Mhwd -li no pci/usb devices installed
Hi all!
I’m just checking to make absolutely sure.
Wen I run mhwd -li It does not list any results, as can be seen below:
$ mhwd -li
Warning: No installed PCI configs!
When I run mhwd -l I get the output below:
$ mhwd -l
> 0000:01:00.0 (0300:10de:1401) Display controller nVidia Corporation:
video-nvidia            2020.11.30               false            PCI
video-nvidia-390xx            2020.11.30               false            PCI
video-linux            2018.05.04                true            PCI
And when I run inxi -G the output is:
$ inxi -G
Graphics:  Device-1: NVIDIA GM206 [GeForce GTX 960] driver: nvidia v: 455.45.01
Display: x11 server: X.Org 1.20.10 driver: nvidia resolution: 1: 2560x1080~60Hz 2: 2560x1080~60Hz
OpenGL: renderer: GeForce GTX 960/PCIe/SSE2 v: 4.6.0 NVIDIA 455.45.01
According to my understanding, which might be wrong or might not, nvidia-linux (or something like that) should be listed when I run mhwd -li. Admittedly, I might be wrong and considering everything’s working like a charm it probably is correct, but I just wanted to double-check.
We updated our hardware database. Somehow your system didn’t adopted. What is the output of:
pacman -Q | grep nvidia
You may also try to install the Nvidia driver like this:
sudo mhwd -a pci nonfree 0300
More info about setting up your graphics hard here: Configure Graphics Cards - Manjaro
Just did that, and as expected, the output is
$ pacman -Q | grep nvidia
lib32-nvidia-utils 455.45.01-3
linux510-nvidia 455.45.01-10.0
linux54-nvidia 455.45.01-6
mhwd-nvidia 455.45.01-3
mhwd-nvidia-390xx 390.138-1
nvidia-utils 455.45.01-2
So it looks like all the drivers are, indeed, installed.
And, I just executed the sudo mhwd -a pci nonfree 0300 command again. It went extremely quickly, but afterwards the mhwd -li command shows the right driver again.
$ mhwd -li
> Installed PCI configs:
So, thank you!
