Greetings …
While booted to kernel 5.15.7-1 (and beginning with first 5.15 release) any invocation of mhwd locks up - when using System Settings Hardware Configuration, the System Settings window freezes with dimmed text and cannot be killed. When invoked from the terminal, the terminal cursor disappears and nothing is displayed, but the terminal window can be killed.
Booting back to LTS kernel 5.10 restores normal function of mhwd, but 5.10 had a bug that caused NetworkManager to lose my Intel AX210 wifi half the time, which was fixed in 5.15.
Anyone else observe this behavior?
inxi -Fazy
Kernel: 5.15.7-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=ff897157-6a95-4b42-9298-ba3ff848d4ee rw quiet
modprobe.blacklist=i2c_piix4
resume=UUID=50dcdc25-3ec6-4f79-849d-ad2e0097ad90
acpi_enforce_resources=lax
Desktop: KDE Plasma 5.23.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: Gigabyte product: X570S AORUS MASTER v: -CF
serial: <superuser required>
Mobo: Gigabyte model: X570S AORUS MASTER serial: <superuser required>
BIOS: American Megatrends LLC. v: F3c date: 10/01/2021
Device-1: hidpp_battery_0 model: Logitech MX Ergo Multi-Device Trackball
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: Discharging
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3512 high: 4652 min/max: 2200/5083 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3913 2: 3677
3: 4626 4: 4652 5: 3697 6: 4610 7: 3702 8: 3670 9: 2928 10: 2904 11: 2890
12: 3624 13: 2876 14: 2876 15: 2878 16: 3599 17: 3675 18: 3697 19: 4625
20: 3703 21: 3712 22: 4636 23: 3697 24: 3699 25: 2976 26: 2878 27: 2876
28: 3600 29: 2880 30: 2872 31: 2878 32: 2871 bogomips: 217697
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional,
IBRS_FW, STIBP: always-on, RSB filling
Device-1: NVIDIA TU106 [GeForce RTX 2070 Rev. A] driver: nvidia v: 470.86
alternate: nouveau,nvidia_drm bus-ID: 0c:00.0 chip-ID: 10de:1f07
class-ID: 0300
Device-2: NVIDIA TU117 [GeForce GTX 1650] vendor: ZOTAC driver: nvidia
v: 470.86 alternate: nouveau,nvidia_drm bus-ID: 0d:00.0 chip-ID: 10de:1f82
class-ID: 0300
Display: x11 server: X.Org 1.21.1.2 compositor: kwin_x11 driver:
Screen-1: 0 s-res: 3840x2160 s-dpi: 139 s-size: 702x392mm (27.6x15.4")
s-diag: 804mm (31.7")
Monitor-1: DP-0 res: 3840x2160 dpi: 140 size: 697x392mm (27.4x15.4")
diag: 800mm (31.5")
Device-1: NVIDIA TU106 High Definition Audio driver: snd_hda_intel v: kernel
bus-ID: 0c:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-2: NVIDIA vendor: ZOTAC driver: snd_hda_intel v: kernel
bus-ID: 0d:00.1 chip-ID: 10de:10fa class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 0f:00.4 chip-ID: 1022:1487
class-ID: 0403
Sound Server-1: ALSA v: k5.15.7-1-MANJARO running: yes
Sound Server-3: PulseAudio v: 15.0 running: no
Sound Server-4: PipeWire v: 0.3.40 running: yes
Device-1: Intel Wi-Fi 6 AX210/AX211/AX411 160MHz driver: iwlwifi v: kernel
bus-ID: 07:00.0 chip-ID: 8086:2725 class-ID: 0280
IF: wlp7s0 state: up mac: <filter>
Device-2: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel
port: N/A bus-ID: 08:00.0 chip-ID: 8086:15f3 class-ID: 0200
IF: enp8s0 state: down mac: <filter>
Device-1: Intel AX210 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 5-5:2
chip-ID: 8087:0032 class-ID: e001
Local Storage: total: 4.1 TiB used: 356.7 GiB (8.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: T-FORCE TM8FP7001T
lanes: 4 type: SSD serial: <filter> rev: EGFM13.0 temp: 59.9 C scheme: MBR
ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Samsung model: SSD 960 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: 3B7QCXE7 temp: 64.8 C scheme: MBR
ID-3: /dev/nvme2n1 maj-min: 259:6 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 type: SSD serial: <filter> rev: 2B2QEXE7 temp: 65.8 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD1003FZEX-00MK2A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD10EZEX-08M2NA0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: MBR
ID-6: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 830 Series
size: 59.63 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 3B1Q scheme: MBR
ID-7: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 830 Series
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-8: /dev/sde maj-min: 8:64 type: USB model: USB DISK 3.0 size: 28.9 GiB
block-size: physical: 512 B logical: 512 B type: N/A serial: <filter>
rev: PMAP scheme: MBR
ID-9: /dev/sdf maj-min: 8:80 type: USB model: USB DISK 3.0 size: 28.9 GiB
ID-1: / raw-size: 55.03 GiB size: 53.91 GiB (97.97%) used: 44.39 GiB (82.3%)
fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /home raw-size: 140.29 GiB size: 137.97 GiB (98.34%)
used: 65.61 GiB (47.6%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
ID-1: swap-1 type: partition size: 15.93 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p5 maj-min: 259:4
System Temperatures: cpu: 16.8 C mobo: N/A gpu: nvidia temp: 86 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 70%
Processes: 577 Uptime: 13h 20m wakeups: 25 Memory: 31.31 GiB
used: 5.43 GiB (17.3%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 alt: 10/9 clang: 13.0.0 Packages: pacman: 1755 lib: 464
Shell: Bash v: 5.1.12 running-in: konsole inxi: 3.3.11
