The idea is good, but unfortunately it cannot be implemented.
The reason for this is that mhwd-linux queries the existing or installed kernels via pacman and this information is not stored there.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or or if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
