extra kernel in grub
mhwd-kernel -li
shows one kernel,5.10 but on grub it shows 3 5.10 with 5.8 and 5.7
Found theme: /usr/share/grub/themes/Tela/theme.txt
Found linux image: /boot/vmlinuz-5.10-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.10-x86_64.img
Found initrd fallback image: /boot/initramfs-5.10-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.8-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.8-x86_64.img
Found initrd fallback image: /boot/initramfs-5.8-x86_64-fallback.img
Found linux image: /boot/vmlinuz-5.7-x86_64
Found initrd image: /boot/intel-ucode.img /boot/initramfs-5.7-x86_64.img
Found initrd fallback image: /boot/initramfs-5.7-x86_64-fallback.img
Found
Hi @Bearbobs,
I suggest you install another kernel, for example 5.4:
sudo mhwd-kernel --install linux54
Then reboot, and see what happens at boot.
It’s a good idea to keep 2 kernels anyway, so that if something goes wrong with one, there’s always another one you can use.
Adding to what @Mirdarthos said, remove unneeded/unsupported kernels:
sudo pacman -Rs linux57 linux58
There are remnants of old kernels in /boot
- remove them manually:
$ sudo rm /boot/vmlinuz-5.[78]-x86_64 /boot/initramfs-5.[78]-x86_64.img
$ sudo update-grub
