Merging instances of one application in the panel
Hey guys.
As you can see, I’ve opened 3 instances of firefox, 2 of thunar and 2 of vlc, but they are all being shown separately.
Is it possible to have them merged in the panel?
Many thanks
Screenshot_2022-08-06_18-46-01
I haven’t used XFCE for a long time, but there is a setting somewhere that addresses this.
hi,
“right-click” the panel > panel > panel settings > objects > window buttons > edit > window grouping
…you can change between “always” and “never” .
I applied the setting and it worked!
Vielen Danke!
Use “plank” instead of the xfce “window button panels” plugin, Works perfectly with xfce,
I like Windows Buttons, except for the fact that the icons can’t be enlarged. Plank is a great dock, but if you’re just looking for a taskbar plugin:
https://docs.xfce.org/panel-plugins/xfce4-docklike-plugin/start
xfce4-docklike-plugin does allow icon sizing, with appropriate grouping as well.
Jake
