when pressing the meta key it sometimes doesn’t launch the drop-down menu.
the bug happened after the second newest kde update
inxi:
Host: simon-m-zephyrusg14-ga402rkga402rk Kernel: 6.0.0-1-MANJARO
arch: x86_64 bits: 64 Desktop: KDE Plasma v: 5.25.5 Distro: Manjaro Linux
Type: Laptop System: ASUSTeK product: ROG Zephyrus G14 GA402RK_GA402RK
v: 1.0 serial: <superuser required>
Mobo: ASUSTeK model: GA402RK v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: GA402RK.315 date: 09/21/2022
ID-1: BAT0 charge: 65.4 Wh (100.0%) condition: 65.4/76.0 Wh (86.0%)
volts: 15.9 min: 15.9
Info: 8-core model: AMD Ryzen 9 6900HS with Radeon Graphics bits: 64
type: MT MCP cache: L2: 4 MiB
Speed (MHz): avg: 2006 min/max: 1600/4934 cores: 1: 1600 2: 1600 3: 3300
4: 1600 5: 1600 6: 3300 7: 3300 8: 1516 9: 1600 10: 1600 11: 1394 12: 1600
13: 1600 14: 1600 15: 1600 16: 3300
Device-1: AMD Rembrandt [Radeon 680M] driver: amdgpu v: kernel
Device-2: Quanta USB2.0 HD UVC WebCam type: USB driver: uvcvideo
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
gpu: amdgpu resolution: 1707x1067
OpenGL: renderer: AMD YELLOW_CARP (LLVM 14.0.6 DRM 3.48 6.0.0-1-MANJARO)
v: 4.6 Mesa 22.1.7
Device-1: AMD Rembrandt Radeon High Definition Audio driver: snd_hda_intel
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor driver: snd_pci_acp6x
Device-3: AMD Family 17h/19h HD Audio driver: snd_hda_intel
Sound Server-1: ALSA v: k6.0.0-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.58 running: yes
Device-1: MEDIATEK driver: mt7921e
IF: wlp5s0 state: up mac: b4:8c:9d:5c:77:db
Device-1: IMC Networks Wireless_Device type: USB driver: btusb
Local Storage: total: 1.89 TiB used: 99.99 GiB (5.2%)
ID-1: /dev/mmcblk0 model: SN32G size: 29.72 GiB
ID-2: /dev/nvme0n1 vendor: Toshiba model: N/A size: 1.86 TiB
ID-1: / size: 891.53 GiB used: 45.53 GiB (5.1%) fs: ext4
dev: /dev/nvme0n1p5
ID-2: /boot/efi size: 256 MiB used: 67.8 MiB (26.5%) fs: vfat
dev: /dev/nvme0n1p1
ID-3: /home size: 93.13 GiB used: 54.39 GiB (58.4%) fs: ntfs
dev: /dev/nvme0n1p6
System Temperatures: cpu: 42.9 C mobo: N/A gpu: amdgpu temp: 41.0 C
Fan Speeds (RPM): cpu: 0
Processes: 361 Uptime: 7h 5m Memory: 30.59 GiB used: 6.85 GiB (22.4%)
Shell: Bash inxi: 3.3.21
