I’ve a few .pacnew
files. I’ve never touched them till I came across the last update. The list of files is bellow:
/etc/shadow.pacnew
/etc/fonts/fonts.conf.pacnew
/etc/security/limits.d/10-gcr.conf.pacnew
/etc/locale.gen.pacnew
My system specs are bellow:
System: Kernel: 5.4.62-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-5.4-x86_64 root=UUID=89211654-461e-4349-b0c0-9c72928105dd rw quiet apparmor=1
security=apparmor resume=UUID=a355e02c-1744-4b00-b611-7191d214c9db udev.log_priority=3
Desktop: KDE Plasma 5.19.5 tk: Qt 5.15.0 wm: kwin_x11 dm: SDDM Distro: Manjaro Linux
Machine: Type: Desktop System: Acer product: Aspire TC-710 v: N/A serial: <filter> Chassis: type: 3 serial: <filter>
Mobo: Acer model: Aspire TC-710 v: V:1.1 serial: <filter> UEFI: American Megatrends v: R01-A4 date: 05/18/2016
Battery: Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master serial: <filter>
charge: 100% (should be ignored) rechargeable: yes status: Discharging
Device-2: hidpp_battery_1 model: Logitech MK700 serial: <filter> charge: 70% (should be ignored) rechargeable: yes
status: Discharging
Memory: RAM: total: 15.55 GiB used: 2.35 GiB (15.1%)
CPU: Topology: Quad Core model: Intel Core i5-6400 bits: 64 type: MCP arch: Skylake-S family: 6 model-id: 5E (94)
stepping: 3 microcode: D6 L2 cache: 6144 KiB bogomips: 21607
Speed: 900 MHz min/max: 800/3300 MHz Core speeds (MHz): 1: 900 2: 901 3: 900 4: 900
Flags: 3dnowprefetch abm acpi adx aperfmperf apic arat arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt invpcid
invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap smep
ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT disabled
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW, STIBP: disabled, RSB filling
Type: srbds status: Vulnerable: No microcode
Graphics: Device-1: Intel HD Graphics 530 vendor: Acer Incorporated ALI driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:1912
Display: x11 server: X.Org 1.20.8 compositor: kwin_x11 driver: intel unloaded: modesetting alternate: fbdev,vesa
display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x1080 s-dpi: 96 s-size: 1013x285mm (39.9x11.2") s-diag: 1052mm (41.4")
Monitor-1: HDMI1 res: 1920x1080 hz: 60 dpi: 92 size: 530x300mm (20.9x11.8") diag: 609mm (24")
Monitor-2: HDMI2 res: 1920x1080 hz: 60 dpi: 92 size: 530x300mm (20.9x11.8") diag: 609mm (24")
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 20.1.7 direct render: Yes
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Acer Incorporated ALI driver: snd_hda_intel
v: kernel bus ID: 00:1f.3 chip ID: 8086:a170
Device-2: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo bus ID: 1-1:2 chip ID: 046d:0843
serial: <filter>
Sound Server: ALSA v: k5.4.62-1-MANJARO
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Acer Incorporated ALI driver: r8169
v: kernel port: e000 bus ID: 01:00.0 chip ID: 10ec:8168
IF: enp1s0 state: down mac: <filter>
Device-2: Intel Wireless 3165 driver: iwlwifi v: kernel port: e000 bus ID: 02:00.0 chip ID: 8086:3165
IP v4: <filter> type: dynamic noprefixroute scope: global broadcast: <filter>
IF-ID-1: br-44ebdc58bf49 state: down mac: <filter>
IF-ID-2: br-601de2d0ec23 state: down mac: <filter>
IF-ID-3: br-72b7a677c2f9 state: down mac: <filter>
IF-ID-4: docker0 state: down mac: <filter>
WAN IP: No WAN IP found. Connected to web? SSL issues? Try --no-dig
Drives: Local Storage: total: 447.13 GiB used: 171.86 GiB (38.4%)
ID-1: /dev/sda vendor: Kingston model: SA400S37480G size: 447.13 GiB block size: physical: 512 B logical: 512 B
speed: 6.0 Gb/s serial: <filter> rev: K1B3 scheme: GPT
RAID: Message: No RAID data was found.
Partition: ID-1: / raw size: 64.00 GiB size: 62.74 GiB (98.04%) used: 53.64 GiB (85.5%) fs: ext4 dev: /dev/sda6 label: N/A
uuid: 89211654-461e-4349-b0c0-9c72928105dd
ID-2: /boot/efi raw size: 512.0 MiB size: 511.0 MiB (99.80%) used: 308 KiB (0.1%) fs: vfat dev: /dev/sda4
label: N/A uuid: 5619-6EE0
ID-3: /home raw size: 162.32 GiB size: 158.77 GiB (97.81%) used: 118.22 GiB (74.5%) fs: ext4 dev: /dev/sda7
label: N/A uuid: 77837a9a-08a0-42cd-acdc-b397b1f127d1
ID-4: /run/timeshift/backup raw size: 64.00 GiB size: <superuser/root required> used: <superuser/root required>
fs: ext4 dev: /dev/sda6 label: N/A uuid: 89211654-461e-4349-b0c0-9c72928105dd
Swap: Kernel: swappiness: 60 (default) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 2.00 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda5 label: N/A
uuid: a355e02c-1744-4b00-b611-7191d214c9db
Unmounted: ID-1: /dev/sda1 size: 100.0 MiB fs: vfat label: N/A uuid: 3C5F-760D
ID-2: /dev/sda2 size: 16.0 MiB fs: <superuser/root required> label: N/A uuid: N/A
ID-3: /dev/sda3 size: 218.20 GiB fs: ntfs label: N/A uuid: D67A75397A751787
USB: Hub: 1-0:1 info: Full speed (or root) Hub ports: 10 rev: 2.0 speed: 480 Mb/s chip ID: 1d6b:0002
Device-1: 1-1:2 info: Logitech Webcam C930e type: Video,Audio driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.0
speed: 480 Mb/s chip ID: 046d:0843 serial: <filter>
Device-2: 1-2:3 info: Logitech Unifying Receiver type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid
interfaces: 3 rev: 2.0 speed: 12 Mb/s chip ID: 046d:c52b
Device-3: 1-9:4 info: Realtek 3-in-1 (SD/SDHC/SDXC) Card Reader type: Mass Storage driver: ums-realtek
interfaces: 1 rev: 2.0 speed: 480 Mb/s chip ID: 0bda:0153 serial: <filter>
Device-4: 1-10:5 info: Intel Bluetooth wireless interface type: Bluetooth driver: btusb interfaces: 2 rev: 2.0
speed: 12 Mb/s chip ID: 8087:0a2a
Hub: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.0 speed: 5 Gb/s chip ID: 1d6b:0003
Sensors: System Temperatures: cpu: 39.0 C mobo: 29.8 C
Info: Processes: 230 Uptime: 4h 57m Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: pacman: 1585 lib: 464
flatpak: 0 Shell: Zsh v: 5.8 running in: konsole inxi: 3.1.05
Running DIFFPROG="sudo meld" pacdiff
gives the folloing results:
/etc/shadow.pacnew
root:*:14871::::::
/etc/shadow
root:$6$dRLOxzLv2tHC/b0e$oie.O0yluqVkEdoK8.skdCghLuiqkMfq8aej4DdFa2x3OtQohcQfgzqFacYsc0p2oVtbnPJwLevq7rh4jvIFD0:18305::::::
nobody:!!:18259::::::
dbus:!!:18259::::::
bin:!!:18259::::::
daemon:!!:18259::::::
mail:!!:18259::::::
ftp:!!:18259::::::
http:!!:18259::::::
systemd-journal-remote:!!:18259::::::
systemd-network:!!:18259::::::
systemd-resolve:!!:18259::::::
systemd-timesync:!!:18259::::::
systemd-coredump:!!:18259::::::
uuidd:!!:18259::::::
dnsmasq:!!:18259::::::
rpc:!!:18259::::::
avahi:!!:18259::::::
colord:!!:18259::::::
cups:!!:18259::::::
flatpak:!!:18259::::::
geoclue:!!:18259::::::
git:!!:18259::::::
nm-openconnect:!!:18259::::::
nm-openvpn:!!:18259::::::
ntp:!!:18259::::::
polkitd:!!:18259::::::
rtkit:!!:18259::::::
sddm:!!:18259::::::
tss:!!:18259::::::
usbmux:!!:18259::::::
ystanev:$6$cXRrYnmfCTL3Keg0$M.6dT631WZMYDIgQv4c5mIG7IlQ3zmkrqqIrrfqvuBcBj/mxqMogRzkRiFvXnqbvRjd8Na2HE/4HRm2EhU0mu1:18305:0:99999:7:::
duplicati:!!:18307::::::
dhcpcd:!!:18377::::::
mysql:!*:18446::::::
named:!*:18492::::::
<?xml version="1.0"?>
<!DOCTYPE fontconfig SYSTEM "urn:fontconfig:fonts.dtd">
<!-- /etc/fonts/fonts.conf file to configure system font access -->
<fontconfig>
<its:rules xmlns:its="http://www.w3.org/2005/11/its" version="1.0">
<its:translateRule translate="no" selector="/fontconfig/*[not(self::description)]"/>
</its:rules>
<description>Default configuration file</description>
DO NOT EDIT THIS FILE.
IT WILL BE REPLACED WHEN FONTCONFIG IS UPDATED.
LOCAL CHANGES BELONG IN 'local.conf'.
The intent of this standard configuration file is to be adequate for
most environments. If you have a reasonably normal environment and
have found problems with this configuration, they are probably
things that others will also want fixed. Please submit any
problems to the fontconfig bugzilla system located at fontconfig.org
Note that the normal 'make install' procedure for fontconfig is to
replace any existing fonts.conf file with the new version. Place
any local customizations in local.conf which this file references.
Keith Packard
<!-- Font directory list -->
<dir>/usr/share/fonts</dir>
<dir>/usr/local/share/fonts</dir>
<dir prefix="xdg">fonts</dir>
<!-- the following element will be removed in the future -->
<dir>~/.fonts</dir>
Accept deprecated 'mono' alias, replacing it with 'monospace'
<match target="pattern">
<test qual="any" name="family">
<string>mono</string>
</test>
<edit name="family" mode="assign" binding="same">
<string>monospace</string>
</edit>
</match>
Accept alternate 'sans serif' spelling, replacing it with 'sans-serif'
<string>sans serif</string>
</test>
<string>sans-serif</string>
</edit>
</match>
Accept deprecated 'sans' alias, replacing it with 'sans-serif'
<string>sans</string>
</test>
</edit>
</match>
Accept alternate 'system ui' spelling, replacing it with 'system-ui'
<string>system ui</string>
</test>
<string>system-ui</string>
</edit>
</match>
Load local system customization file
<include ignore_missing="yes">conf.d</include>
<!-- Font cache directory list -->
<cachedir>/var/cache/fontconfig</cachedir>
<cachedir prefix="xdg">fontconfig</cachedir>
<cachedir>~/.fontconfig</cachedir>
<config>
Rescan configuration every 30 seconds when FcFontSetList is called
<rescan>
<int>30</int>
</rescan>
</config>
</fontconfig>
<!DOCTYPE fontconfig SYSTEM "fonts.dtd">
<fontconfig>
</its:rules>
Keith Packard
<dir>~/.fonts</dir>
</test>
</edit>
</match>
</test>
</edit>
</match>
</test>
</edit>
</match>
<config>
<rescan>
<int>30</int>
</rescan>
</config>
</fontconfig>
@users - memlock 1024
# vim:set ft=limits:
# Configuration file for locale-gen
# lists of locales that are to be generated by the locale-gen command.
# Each line is of the form:
# <locale> <charset>
# where <locale> is one of the locales given in /usr/share/i18n/locales
# and <charset> is one of the character sets listed in /usr/share/i18n/charmaps
# Examples:
# en_US ISO-8859-1
# en_US.UTF-8 UTF-8
# de_DE ISO-8859-1
# de_DE@euro ISO-8859-15
# The locale-gen command will generate all the locales,
# placing them in /usr/lib/locale.
# A list of supported locales is included in this file.
# Uncomment the ones you need.
#aa_DJ.UTF-8 UTF-8
#aa_DJ ISO-8859-1
#aa_ER UTF-8
#aa_ER@saaho UTF-8
#aa_ET UTF-8
#af_ZA.UTF-8 UTF-8
#af_ZA ISO-8859-1
#agr_PE UTF-8
#ak_GH UTF-8
#am_ET UTF-8
#an_ES.UTF-8 UTF-8
#an_ES ISO-8859-15
#anp_IN UTF-8
#ar_AE.UTF-8 UTF-8
#ar_AE ISO-8859-6
#ar_BH.UTF-8 UTF-8
#ar_BH ISO-8859-6
#ar_DZ.UTF-8 UTF-8
#ar_DZ ISO-8859-6
#ar_EG.UTF-8 UTF-8
#ar_EG ISO-8859-6
#ar_IN UTF-8
#ar_IQ.UTF-8 UTF-8
#ar_IQ ISO-8859-6
#ar_JO.UTF-8 UTF-8
#ar_JO ISO-8859-6
#ar_KW.UTF-8 UTF-8
#ar_KW ISO-8859-6
#ar_LB.UTF-8 UTF-8
#ar_LB ISO-8859-6
#ar_LY.UTF-8 UTF-8
#ar_LY ISO-8859-6
#ar_MA.UTF-8 UTF-8
#ar_MA ISO-8859-6
#ar_OM.UTF-8 UTF-8
#ar_OM ISO-8859-6
#ar_QA.UTF-8 UTF-8
#ar_QA ISO-8859-6
#ar_SA.UTF-8 UTF-8
#ar_SA ISO-8859-6
#ar_SD.UTF-8 UTF-8
#ar_SD ISO-8859-6
#ar_SS UTF-8
#ar_SY.UTF-8 UTF-8
#ar_SY ISO-8859-6
#ar_TN.UTF-8 UTF-8
#ar_TN ISO-8859-6
#ar_YE.UTF-8 UTF-8
#ar_YE ISO-8859-6
#ayc_PE UTF-8
#az_AZ UTF-8
#az_IR UTF-8
#as_IN UTF-8
#ast_ES.UTF-8 UTF-8
#ast_ES ISO-8859-15
#be_BY.UTF-8 UTF-8
#be_BY CP1251
#be_BY@latin UTF-8
#bem_ZM UTF-8
#ber_DZ UTF-8
#ber_MA UTF-8
#bg_BG.UTF-8 UTF-8
#bg_BG CP1251
#bhb_IN.UTF-8 UTF-8
#bho_IN UTF-8
#bho_NP UTF-8
#bi_VU UTF-8
#bn_BD UTF-8
#bn_IN UTF-8
#bo_CN UTF-8
#bo_IN UTF-8
#br_FR.UTF-8 UTF-8
#br_FR ISO-8859-1
#br_FR@euro ISO-8859-15
#brx_IN UTF-8
#bs_BA.UTF-8 UTF-8
#bs_BA ISO-8859-2
#byn_ER UTF-8
#ca_AD.UTF-8 UTF-8
#ca_AD ISO-8859-15
#ca_ES.UTF-8 UTF-8
#ca_ES ISO-8859-1
#ca_ES@euro ISO-8859-15
#ca_ES@valencia UTF-8
#ca_FR.UTF-8 UTF-8
#ca_FR ISO-8859-15
#ca_IT.UTF-8 UTF-8
#ca_IT ISO-8859-15
#ce_RU UTF-8
#chr_US UTF-8
#ckb_IQ UTF-8
#cmn_TW UTF-8
#crh_UA UTF-8
#cs_CZ.UTF-8 UTF-8
#cs_CZ ISO-8859-2
#csb_PL UTF-8
#cv_RU UTF-8
#cy_GB.UTF-8 UTF-8
#cy_GB ISO-8859-14
#da_DK.UTF-8 UTF-8
#da_DK ISO-8859-1
#de_AT.UTF-8 UTF-8
#de_AT ISO-8859-1
#de_AT@euro ISO-8859-15
#de_BE.UTF-8 UTF-8
#de_BE ISO-8859-1
#de_BE@euro ISO-8859-15
#de_CH.UTF-8 UTF-8
#de_CH ISO-8859-1
#de_DE.UTF-8 UTF-8
#de_DE ISO-8859-1
#de_DE@euro ISO-8859-15
#de_IT.UTF-8 UTF-8
#de_IT ISO-8859-1
#de_LI.UTF-8 UTF-8
#de_LU.UTF-8 UTF-8
#de_LU ISO-8859-1
#de_LU@euro ISO-8859-15
#doi_IN UTF-8
#dsb_DE UTF-8
#dv_MV UTF-8
#dz_BT UTF-8
#el_GR.UTF-8 UTF-8
#el_GR ISO-8859-7
#el_GR@euro ISO-8859-7
#el_CY.UTF-8 UTF-8
#el_CY ISO-8859-7
#en_AG UTF-8
#en_AU.UTF-8 UTF-8
#en_AU ISO-8859-1
#en_BW.UTF-8 UTF-8
#en_BW ISO-8859-1
#en_CA.UTF-8 UTF-8
#en_CA ISO-8859-1
#en_DK.UTF-8 UTF-8
#en_DK ISO-8859-1
#en_GB.UTF-8 UTF-8
#en_GB ISO-8859-1
#en_HK.UTF-8 UTF-8
#en_HK ISO-8859-1
#en_IE.UTF-8 UTF-8
#en_IE ISO-8859-1
#en_IE@euro ISO-8859-15
#en_IL UTF-8
#en_IN UTF-8
#en_NG UTF-8
#en_NZ.UTF-8 UTF-8
#en_NZ ISO-8859-1
#en_PH.UTF-8 UTF-8
#en_PH ISO-8859-1
#en_SC.UTF-8 UTF-8
#en_SG.UTF-8 UTF-8
#en_SG ISO-8859-1
#en_US.UTF-8 UTF-8
#en_US ISO-8859-1
#en_ZA.UTF-8 UTF-8
#en_ZA ISO-8859-1
#en_ZM UTF-8
#en_ZW.UTF-8 UTF-8
#en_ZW ISO-8859-1
#eo UTF-8
#es_AR.UTF-8 UTF-8
#es_AR ISO-8859-1
#es_BO.UTF-8 UTF-8
#es_BO ISO-8859-1
#es_CL.UTF-8 UTF-8
#es_CL ISO-8859-1
#es_CO.UTF-8 UTF-8
#es_CO ISO-8859-1
#es_CR.UTF-8 UTF-8
#es_CR ISO-8859-1
#es_CU UTF-8
#es_DO.UTF-8 UTF-8
#es_DO ISO-8859-1
#es_EC.UTF-8 UTF-8
#es_EC ISO-8859-1
#es_ES.UTF-8 UTF-8
#es_ES ISO-8859-1
#es_ES@euro ISO-8859-15
#es_GT.UTF-8 UTF-8
#es_GT ISO-8859-1
#es_HN.UTF-8 UTF-8
#es_HN ISO-8859-1
#es_MX.UTF-8 UTF-8
#es_MX ISO-8859-1
#es_NI.UTF-8 UTF-8
#es_NI ISO-8859-1
#es_PA.UTF-8 UTF-8
#es_PA ISO-8859-1
#es_PE.UTF-8 UTF-8
#es_PE ISO-8859-1
#es_PR.UTF-8 UTF-8
#es_PR ISO-8859-1
#es_PY.UTF-8 UTF-8
#es_PY ISO-8859-1
#es_SV.UTF-8 UTF-8
#es_SV ISO-8859-1
#es_US.UTF-8 UTF-8
#es_US ISO-8859-1
#es_UY.UTF-8 UTF-8
#es_UY ISO-8859-1
#es_VE.UTF-8 UTF-8
#es_VE ISO-8859-1
#et_EE.UTF-8 UTF-8
#et_EE ISO-8859-1
#et_EE.ISO-8859-15 ISO-8859-15
#eu_ES.UTF-8 UTF-8
#eu_ES ISO-8859-1
#eu_ES@euro ISO-8859-15
#fa_IR UTF-8
#ff_SN UTF-8
#fi_FI.UTF-8 UTF-8
#fi_FI ISO-8859-1
#fi_FI@euro ISO-8859-15
#fil_PH UTF-8
#fo_FO.UTF-8 UTF-8
#fo_FO ISO-8859-1
#fr_BE.UTF-8 UTF-8
#fr_BE ISO-8859-1
#fr_BE@euro ISO-8859-15
#fr_CA.UTF-8 UTF-8
#fr_CA ISO-8859-1
#fr_CH.UTF-8 UTF-8
#fr_CH ISO-8859-1
#fr_FR.UTF-8 UTF-8
#fr_FR ISO-8859-1
#fr_FR@euro ISO-8859-15
#fr_LU.UTF-8 UTF-8
#fr_LU ISO-8859-1
#fr_LU@euro ISO-8859-15
#fur_IT UTF-8
#fy_NL UTF-8
#fy_DE UTF-8
#ga_IE.UTF-8 UTF-8
#ga_IE ISO-8859-1
#ga_IE@euro ISO-8859-15
#gd_GB.UTF-8 UTF-8
#gd_GB ISO-8859-15
#gez_ER UTF-8
#gez_ER@abegede UTF-8
#gez_ET UTF-8
#gez_ET@abegede UTF-8
#gl_ES.UTF-8 UTF-8
#gl_ES ISO-8859-1
#gl_ES@euro ISO-8859-15
#gu_IN UTF-8
#gv_GB.UTF-8 UTF-8
#gv_GB ISO-8859-1
#ha_NG UTF-8
#hak_TW UTF-8
#he_IL.UTF-8 UTF-8
#he_IL ISO-8859-8
#hi_IN UTF-8
#hif_FJ UTF-8
#hne_IN UTF-8
#hr_HR.UTF-8 UTF-8
#hr_HR ISO-8859-2
#hsb_DE ISO-8859-2
#hsb_DE.UTF-8 UTF-8
#ht_HT UTF-8
#hu_HU.UTF-8 UTF-8
#hu_HU ISO-8859-2
#hy_AM UTF-8
#hy_AM.ARMSCII-8 ARMSCII-8
#ia_FR UTF-8
#id_ID.UTF-8 UTF-8
#id_ID ISO-8859-1
#ig_NG UTF-8
#ik_CA UTF-8
#is_IS.UTF-8 UTF-8
#is_IS ISO-8859-1
#it_CH.UTF-8 UTF-8
#it_CH ISO-8859-1
#it_IT.UTF-8 UTF-8
#it_IT ISO-8859-1
#it_IT@euro ISO-8859-15
#iu_CA UTF-8
#ja_JP.EUC-JP EUC-JP
#ja_JP.UTF-8 UTF-8
#ka_GE.UTF-8 UTF-8
#ka_GE GEORGIAN-PS
#kab_DZ UTF-8
#kk_KZ.UTF-8 UTF-8
#kk_KZ PT154
#kl_GL.UTF-8 UTF-8
#kl_GL ISO-8859-1
#km_KH UTF-8
#kn_IN UTF-8
#ko_KR.EUC-KR EUC-KR
#ko_KR.UTF-8 UTF-8
#kok_IN UTF-8
#ks_IN UTF-8
#ks_IN@devanagari UTF-8
#ku_TR.UTF-8 UTF-8
#ku_TR ISO-8859-9
#kw_GB.UTF-8 UTF-8
#kw_GB ISO-8859-1
#ky_KG UTF-8
#lb_LU UTF-8
#lg_UG.UTF-8 UTF-8
#lg_UG ISO-8859-10
#li_BE UTF-8
#li_NL UTF-8
#lij_IT UTF-8
#ln_CD UTF-8
#lo_LA UTF-8
#lt_LT.UTF-8 UTF-8
#lt_LT ISO-8859-13
#lv_LV.UTF-8 UTF-8
#lv_LV ISO-8859-13
#lzh_TW UTF-8
#mag_IN UTF-8
#mai_IN UTF-8
#mai_NP UTF-8
#mfe_MU UTF-8
#mg_MG.UTF-8 UTF-8
#mg_MG ISO-8859-15
#mhr_RU UTF-8
#mi_NZ.UTF-8 UTF-8
#mi_NZ ISO-8859-13
#miq_NI UTF-8
#mjw_IN UTF-8
#mk_MK.UTF-8 UTF-8
#mk_MK ISO-8859-5
#ml_IN UTF-8
#mn_MN UTF-8
#mni_IN UTF-8
#mnw_MM UTF-8
#mr_IN UTF-8
#ms_MY.UTF-8 UTF-8
#ms_MY ISO-8859-1
#mt_MT.UTF-8 UTF-8
#mt_MT ISO-8859-3
#my_MM UTF-8
#nan_TW UTF-8
#nan_TW@latin UTF-8
#nb_NO.UTF-8 UTF-8
#nb_NO ISO-8859-1
#nds_DE UTF-8
#nds_NL UTF-8
#ne_NP UTF-8
#nhn_MX UTF-8
#niu_NU UTF-8
#niu_NZ UTF-8
#nl_AW UTF-8
#nl_BE.UTF-8 UTF-8
#nl_BE ISO-8859-1
#nl_BE@euro ISO-8859-15
#nl_NL.UTF-8 UTF-8
#nl_NL ISO-8859-1
#nl_NL@euro ISO-8859-15
#nn_NO.UTF-8 UTF-8
#nn_NO ISO-8859-1
#nr_ZA UTF-8
#nso_ZA UTF-8
#oc_FR.UTF-8 UTF-8
#oc_FR ISO-8859-1
#om_ET UTF-8
#om_KE.UTF-8 UTF-8
#om_KE ISO-8859-1
#or_IN UTF-8
#os_RU UTF-8
#pa_IN UTF-8
#pa_PK UTF-8
#pap_AW UTF-8
#pap_CW UTF-8
#pl_PL.UTF-8 UTF-8
#pl_PL ISO-8859-2
#ps_AF UTF-8
#pt_BR.UTF-8 UTF-8
#pt_BR ISO-8859-1
#pt_PT.UTF-8 UTF-8
#pt_PT ISO-8859-1
#pt_PT@euro ISO-8859-15
#quz_PE UTF-8
#raj_IN UTF-8
#ro_RO.UTF-8 UTF-8
#ro_RO ISO-8859-2
#ru_RU.KOI8-R KOI8-R
#ru_RU.UTF-8 UTF-8
#ru_RU ISO-8859-5
#ru_UA.UTF-8 UTF-8
#ru_UA KOI8-U
#rw_RW UTF-8
#sa_IN UTF-8
#sah_RU UTF-8
#sat_IN UTF-8
#sc_IT UTF-8
#sd_IN UTF-8
#sd_IN@devanagari UTF-8
#se_NO UTF-8
#sgs_LT UTF-8
#shn_MM UTF-8
#shs_CA UTF-8
#si_LK UTF-8
#sid_ET UTF-8
#sk_SK.UTF-8 UTF-8
#sk_SK ISO-8859-2
#sl_SI.UTF-8 UTF-8
#sl_SI ISO-8859-2
#sm_WS UTF-8
#so_DJ.UTF-8 UTF-8
#so_DJ ISO-8859-1
#so_ET UTF-8
#so_KE.UTF-8 UTF-8
#so_KE ISO-8859-1
#so_SO.UTF-8 UTF-8
#so_SO ISO-8859-1
#sq_AL.UTF-8 UTF-8
#sq_AL ISO-8859-1
#sq_MK UTF-8
#sr_ME UTF-8
#sr_RS UTF-8
#sr_RS@latin UTF-8
#ss_ZA UTF-8
#st_ZA.UTF-8 UTF-8
#st_ZA ISO-8859-1
#sv_FI.UTF-8 UTF-8
#sv_FI ISO-8859-1
#sv_FI@euro ISO-8859-15
#sv_SE.UTF-8 UTF-8
#sv_SE ISO-8859-1
#sw_KE UTF-8
#sw_TZ UTF-8
#szl_PL UTF-8
#ta_IN UTF-8
#ta_LK UTF-8
#tcy_IN.UTF-8 UTF-8
#te_IN UTF-8
#tg_TJ.UTF-8 UTF-8
#tg_TJ KOI8-T
#th_TH.UTF-8 UTF-8
#th_TH TIS-620
#the_NP UTF-8
#ti_ER UTF-8
#ti_ET UTF-8
#tig_ER UTF-8
#tk_TM UTF-8
#tl_PH.UTF-8 UTF-8
#tl_PH ISO-8859-1
#tn_ZA UTF-8
#to_TO UTF-8
#tpi_PG UTF-8
#tr_CY.UTF-8 UTF-8
#tr_CY ISO-8859-9
#tr_TR.UTF-8 UTF-8
#tr_TR ISO-8859-9
#ts_ZA UTF-8
#tt_RU UTF-8
#tt_RU@iqtelif UTF-8
#ug_CN UTF-8
#uk_UA.UTF-8 UTF-8
#uk_UA KOI8-U
#unm_US UTF-8
#ur_IN UTF-8
#ur_PK UTF-8
#uz_UZ.UTF-8 UTF-8
#uz_UZ ISO-8859-1
#uz_UZ@cyrillic UTF-8
#ve_ZA UTF-8
#vi_VN UTF-8
#wa_BE ISO-8859-1
#wa_BE@euro ISO-8859-15
#wa_BE.UTF-8 UTF-8
#wae_CH UTF-8
#wal_ET UTF-8
#wo_SN UTF-8
#xh_ZA.UTF-8 UTF-8
#xh_ZA ISO-8859-1
#yi_US.UTF-8 UTF-8
#yi_US CP1255
#yo_NG UTF-8
#yue_HK UTF-8
#yuw_PG UTF-8
#zh_CN.GB18030 GB18030
#zh_CN.GBK GBK
#zh_CN.UTF-8 UTF-8
#zh_CN GB2312
#zh_HK.UTF-8 UTF-8
#zh_HK BIG5-HKSCS
#zh_SG.UTF-8 UTF-8
#zh_SG.GBK GBK
#zh_SG GB2312
#zh_TW.EUC-TW EUC-TW
#zh_TW.UTF-8 UTF-8
#zh_TW BIG5
#zu_ZA.UTF-8 UTF-8
#zu_ZA ISO-8859-1
/etc/locale.gen
# Examples:
# en_US ISO-8859-1
# en_US.UTF-8 UTF-8
# de_DE ISO-8859-1
#aa_DJ.UTF-8 UTF-8
#aa_DJ ISO-8859-1
#aa_ER UTF-8
#aa_ER@saaho UTF-8
#aa_ET UTF-8
#af_ZA.UTF-8 UTF-8
#af_ZA ISO-8859-1
#agr_PE UTF-8
#ak_GH UTF-8
#am_ET UTF-8
#an_ES.UTF-8 UTF-8
#an_ES ISO-8859-15
#anp_IN UTF-8
#ar_AE.UTF-8 UTF-8
#ar_AE ISO-8859-6
#ar_BH.UTF-8 UTF-8
#ar_BH ISO-8859-6
#ar_DZ.UTF-8 UTF-8
#ar_DZ ISO-8859-6
#ar_EG.UTF-8 UTF-8
#ar_EG ISO-8859-6
#ar_IN UTF-8
#ar_IQ.UTF-8 UTF-8
#ar_IQ ISO-8859-6
#ar_JO.UTF-8 UTF-8
#ar_JO ISO-8859-6
#ar_KW.UTF-8 UTF-8
#ar_KW ISO-8859-6
#ar_LB.UTF-8 UTF-8
#ar_LB ISO-8859-6
#ar_LY.UTF-8 UTF-8
#ar_LY ISO-8859-6
#ar_MA.UTF-8 UTF-8
#ar_MA ISO-8859-6
#ar_OM.UTF-8 UTF-8
#ar_OM ISO-8859-6
#ar_QA.UTF-8 UTF-8
#ar_QA ISO-8859-6
#ar_SA.UTF-8 UTF-8
#ar_SA ISO-8859-6
#ar_SD.UTF-8 UTF-8
#ar_SD ISO-8859-6
#ar_SS UTF-8
#ar_SY.UTF-8 UTF-8
#ar_SY ISO-8859-6
#ar_TN.UTF-8 UTF-8
#ar_TN ISO-8859-6
#ar_YE.UTF-8 UTF-8
#ar_YE ISO-8859-6
#ayc_PE UTF-8
#az_AZ UTF-8
#az_IR UTF-8
#as_IN UTF-8
#ast_ES.UTF-8 UTF-8
#ast_ES ISO-8859-15
#be_BY.UTF-8 UTF-8
#be_BY CP1251
#be_BY@latin UTF-8
#bem_ZM UTF-8
#ber_DZ UTF-8
#ber_MA UTF-8
#bg_BG.UTF-8 UTF-8
#bg_BG CP1251
#bhb_IN.UTF-8 UTF-8
#bho_IN UTF-8
#bho_NP UTF-8
#bi_VU UTF-8
#bn_BD UTF-8
#bn_IN UTF-8
#bo_CN UTF-8
#bo_IN UTF-8
#br_FR.UTF-8 UTF-8
#br_FR ISO-8859-1
#brx_IN UTF-8
#bs_BA.UTF-8 UTF-8
#bs_BA ISO-8859-2
#byn_ER UTF-8
#ca_AD.UTF-8 UTF-8
#ca_AD ISO-8859-15
#ca_ES.UTF-8 UTF-8
#ca_ES ISO-8859-1
#ca_FR.UTF-8 UTF-8
#ca_FR ISO-8859-15
#ca_IT.UTF-8 UTF-8
#ca_IT ISO-8859-15
#ce_RU UTF-8
#chr_US UTF-8
#cmn_TW UTF-8
#crh_UA UTF-8
#cs_CZ.UTF-8 UTF-8
#cs_CZ ISO-8859-2
#csb_PL UTF-8
#cv_RU UTF-8
#cy_GB.UTF-8 UTF-8
#cy_GB ISO-8859-14
#da_DK.UTF-8 UTF-8
#da_DK ISO-8859-1
#de_AT.UTF-8 UTF-8
#de_AT ISO-8859-1
#de_BE.UTF-8 UTF-8
#de_BE ISO-8859-1
#de_CH.UTF-8 UTF-8
#de_CH ISO-8859-1
#de_DE.UTF-8 UTF-8
#de_DE ISO-8859-1
#de_IT.UTF-8 UTF-8
#de_IT ISO-8859-1
#de_LI.UTF-8 UTF-8
#de_LU.UTF-8 UTF-8
#de_LU ISO-8859-1
#doi_IN UTF-8
#dsb_DE UTF-8
#dv_MV UTF-8
#dz_BT UTF-8
#el_GR.UTF-8 UTF-8
#el_GR ISO-8859-7
#el_CY.UTF-8 UTF-8
#el_CY ISO-8859-7
#en_AG UTF-8
#en_AU.UTF-8 UTF-8
#en_AU ISO-8859-1
#en_BW.UTF-8 UTF-8
#en_BW ISO-8859-1
#en_CA.UTF-8 UTF-8
#en_CA ISO-8859-1
#en_DK.UTF-8 UTF-8
#en_DK ISO-8859-1
#en_GB.UTF-8 UTF-8
#en_GB ISO-8859-1
#en_HK.UTF-8 UTF-8
#en_HK ISO-8859-1
#en_IE.UTF-8 UTF-8
#en_IE ISO-8859-1
#en_IL UTF-8
#en_IN UTF-8
#en_NG UTF-8
#en_NZ.UTF-8 UTF-8
#en_NZ ISO-8859-1
#en_PH.UTF-8 UTF-8
#en_PH ISO-8859-1
#en_SC.UTF-8 UTF-8
#en_SG.UTF-8 UTF-8
#en_SG ISO-8859-1
#en_US.UTF-8 UTF-8
#en_US ISO-8859-1
#en_ZA.UTF-8 UTF-8
#en_ZA ISO-8859-1
#en_ZM UTF-8
#en_ZW.UTF-8 UTF-8
#en_ZW ISO-8859-1
#eo UTF-8
#es_AR.UTF-8 UTF-8
#es_AR ISO-8859-1
#es_BO.UTF-8 UTF-8
#es_BO ISO-8859-1
#es_CL.UTF-8 UTF-8
#es_CL ISO-8859-1
#es_CO.UTF-8 UTF-8
#es_CO ISO-8859-1
#es_CR.UTF-8 UTF-8
#es_CR ISO-8859-1
#es_CU UTF-8
#es_DO.UTF-8 UTF-8
#es_DO ISO-8859-1
#es_EC.UTF-8 UTF-8
#es_EC ISO-8859-1
#es_ES.UTF-8 UTF-8
#es_ES ISO-8859-1
#es_GT.UTF-8 UTF-8
#es_GT ISO-8859-1
#es_HN.UTF-8 UTF-8
#es_HN ISO-8859-1
#es_MX.UTF-8 UTF-8
#es_MX ISO-8859-1
#es_NI.UTF-8 UTF-8
#es_NI ISO-8859-1
#es_PA.UTF-8 UTF-8
#es_PA ISO-8859-1
#es_PE.UTF-8 UTF-8
#es_PE ISO-8859-1
#es_PR.UTF-8 UTF-8
#es_PR ISO-8859-1
#es_PY.UTF-8 UTF-8
#es_PY ISO-8859-1
#es_SV.UTF-8 UTF-8
#es_SV ISO-8859-1
#es_US.UTF-8 UTF-8
#es_US ISO-8859-1
#es_UY.UTF-8 UTF-8
#es_UY ISO-8859-1
#es_VE.UTF-8 UTF-8
#es_VE ISO-8859-1
#et_EE.UTF-8 UTF-8
#et_EE ISO-8859-1
#eu_ES.UTF-8 UTF-8
#eu_ES ISO-8859-1
#fa_IR UTF-8
#ff_SN UTF-8
#fi_FI.UTF-8 UTF-8
#fi_FI ISO-8859-1
#fil_PH UTF-8
#fo_FO.UTF-8 UTF-8
#fo_FO ISO-8859-1
#fr_BE.UTF-8 UTF-8
#fr_BE ISO-8859-1
#fr_CA.UTF-8 UTF-8
#fr_CA ISO-8859-1
#fr_CH.UTF-8 UTF-8
#fr_CH ISO-8859-1
#fr_FR.UTF-8 UTF-8
#fr_FR ISO-8859-1
#fr_LU.UTF-8 UTF-8
#fr_LU ISO-8859-1
#fur_IT UTF-8
#fy_NL UTF-8
#fy_DE UTF-8
#ga_IE.UTF-8 UTF-8
#ga_IE ISO-8859-1
#gd_GB.UTF-8 UTF-8
#gd_GB ISO-8859-15
#gez_ER UTF-8
#gez_ET UTF-8
#gl_ES.UTF-8 UTF-8
#gl_ES ISO-8859-1
#gu_IN UTF-8
#gv_GB.UTF-8 UTF-8
#gv_GB ISO-8859-1
#ha_NG UTF-8
#hak_TW UTF-8
#he_IL.UTF-8 UTF-8
#he_IL ISO-8859-8
#hi_IN UTF-8
#hif_FJ UTF-8
#hne_IN UTF-8
#hr_HR.UTF-8 UTF-8
#hr_HR ISO-8859-2
#hsb_DE ISO-8859-2
#hsb_DE.UTF-8 UTF-8
#ht_HT UTF-8
#hu_HU.UTF-8 UTF-8
#hu_HU ISO-8859-2
#hy_AM UTF-8
#ia_FR UTF-8
#id_ID.UTF-8 UTF-8
#id_ID ISO-8859-1
#ig_NG UTF-8
#ik_CA UTF-8
#is_IS.UTF-8 UTF-8
#is_IS ISO-8859-1
#it_CH.UTF-8 UTF-8
#it_CH ISO-8859-1
#it_IT.UTF-8 UTF-8
#it_IT ISO-8859-1
#iu_CA UTF-8
#ja_JP.UTF-8 UTF-8
#ka_GE.UTF-8 UTF-8
#ka_GE GEORGIAN-PS
#kab_DZ UTF-8
#kk_KZ.UTF-8 UTF-8
#kk_KZ PT154
#kl_GL.UTF-8 UTF-8
#kl_GL ISO-8859-1
#km_KH UTF-8
#kn_IN UTF-8
#ko_KR.UTF-8 UTF-8
#kok_IN UTF-8
#ks_IN UTF-8
#ku_TR.UTF-8 UTF-8
#ku_TR ISO-8859-9
#kw_GB.UTF-8 UTF-8
#kw_GB ISO-8859-1
#ky_KG UTF-8
#lb_LU UTF-8
#lg_UG.UTF-8 UTF-8
#lg_UG ISO-8859-10
#li_BE UTF-8
#li_NL UTF-8
#lij_IT UTF-8
#ln_CD UTF-8
#lo_LA UTF-8
#lt_LT.UTF-8 UTF-8
#lt_LT ISO-8859-13
#lv_LV.UTF-8 UTF-8
#lv_LV ISO-8859-13
#lzh_TW UTF-8
#mag_IN UTF-8
#mai_IN UTF-8
#mai_NP UTF-8
#mfe_MU UTF-8
#mg_MG.UTF-8 UTF-8
#mg_MG ISO-8859-15
#mhr_RU UTF-8
#mi_NZ.UTF-8 UTF-8
#mi_NZ ISO-8859-13
#miq_NI UTF-8
#mjw_IN UTF-8
#mk_MK.UTF-8 UTF-8
#mk_MK ISO-8859-5
#ml_IN UTF-8
#mn_MN UTF-8
#mni_IN UTF-8
#mr_IN UTF-8
#ms_MY.UTF-8 UTF-8
#ms_MY ISO-8859-1
#mt_MT.UTF-8 UTF-8
#mt_MT ISO-8859-3
#my_MM UTF-8
#nan_TW UTF-8
#nan_TW@latin UTF-8
#nb_NO.UTF-8 UTF-8
#nb_NO ISO-8859-1
#nds_DE UTF-8
#nds_NL UTF-8
#ne_NP UTF-8
#nhn_MX UTF-8
#niu_NU UTF-8
#niu_NZ UTF-8
#nl_AW UTF-8
#nl_BE.UTF-8 UTF-8
#nl_BE ISO-8859-1
#nl_NL.UTF-8 UTF-8
#nl_NL ISO-8859-1
#nn_NO.UTF-8 UTF-8
#nn_NO ISO-8859-1
#nr_ZA UTF-8
#nso_ZA UTF-8
#oc_FR.UTF-8 UTF-8
#oc_FR ISO-8859-1
#om_ET UTF-8
#om_KE.UTF-8 UTF-8
#om_KE ISO-8859-1
#or_IN UTF-8
#os_RU UTF-8
#pa_IN UTF-8
#pa_PK UTF-8
#pap_AW UTF-8
#pap_CW UTF-8
#pl_PL.UTF-8 UTF-8
#pl_PL ISO-8859-2
#ps_AF UTF-8
#pt_BR.UTF-8 UTF-8
#pt_BR ISO-8859-1
#pt_PT.UTF-8 UTF-8
#pt_PT ISO-8859-1
#quz_PE UTF-8
#raj_IN UTF-8
#ro_RO.UTF-8 UTF-8
#ro_RO ISO-8859-2
#ru_RU.UTF-8 UTF-8
#ru_RU ISO-8859-5
#ru_UA.UTF-8 UTF-8
#ru_UA KOI8-U
#rw_RW UTF-8
#sa_IN UTF-8
#sah_RU UTF-8
#sat_IN UTF-8
#sc_IT UTF-8
#sd_IN UTF-8
#se_NO UTF-8
#sgs_LT UTF-8
#shn_MM UTF-8
#shs_CA UTF-8
#si_LK UTF-8
#sid_ET UTF-8
#sk_SK.UTF-8 UTF-8
#sk_SK ISO-8859-2
#sl_SI.UTF-8 UTF-8
#sl_SI ISO-8859-2
#sm_WS UTF-8
#so_DJ.UTF-8 UTF-8
#so_DJ ISO-8859-1
#so_ET UTF-8
#so_KE.UTF-8 UTF-8
#so_KE ISO-8859-1
#so_SO.UTF-8 UTF-8
#so_SO ISO-8859-1
#sq_AL.UTF-8 UTF-8
#sq_AL ISO-8859-1
#sq_MK UTF-8
#sr_ME UTF-8
#sr_RS UTF-8
#sr_RS@latin UTF-8
#ss_ZA UTF-8
#st_ZA.UTF-8 UTF-8
#st_ZA ISO-8859-1
#sv_FI.UTF-8 UTF-8
#sv_FI ISO-8859-1
#sv_SE.UTF-8 UTF-8
#sv_SE ISO-8859-1
#sw_KE UTF-8
#sw_TZ UTF-8
#szl_PL UTF-8
#ta_IN UTF-8
#ta_LK UTF-8
#tcy_IN.UTF-8 UTF-8
#te_IN UTF-8
#tg_TJ.UTF-8 UTF-8
#tg_TJ KOI8-T
#th_TH.UTF-8 UTF-8
#th_TH TIS-620
#the_NP UTF-8
#ti_ER UTF-8
#ti_ET UTF-8
#tig_ER UTF-8
#tk_TM UTF-8
#tl_PH.UTF-8 UTF-8
#tl_PH ISO-8859-1
#tn_ZA UTF-8
#to_TO UTF-8
#tpi_PG UTF-8
#tr_CY.UTF-8 UTF-8
#tr_CY ISO-8859-9
#tr_TR.UTF-8 UTF-8
#tr_TR ISO-8859-9
#ts_ZA UTF-8
#tt_RU UTF-8
#ug_CN UTF-8
#uk_UA.UTF-8 UTF-8
#uk_UA KOI8-U
#unm_US UTF-8
#ur_IN UTF-8
#ur_PK UTF-8
#uz_UZ.UTF-8 UTF-8
#uz_UZ ISO-8859-1
#ve_ZA UTF-8
#vi_VN UTF-8
#wa_BE ISO-8859-1
#wa_BE.UTF-8 UTF-8
#wae_CH UTF-8
#wal_ET UTF-8
#wo_SN UTF-8
#xh_ZA.UTF-8 UTF-8
#xh_ZA ISO-8859-1
#yi_US.UTF-8 UTF-8
#yi_US CP1255
#yo_NG UTF-8
#yue_HK UTF-8
#yuw_PG UTF-8
#zh_CN.GBK GBK
#zh_CN.UTF-8 UTF-8
#zh_CN GB2312
#zh_HK.UTF-8 UTF-8
#zh_HK BIG5-HKSCS
#zh_SG.UTF-8 UTF-8
#zh_SG.GBK GBK
#zh_SG GB2312
#zh_TW.UTF-8 UTF-8
#zh_TW BIG5
#zu_ZA.UTF-8 UTF-8
#zu_ZA ISO-8859-1
# Locales enabled by Calamares
en_US.UTF-8 UTF-8
en_CA.UTF-8 UTF-8
Looking at it /locale.gen
might cause minor issue which is easy to fix.
fonts.conf
doesn’t have any breaking changes, just a minor adjustment to the spell check.
10-gcr.conf
just removed a comment.
My main concern being /etc/shadow
as that is a huge change and I’m not sure if it’s a breaking change.
I’ve made a backup copy of each of the original files.
What’s the best way to proceed in this case?
Thanks in advance.
