (IEEE 1394): Ricoh Co Ltd R5C832 IEEE 1394 Controller (rev 04)
Kernel driver in use: firewire_ohci
Kernel modules: firewire_ohci
amixer -c0:
Simple mixer control 'Master',0
Capabilities: pvolume pvolume-joined pswitch pswitch-joined
Playback channels: Mono
Limits: Playback 0 - 39
Mono: Playback 30 [77%] [-13.50dB] [on]
Simple mixer control 'Headphone',0
Capabilities: pvolume pswitch
Mono:
Front Left: Playback 0 [0%] [-58.50dB] [off]
Front Right: Playback 0 [0%] [-58.50dB] [off]
Simple mixer control 'Speaker',0
Mono:
Front Left: Playback 39 [100%] [0.00dB] [on]
Front Right: Playback 39 [100%] [0.00dB] [on]
Simple mixer control 'PCM',0
Limits: Playback 0 - 255
Mono:
Front Left: Playback 255 [100%] [0.00dB]
Front Right: Playback 255 [100%] [0.00dB]
Simple mixer control 'Mic',0
Limits: Playback 0 - 31
Mono:
Front Left: Playback 0 [0%] [-34.50dB] [off]
Front Right: Playback 0 [0%] [-34.50dB] [off]
Simple mixer control 'Mic Boost',0
Capabilities: volume
Limits: 0 - 3
Front Left: 0 [0%] [0.00dB]
Front Right: 0 [0%] [0.00dB]
Simple mixer control 'IEC958',0
Capabilities: pswitch pswitch-joined
Mono: Playback [off]
Simple mixer control 'IEC958 Default PCM',0
Mono: Playback [on]
Simple mixer control 'IEC958 Playback Source',0
Capabilities: enum
Items: 'PCM' 'ADC1' 'ADC2'
Item0: 'PCM'
Simple mixer control 'Beep',0
Mono:
Simple mixer control 'Capture',0
Capabilities: cvolume cswitch
Limits: Capture 0 - 54
Front Left: Capture 45 [83%] [9.00dB] [on]
Front Right: Capture 45 [83%] [9.00dB] [on]
Simple mixer control 'Auto-Mute Mode',0
Capabilities: enum
Items: 'Disabled' 'Enabled'
Item0: 'Disabled'
Simple mixer control 'Dock Mic',0
Mono:
Simple mixer control 'Dock Mic Boost',0
Limits: 0 - 3
Simple mixer control 'Independent HP',0
Capabilities: enum
Item0: 'Disabled'
Simple mixer control 'Internal Mic',0
Mono:
Simple mixer control 'Internal Mic Boost',0
Limits: 0 - 3
Simple mixer control 'Loopback Mixing',0
Capabilities: enum
Item0: 'Disabled'
pacmd list-cards:
1 card(s) available.
index: 0
driver: <module-alsa-card.c>
owner module: 6
properties:
alsa.card = "0"
alsa.card_name = "HDA Intel"
alsa.long_card_name = "HDA Intel at 0xfe020000 irq 30"
device.bus_path = "pci-0000:00:1b.0"
sysfs.path = "/devices/pci0000:00/0000:00:1b.0/sound/card0"
device.bus = "pci"
device.vendor.id = "8086"
device.product.id = "284b"
device.product.name = "82801H (ICH8 Family) HD Audio Controller (ThinkPad T61/R61)"
device.string = "0"
device.description = "Built-in Audio"
module-udev-detect.discovered = "1"
device.icon_name = "audio-card-pci"
profiles:
input:analog-stereo: Analog Stereo Input (priority 32833, available: unknown)
output:analog-stereo: Analog Stereo Output (priority 39268, available: unknown)
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (priority 39333, available: unknown)
output:iec958-stereo: Digital Stereo (IEC958) Output (priority 38268, available: unknown)
output:iec958-stereo+input:analog-stereo: Digital Stereo (IEC958) Output + Analog Stereo Input (priority 38333, available: unknown)
off: Off (priority 0, available: unknown)
active profile: <output:analog-stereo+input:analog-stereo>
sinks:
alsa_output.pci-0000_00_1b.0.analog-stereo/#0: Built-in Audio Analog Stereo
sources:
alsa_output.pci-0000_00_1b.0.analog-stereo.monitor/#0: Monitor of Built-in Audio Analog Stereo
alsa_input.pci-0000_00_1b.0.analog-stereo/#1: Built-in Audio Analog Stereo
ports:
analog-input-internal-mic: Internal Microphone (priority 8900, latency offset 0 usec, available: unknown)
properties:
analog-input-dock-mic: Dock Microphone (priority 7800, latency offset 0 usec, available: no)
properties:
analog-input-mic: Microphone (priority 8700, latency offset 0 usec, available: no)
properties:
analog-output-speaker: Speakers (priority 10000, latency offset 0 usec, available: unknown)
properties:
analog-output-headphones: Headphones (priority 9900, latency offset 0 usec, available: no)
properties:
iec958-stereo-output: Digital Output (S/PDIF) (priority 0, latency offset 0 usec, available: unknown)
properties:
Thank You in advance for any help to get this working again!
