tsapi
17 November 2024 11:25
1
Hi all!
I tried to rum mhwd yesterday, but it refuses to run:
sudo mhwd
Error: Following directories do not exist:
> /var/lib/mhwd/db/usb
> /var/lib/mhwd/local/usb
I reinstalled it (pacman -S mhwd) but the error persists.
I googled for the problem - found no obvious help.
Checked about these directories in my system - they don’t exist.
ls -lah /var/lib/mhwd/db
Summary
drwxr-xr-x 3 root root 4,0K Νοε 13 22:46 .
drwxr-xr-x 6 root root 4,0K Αυγ 12 14:01 ..
drwxr-xr-x 4 root root 4,0K Αυγ 20 18:56 pci
ls -lah /var/lib/mhwd/local
Summary
drwxr-xr-x 3 root root 4,0K Αυγ 20 18:56 pci
I understand that I can create these directories manually (with correct permissions, writable only by root) - but I thought I d ask here first and report the problem first.
There is more than mhwd
pacman -Ss mhwd
extra/bmenu 0.25-1
Bash scripts providing a collection of terminal applications in a simple UI
extra/mhwd 0.6.5-36 [installed]
Manjaro Linux Hardware Detection library and application
extra/mhwd-amdgpu 19.1.0-1 [installed]
MHWD module-ids for amdgpu
extra/mhwd-ati 19.1.0-1 [installed]
MHWD module-ids for ati 19.1.0
extra/mhwd-db 0.6.5-36 [installed]
Manjaro Linux Hardware Detection Database
extra/mhwd-nvidia 550.120-1 [installed]
MHWD module-ids for nvidia 550.120
extra/mhwd-nvidia-390xx 390.157-14 [installed]
MHWD module-ids for nvidia 390.157
extra/mhwd-nvidia-470xx 470.256.02-4 [installed]
MHWD module-ids for nvidia 470.256.02
brahma
17 November 2024 16:28
3
had the same issue, created the 2 missing directories, now everything works…
What version of mhwd
& mhwd-db
do you have installed?
pacman -Qi mhwd mhwd-db | grep Version
No matter which version, mhwd
installs both these directories:
❯ pacman -Qo /var/lib/mhwd/{db,local}/usb
/var/lib/mhwd/db/usb/ is owned by mhwd 0.6.6-1
/var/lib/mhwd/local/usb/ is owned by mhwd 0.6.6-1
From up-to-date testing channel:
$ pacman -Qi mhwd mhwd-db | grep Version
Version : 0.6.6-1
Version : 20241117-1
$ pacman -Qo /var/lib/mhwd/{db,local}/usb
error: No package owns /var/lib/mhwd/db/usb
error: No package owns /var/lib/mhwd/local/usb
$ pacman -Qkk mhwd mhwd-db
mhwd: 15 total files, 0 altered files
mhwd-db: 51 total files, 0 altered files
Ah, I just realized what happened. I’ll push 0.6.6-2 here shortly.
Molski
17 November 2024 18:05
7
Happened to me yesterday when I changed one instance to the testing branch.
So what are the permissions on those folders?
e.g: owner:group 775 ?
tsapi
17 November 2024 19:53
8
Forgot to mention that I am on the testing branch…
Version : 0.6.6-1
Version : 20240506-2
root:root, 755
I have created the directories manually, so mhwd runs fine. But I guess pushing a version which corrects the problem is the correct solution. Thanks!
Molski
17 November 2024 20:17
9
$ mhwd
Copy/pasta fix:
$ sudo mkdir /var/lib/mhwd/db/usb /var/lib/mhwd/local/usb
$ sudo chown root:root /var/lib/mhwd/db/usb /var/lib/mhwd/local/usb
$ sudo chmod 775 /var/lib/mhwd/db/usb /var/lib/mhwd/local/usb
Working.
$ mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-virtualmachine 2024.05.06 true PCI
video-modesetting 2020.01.13 true PCI
video-linux 2024.05.06 true PCI
video-nvidia 2024.05.03 false PCI
Molski:
yesterday
…is no longer relevant.
Have you updated to 0.6.6-2 yet?
Molski
17 November 2024 21:10
11
I checked for updates not long before posting.
I see it now.
[tracy@daphne ~]$ mhwd -v
Manjaro Hardware Detection v0.6.5
Copyright (C) 2012-2020 Manjaro Linux Developers
This is free software licensed under GNU GPL v3.0
FITNESS FOR A PARTICULAR PURPOSE
What is the point of those Directories? on my set up they are empty.
cscs
17 November 2024 21:39
13
One would guess they would contain some sort of drivers provided over USB.
But in all the years of its existence, I dont recall if mhwd
ever did provide any such drivers.
And it certainly does not now.
The paths are like this:
/var/lib/mhwd/db/
= for available mhwd profiles
= for installed mhwd profiles
Don’t forget to update your user profile via Forum Profile Preferences to reflect that you are no longer on on Stable branch.
system
Closed
20 November 2024 23:33
15
