Searching this returns a 2x8gb package (16gb total).
Ex: https://www.corsair.com/us/en/search?q=CMR16GX4M2Z2933C16
Someone or something is confused along the way here.
This is on one plate in plain text. Do they mean the plates go in pairs?
That means that each stick is 8gb. Which is what your system shows.
But apparently different than what you thought to expect.
In order for you to have 16gb total you would need to use 2 sticks of that RAM.
In order for you to have 32gb total you would need to use 4 sticks of that RAM.
I’m not sure what you mean … but yes?
They are sold in pairs.
The package is supposed to give you 16gb total. By providing 2 8gb sticks (2x8GB
@cscs is right, a “memory kit” means total memory with more than one module.
Did your memory came in a box like this?
Dmidecode shows is working at 2667 mhz to synchonize with the other (slower) modules. In which slots are the new modules (A1,A2,B1,B2)?
If the output showed was in full … then there are no other modules.
One wonders if there is some BIOS setting … or if the hardware does not support higher clocks**?
** EDIT - I looked up the mobo “PRO B550M-P GEN3” and thats not it.
Supports DDR4 Memory, up to 4400(OC) MHz
It’s second hand, w/o a box, but otherwise it looks exactly like on your pic
Yes, now that you mention it, at different reboots it showed slightly different frequency, but never more than 29xx MHz.
Oooppss… I shouldn’t write posts early in the morning until the first coffee.
