Mf4018 not printing
I’m a beginner and I have this setup:
Summary
KDE Plasma Version: 6.3.6
KDE Frameworks Version: 6.18.0
Qt Version: 6.9.2
Kernel Version: 6.12.48-1-MANJARO (64-bit)
Graphics Platform: Wayland
Processors: 20 × Intel® Xeon® CPU E5-2666 v3 @ 2.90GHz
Memory: 31.2 ГиБ of RAM
Graphics Processor: AMD Radeon RX 6600 XT
Manufacturer: INTEL
Product Name: X99
I tried to connect the Cannon mf4018 printer, Manjaro was able to find it, but the printer does not print. How do I investigate the reasons why the printer doesn’t want to print? If additional information and team conclusions are needed, please let me know, and I will send everything. Also, this printer does not want to scan, I am also concerned about this issue. Before that, Linux Mint 22 was installed and there I was able to configure this printer to print, but in Manjaro I did not understand how to install deb packages.
Please provide system information as desctibed (below) to better assist other who might wish to help. Also, see How to Post Command Output as Preformatted Text to help you conform with forum presentational guidelines.
Always send everything…
Waiting for others to blindly ask questions can be counter-productive – typically, nobody has a :crystal_ball: at their disposal – Instead, please help others to make informed suggestions, based on information you provide.
Update Announcements
System Information
inxi --filter --verbosity=8
inxi -zv8
Highly Recommended
Technical Resources
Required Reading
In general, I didn’t understand what I did, but I installed the following packages:
system-config-printer
cnrdrvcups-lb-bin 6.10.01-1
cnrdrvcups-sfp 5.00-3
cnrdrvcups-lb 1:6.20.1.20-1
I rebooted the computer.
I started the system-config-printer, deleted the already installed printers and added a new printer, after that I was able to print.
Thank you!
It looks like you read the links given. Good job. :wink:
