2 displays connected with DisplayPorts, with a resolution of 3840x2160. I set the zoom factor to 200% because otherwise, everything is too small for me to read. Now, here’s the issue:
When I right-click on the desktop, I only see the top left quarter of the menu. When I move the mouse over where the rest should be, the pointer acts as if there is more to the menu, but it is not visible. How can I fix this?
Just in case you need it, here is the output of inxi and mhwd
inxi -v7azy
Kernel: 6.1.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=924095d4-0579-4229-9d54-6fb389299be2 rw quiet apparmor=1
Desktop: Cinnamon v: 5.6.4 tk: GTK v: 3.24.35 vt: 7 dm: LightDM v: 1.32.0
Type: Desktop Mobo: Gigabyte model: B450M DS3H V2 v: x.x
serial: <superuser required> UEFI-[Legacy]: American Megatrends v: F1
date: 08/17/2020
RAM: total: 62.75 GiB used: 2.99 GiB (4.8%)
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 2400 high: 3800 min/max: 2200/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3800 2: 2200
3: 2200 4: 2200 5: 2200 6: 2200 7: 2200 8: 3800 9: 2200 10: 2200 11: 2200
12: 2200 13: 2200 14: 2200 15: 2200 16: 2200 17: 2200 18: 2200 19: 2200
20: 2200 21: 2200 22: 2200 23: 3800 24: 2200 bogomips: 182137
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: PNY driver: nvidia
v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 2 speed: 5 GT/s lanes: 16
link-max: gen: 4 speed: 16 GT/s bus-ID: 06:00.0 chip-ID: 10de:2484
class-ID: 0300
Device-2: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 3-1:2 chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.6 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 159 s-size: 613x352mm (24.13x13.86")
s-diag: 707mm (27.83")
Monitor-1: DP-4 res: 3840x2160 hz: 60 dpi: 161
size: 607x345mm (23.9x13.58") diag: 698mm (27.49") modes: N/A
API: OpenGL Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: NVIDIA GA104 High Definition Audio vendor: PNY
driver: snd_hda_intel v: kernel bus-ID: 1-9.1:5 chip-ID: 0d8c:000e pcie:
class-ID: 0300 gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 06:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Gigabyte
bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: C-Media Audio Adapter (Planet UP-100 Genius G-Talk) type: USB
driver: cm109,snd-usb-audio
Device-4: Logitech Webcam C270 type: USB driver: snd-usb-audio,uvcvideo
Sound API: ALSA v: k6.1.0-1-MANJARO running: yes
Sound Server-3: PipeWire v: 0.3.63 running: yes
lanes: 1 port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp4s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 953.87 GiB used: 15.67 GiB (1.6%)
ID-1: /dev/sda maj-min: 8:0 vendor: Silicon Power
model: SPCC Solid State Disk size: 953.87 GiB block-size: physical: 512 B
logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 9A0
scheme: MBR
ID-1: / raw-size: 953.86 GiB size: 937.82 GiB (98.32%) used: 15.67 GiB (1.7%)
fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 924095d4-0579-4229-9d54-6fb389299be2
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-5:2 info: Micro Star MSI GM20 Elite type: Keyboard,Mouse
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
chip-ID: 0db0:0d2e class-ID: 0301 serial: <filter>
Device-2: 1-6:3 info: Holtek USB-HID Keyboard type: Keyboard,HID
driver: hid-generic,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 100mA
chip-ID: 04d9:018b class-ID: 0300
Hub-2: 1-9:4 info: Genesys Logic USB 2.0 Hub / D-Link DUB-H4 ports: 4
rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 05e3:0606 class-ID: 0900
Device-1: 1-9.1:5 info: C-Media Audio Adapter (Planet UP-100 Genius G-Talk)
type: Audio,HID driver: cm109,snd-usb-audio interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:000e class-ID: 0300
Device-2: 1-9.4:6 info: Yubicom Yubikey 4/5 OTP+U2F+CCID
type: Keyboard,HID,Smart Card driver: hid-generic,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 30mA chip-ID: 1050:0407 class-ID: 0b00
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Device-1: 3-1:2 info: Logitech Webcam C270 type: Video,Audio
power: 500mA chip-ID: 046d:0825 class-ID: 0102 serial: <filter>
Device-2: 3-3:3 info: Logitech 3Dconnexion Space Mouse Pro type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046d:c62b class-ID: 0300
Hub-5: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 50.6 C mobo: N/A gpu: nvidia temp: 56 C
Processes: 379 Uptime: 1h 19m wakeups: 0 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: pm: pacman pkgs: 1181 libs: 346 tools: pamac,paru,yay pm: flatpak
pkgs: 0 Shell: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.24
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-nvidia 2021.11.04 false PCI
