Menus appear on Incorrect Screen
Hi everyone,
I’m experiencing a very frustrating issue with my triple-monitor setup on Manjaro KDE. Whenever I open a window’s properties/settings (e.g., in VLC or Kate), the menu items are consistently displayed on the leftmost monitor(primary Monitor), even though the main window is on the rightmost monitor. If i set primary Monitor to right monitor i have same problem(opposite direction). This makes it nearly impossible to work normally, as I have to physically turn my head and reach across my desk to interact with the menus.
Here’s a summary of the problem:
  • Setup: 3 monitors running on Manjaro KDE Plasma.
  • Issue: When I open the settings/properties of a window (e.g., right-clicking and selecting “Settings” in VLC), the menu that appears is displayed on a completely different screen (the leftmost one), instead of near the main window.
  • Programs Affected: This is happening in multiple applications, including VLC, Kate and Double Commander.
  • Impact: Makes using these programs very difficult because the menus are not accessible in a convenient way.
Things I’ve already checked (and haven’t resolved the issue):
  • Monitor Configuration in KDE: I’ve carefully verified the monitor order, resolution, scaling, and primary monitor settings in KDE’s “Display and Monitor” settings. The physical arrangement matches the settings. Tried switching which is the primary monitor with no luck.
  • KDE Window Behavior: I’ve experimented with different window placement and focus settings in KDE’s “Window Management” options.
  • KDE Compositor: Verified the compositor is enabled
  • Application-Specific Settings: I initially thought it was a VLC issue, but it’s happening in multiple unrelated applications now.
  • Wayland/X11: I’m currently using X11.
System Information:
  • Operating System: Manjaro Linux
  • KDE Plasma Version: 6.3.3
  • KDE Frameworks Version: 6.11.0
  • Qt Version: 6.8.2
  • Kernel Version: 6.12.19-1-MANJARO (64-bit)
  • Graphics Platform: X11
  • Processors: 16 × AMD Ryzen 7 3700X 8-Core Processor
  • Graphics: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2 (x2 – SLI is disabled)
Could anyone offer any advice on how to troubleshoot or fix this misplaced menu issue? Any help would be greatly appreciated
Thanks in advance
The information from *-fetch type programs might be fine for someone wishing to buy your computer, but for Support purposes it’s best to ask your system directly, to produce more useful information.
System Information:
inxi -zv8
Privacy:- Those with privacy concerns, note that when -z is used, all personally identifiable information is filtered out from the resulting inxi output.
  Kernel: 6.12.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=facac5d6-e4b0-4883-9af6-04b0966b2399 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.11.0
    wm: kwin_x11 tools: avail: xfce4-screensaver vt: 2 dm: 1: LightDM v: 1.32.0
    note: stopped 2: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: Micro-Star model: MPG X570 GAMING PLUS (MS-7C37) v: 2.0
    serial: <superuser required> uuid: <superuser required>
    UEFI: American Megatrends v: A.40 date: 09/10/2019
  System RAM: total: 32 GiB available: 31.29 GiB used: 7.26 GiB (23.2%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 16 GiB speed: spec: 2133 MT/s actual: 1067 MT/s
    volts: note: check curr: 1 min: 1 max: 1 width (bits): data: 64 total: 64
    manufacturer: G.Skill part-no: F4-3200C16-16GVK serial: N/A
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 2
    level: v3 note: check built: 2020-22 process: TSMC n7 (7nm)
    family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701034
    desc: 8x512 KiB L3: 32 MiB desc: 2x16 MiB
  Speed (MHz): avg: 2213 min/max: 2200/4426 boost: enabled scaling:
    driver: acpi-cpufreq governor: schedutil cores: 1: 2213 2: 2213 3: 2213
    4: 2213 5: 2213 6: 2213 7: 2213 8: 2213 9: 2213 10: 2213 11: 2213 12: 2213
    13: 2213 14: 2213 15: 2213 16: 2213 bogomips: 115233
    f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
    pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
    rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
    sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
    tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme
    vmmcall wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xtopology
  Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
    protection
    always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nvidia v: 550.144.03
    alternate: nouveau,nvidia_drm non-free: 550/565.xx+ status: current (as of
    2025-01; EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
    built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports: active: none
    off: DP-1,HDMI-A-1 empty: DVI-D-1 bus-ID: 2d:00.0 chip-ID: 10de:1c82
    class-ID: 0300
  Device-2: Logitech HD Webcam C910 driver: snd-usb-audio,uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-2:3 chip-ID: 046d:0821
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia
    gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3000x1920 s-dpi: 94 s-size: 811x519mm (31.93x20.43")
    s-diag: 963mm (37.91")
  Monitor-1: DP-1 pos: bottom-l res: mode: 1920x1080 hz: 60 scale: 100% (1)
    dpi: 93 size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
  Monitor-2: HDMI-0 pos: primary,top-right res: mode: 1920x1080 hz: 60
    scale: 177% (0.5625) to: 1080x1920 dpi: 96 size: 510x287mm (20.08x11.3")
    diag: 585mm (23.04") modes: N/A
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
    drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
  API: OpenGL v: 4.6.0 vendor: nvidia v: 550.144.03 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2
    memory: 3.91 GiB
  API: Vulkan v: 1.4.304 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
    GeForce GTX 1050 Ti driver: N/A device-ID: 10de:1c82 surfaces: xcb,xlib
  Info: Tools: api: clinfo, eglinfo, glxinfo, vulkaninfo de: kscreen-console,
    kscreen-doctor, xfce4-display-settings gpu: nvidia-settings,nvidia-smi
  Device-1: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 2d:00.1
    chip-ID: 10de:0fb9 class-ID: 0403
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Logitech HD Webcam C910 driver: snd-usb-audio,uvcvideo type: USB
  Device-4: Plantronics Savi 7xx driver: plantronics,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2:3
    chip-ID: 047f:ac01 class-ID: 0300 serial: <filter>
  API: ALSA v: k6.12.19-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
    vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8168
    class-ID: 0200
  IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 2.05 TiB used: 260.74 GiB (12.4%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Crucial model: CT1000P1SSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P3CR013 temp: 31.9 C
    scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 840 PRO Series
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 4B0Q scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 1TB
    tech: SSD serial: <filter> fw-rev: 3B6Q scheme: GPT
  ID-1: / raw-size: 931.22 GiB size: 915.53 GiB (98.32%)
    used: 260.74 GiB (28.5%) fs: ext4 dev: /dev/sdb2 maj-min: 8:18 label: N/A
    uuid: facac5d6-e4b0-4883-9af6-04b0966b2399
    used: 288 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: N/A
    uuid: A549-2BF6
  ID-3: /tmp/.mount_15390209352524659314 raw-size: N/A size: 100.2 MiB
    used: 100.2 MiB (100.0%) fs: fuse.squashfuse source: ERR-102
  ID-1: /dev/nvme0n1p2 maj-min: 259:1 size: 931.01 GiB fs: ext4
    label: dev/nvme 1100MBs uuid: 2398230e-4ed4-41ab-9ee3-a6e47e9ec276
  ID-2: /dev/sda1 maj-min: 8:1 size: 512 MiB fs: vfat label: N/A
    uuid: A0BF-0D62
  ID-3: /dev/sda2 maj-min: 8:2 size: 237.97 GiB fs: ext4 label: N/A
    uuid: 803625e1-048d-47f9-a440-1ff26ea65c99
  Device-1: 1-1:2 info: Sunplus Innovation Optical Mouse type: mouse
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 98mA
    chip-ID: 1bcf:0005 class-ID: 0301
  Device-2: 1-2:3 info: Logitech HD Webcam C910 type: audio,video
    chip-ID: 046d:0821 class-ID: 0e02 serial: <filter>
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
  Device-1: 3-1:2 info: Microsoft Natural Keyboard Elite type: keyboard
    driver: hid-generic,usbhid interfaces: 1 rev: 1.0
    chip-ID: 045e:000b class-ID: 0301
  Device-2: 3-2:3 info: Plantronics Savi 7xx type: audio,HID
    driver: plantronics,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 047f:ac01
  Device-3: 3-5:4 info: Micro Star MYSTIC LIGHT type: HID
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 1462:7c37 class-ID: 0300
    serial: <filter>
  Hub-4: 3-6:5 info: Genesys Logic Hub ports: 4 rev: 2.0
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-6: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 5-3:2 info: Sunplus Innovation Optical Mouse type: mouse
  Hub-7: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
  System Temperatures: cpu: 57.6 C mobo: N/A gpu: nvidia temp: 36 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 20%
  Packages: 1552 pm: pacman pkgs: 1545 libs: 394 tools: pamac,yay pm: flatpak
    pkgs: 7
    1: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    2: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    3: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    4: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    5: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    6: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    7: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    8: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    9: https://ftp.caliu.cat/pub/distribucions/manjaro/stable/$repo/$arch
    10: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    11: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    12: https://manjaro.kurdy.org/stable/$repo/$arch
    13: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    14: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    15: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    16: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    17: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    18: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    19: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    20: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    21: https://mirrors2.manjaro.org/stable/$repo/$arch
    22: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    23: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    24: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    25: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    26: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    27: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    28: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    29: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    30: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    31: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    32: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    33: https://mirror.init7.net/manjaro/stable/$repo/$arch
    34: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    35: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    36: https://mirror.hostiko.network/manjaro/stable/$repo/$arch
    37: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    38: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    39: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    40: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    41: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    42: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    43: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    44: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    45: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    46: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    47: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    48: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    49: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    50: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    51: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    52: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    53: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    54: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    55: https://manjaro.ynh.ovh/stable/$repo/$arch
    56: http://manjaro.grena.ge/stable/$repo/$arch
    57: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    58: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    59: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    60: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    61: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    62: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    63: https://mirrors.eric.ovh/manjaro/stable/$repo/$arch
    64: https://mirror.23m.com/manjaro/stable/$repo/$arch
    65: https://linorg.usp.br/manjaro/stable/$repo/$arch
    66: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    67: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    68: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    69: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    70: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    71: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    72: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    73: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    74: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    75: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    76: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    77: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    78: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    79: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    80: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    81: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    82: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    83: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    84: https://mirrors.pku.edu.cn/manjaro/stable/$repo/$arch
    85: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    86: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    87: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    88: https://bd.mirror.vanehost.com/Manjaro/stable/$repo/$arch
    89: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    90: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    91: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    92: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    93: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    94: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    95: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    96: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    97: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    98: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    99: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    100: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    101: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    102: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    103: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    104: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    105: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 398
  1: cpu: 3.5% command: zen pid: 1403 mem: 1894.1 MiB (5.9%)
  2: cpu: 2.1% command: zen pid: 7190 mem: 349.8 MiB (1.0%)
  3: cpu: 2.0% command: zen pid: 1340 mem: 839.7 MiB (2.6%)
  4: cpu: 1.4% command: zen pid: 14361 mem: 321.8 MiB (1.0%)
  5: cpu: 1.3% command: zen pid: 13615 mem: 323.6 MiB (1.0%)
  Memory top: 5 of 398
  1: mem: 1894.1 MiB (5.9%) command: zen pid: 1403 cpu: 3.5%
  2: mem: 839.7 MiB (2.6%) command: zen pid: 1340 cpu: 2.0%
  3: mem: 823.2 MiB (2.5%) command: plasmashell pid: 902 cpu: 0.3%
  4: mem: 396.8 MiB (1.2%) command: zen pid: 1553 cpu: 0.9%
  5: mem: 372.9 MiB (1.1%) command: zen pid: 12033 cpu: 0.4%
  Processes: 398 Power: uptime: 4h 30m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.37
The Problem seems also good described (with screenshots) here: https://www.reddit.com/r/kde/comments/1bdopmf/how_do_i_fix_this_the_rigjtclick_context_menu_is/
found a workaround that works a little bit:
Copy1533
vor 3 Jahren
I cannot believe that. The problem was really fixed by moving one monitor slightly up in the display configuration, thanks!
Avatar von u/SL5net
SL5net
vor 1 m
yes works here. problem is: i need other monitor setup. my two monitors looks like: ==
if i set the top same for both it works but its not useful for me
You might also try using Wayland instead, and experimenting with the finer grained setting as compared to X11. That said, as you’re using Nvidia, you might introduce other unrelated issues in the process.
