Hello, I am new user and new also for Majaro. I have a pi4 and I am going to start using this SO, coming from Raspian experience.
I would like to use the fan hat just used till now, the melopero fan hat, which works with python pip3.
Could some one help me? I am not yet common with pacman commands instead of sudo apt.
Many thanks
Open a terminal.
man pacman
man pamac
Open a browser, search:
beginner guide pacman
pacman cheat sheet
beginner guide pamac
That should keep you busy for a while.
Make notes, maybe use conky to put them on the desktop…
Something like this:
sudo apt install package = sudo pacman -S package = pamac install package
You’ll get the idea.
Pamac is a little more like ‘apt’ in that it uses more of a natural English syntax…
https://wiki.manjaro.org/index.php?title=Pamac#Using_the_Pamac_CLI
Internet is your friend.
However, to install fan hat you should use pip3 install
so I guess you didn’t read that guide either.
Hello, manu thanks for your support, now better. I tried to read guides for pip3 install, I did the command.
There came many errors, such as ERROR: Failed building wheel for RPi.GPIO
I install python 3, but no result.
Could you help me? Many thanks
I looked here:
I tried:
sudo pip3 install --no-cache melopero-fan-hat
Yes, many errors…
Sorry, I don’t know how to fix this.
╭─ ~ ─────────────────────────────────────────────────────────────────────────────────────── ✔ at 08:51:09 ─╮
╰─ sudo pip3 install --no-cache melopero-fan-hat ─╯
[sudo] password for ben:
Collecting melopero-fan-hat
Downloading melopero_fan_hat-0.0.6.tar.gz (3.0 kB)
Collecting melopero_autostart>=0.0.7
Downloading melopero_autostart-0.1.0.tar.gz (2.8 kB)
Collecting RPi.GPIO
Downloading RPi.GPIO-0.7.0.tar.gz (30 kB)
Building wheels for collected packages: melopero-fan-hat, melopero-autostart, RPi.GPIO
Building wheel for melopero-fan-hat (setup.py) ... done
Created wheel for melopero-fan-hat: filename=melopero_fan_hat-0.0.6-py3-none-any.whl size=2812 sha256=1e2af726b8a0b0898f8142344be463354a516548577d39838d3fe836206a7227
Stored in directory: /tmp/pip-ephem-wheel-cache-ca71gpxz/wheels/84/0c/c7/d4f1773c776b7651cb2474e79c176454d68fc0978e83371b87
Building wheel for melopero-autostart (setup.py) ... done
Created wheel for melopero-autostart: filename=melopero_autostart-0.1.0-py3-none-any.whl size=3468 sha256=e4317daf42b6b9d293db5fd15ef94f60664bde5eb3a836389e445a60a879ad45
Stored in directory: /tmp/pip-ephem-wheel-cache-ca71gpxz/wheels/7b/9b/6b/1d2fad55cc1062e0e58ab4b0da5a1a4cdd48b60d867d43e945
Building wheel for RPi.GPIO (setup.py) ... error
ERROR: Command errored out with exit status 1:
command: /usr/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/setup.py'"'"'; __file__='"'"'/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-ndehskvz
cwd: /tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/
Complete output (102 lines):
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-x86_64-3.9
creating build/lib.linux-x86_64-3.9/RPi
copying RPi/__init__.py -> build/lib.linux-x86_64-3.9/RPi
creating build/lib.linux-x86_64-3.9/RPi/GPIO
copying RPi/GPIO/__init__.py -> build/lib.linux-x86_64-3.9/RPi/GPIO
running build_ext
building 'RPi._GPIO' extension
creating build/temp.linux-x86_64-3.9
creating build/temp.linux-x86_64-3.9/source
gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -march=x86-64 -mtune=generic -O3 -pipe -fno-plt -fno-semantic-interposition -march=x86-64 -mtune=generic -O3 -pipe -fno-plt -march=x86-64 -mtune=generic -O3 -pipe -fno-plt -fPIC -I/usr/include/python3.9 -c source/c_gpio.c -o build/temp.linux-x86_64-3.9/source/c_gpio.o
source/c_gpio.c: In function ‘setup’:
source/c_gpio.c:130:9: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
130 | if ((uint32_t)gpio_mem % PAGE_SIZE)
source/c_gpio.c:131:34: warning: cast from pointer to integer of different size [-Wpointer-to-int-cast]
131 | gpio_mem += PAGE_SIZE - ((uint32_t)gpio_mem % PAGE_SIZE);
gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -march=x86-64 -mtune=generic -O3 -pipe -fno-plt -fno-semantic-interposition -march=x86-64 -mtune=generic -O3 -pipe -fno-plt -march=x86-64 -mtune=generic -O3 -pipe -fno-plt -fPIC -I/usr/include/python3.9 -c source/common.c -o build/temp.linux-x86_64-3.9/source/common.o
gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -march=x86-64 -mtune=generic -O3 -pipe -fno-plt -fno-semantic-interposition -march=x86-64 -mtune=generic -O3 -pipe -fno-plt -march=x86-64 -mtune=generic -O3 -pipe -fno-plt -fPIC -I/usr/include/python3.9 -c source/constants.c -o build/temp.linux-x86_64-3.9/source/constants.o
gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -march=x86-64 -mtune=generic -O3 -pipe -fno-plt -fno-semantic-interposition -march=x86-64 -mtune=generic -O3 -pipe -fno-plt -march=x86-64 -mtune=generic -O3 -pipe -fno-plt -fPIC -I/usr/include/python3.9 -c source/cpuinfo.c -o build/temp.linux-x86_64-3.9/source/cpuinfo.o
source/cpuinfo.c: In function ‘get_rpi_info’:
source/cpuinfo.c:139:28: warning: format ‘%llx’ expects argument of type ‘long long unsigned int *’, but argument 3 has type ‘uint64_t *’ {aka ‘long unsigned int *’} [-Wformat=]
139 | sscanf(revision, "%llx", &rev);
| | uint64_t * {aka long unsigned int *}
| %lx
gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -march=x86-64 -mtune=generic -O3 -pipe -fno-plt -fno-semantic-interposition -march=x86-64 -mtune=generic -O3 -pipe -fno-plt -march=x86-64 -mtune=generic -O3 -pipe -fno-plt -fPIC -I/usr/include/python3.9 -c source/event_gpio.c -o build/temp.linux-x86_64-3.9/source/event_gpio.o
gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -march=x86-64 -mtune=generic -O3 -pipe -fno-plt -fno-semantic-interposition -march=x86-64 -mtune=generic -O3 -pipe -fno-plt -march=x86-64 -mtune=generic -O3 -pipe -fno-plt -fPIC -I/usr/include/python3.9 -c source/py_gpio.c -o build/temp.linux-x86_64-3.9/source/py_gpio.o
source/py_gpio.c: In function ‘PyInit__GPIO’:
source/py_gpio.c:1046:4: warning: ‘PyEval_ThreadsInitialized’ is deprecated [-Wdeprecated-declarations]
1046 | if (!PyEval_ThreadsInitialized())
In file included from /usr/include/python3.9/Python.h:145,
from source/py_gpio.c:23:
/usr/include/python3.9/ceval.h:129:36: note: declared here
129 | Py_DEPRECATED(3.9) PyAPI_FUNC(int) PyEval_ThreadsInitialized(void);
source/py_gpio.c:1047:7: warning: ‘PyEval_InitThreads’ is deprecated [-Wdeprecated-declarations]
1047 | PyEval_InitThreads();
/usr/include/python3.9/ceval.h:130:37: note: declared here
130 | Py_DEPRECATED(3.9) PyAPI_FUNC(void) PyEval_InitThreads(void);
gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -march=x86-64 -mtune=generic -O3 -pipe -fno-plt -fno-semantic-interposition -march=x86-64 -mtune=generic -O3 -pipe -fno-plt -march=x86-64 -mtune=generic -O3 -pipe -fno-plt -fPIC -I/usr/include/python3.9 -c source/py_pwm.c -o build/temp.linux-x86_64-3.9/source/py_pwm.o
gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O3 -Wall -march=x86-64 -mtune=generic -O3 -pipe -fno-plt -fno-semantic-interposition -march=x86-64 -mtune=generic -O3 -pipe -fno-plt -march=x86-64 -mtune=generic -O3 -pipe -fno-plt -fPIC -I/usr/include/python3.9 -c source/soft_pwm.c -o build/temp.linux-x86_64-3.9/source/soft_pwm.o
gcc -pthread -shared -Wl,-O1,--sort-common,--as-needed,-z,relro,-z,now -fno-semantic-interposition -Wl,-O1,--sort-common,--as-needed,-z,relro,-z,now build/temp.linux-x86_64-3.9/source/c_gpio.o build/temp.linux-x86_64-3.9/source/common.o build/temp.linux-x86_64-3.9/source/constants.o build/temp.linux-x86_64-3.9/source/cpuinfo.o build/temp.linux-x86_64-3.9/source/event_gpio.o build/temp.linux-x86_64-3.9/source/py_gpio.o build/temp.linux-x86_64-3.9/source/py_pwm.o build/temp.linux-x86_64-3.9/source/soft_pwm.o -L/usr/lib -o build/lib.linux-x86_64-3.9/RPi/_GPIO.cpython-39-x86_64-linux-gnu.so
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:41: multiple definition of `module_setup'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:41: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:40: multiple definition of `setup_error'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:40: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:39: multiple definition of `rpiinfo'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:39: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:38: multiple definition of `gpio_direction'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:38: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:37: multiple definition of `pin_to_gpio'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:37: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:36: multiple definition of `pin_to_gpio_rev3'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:36: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:35: multiple definition of `pin_to_gpio_rev2'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:35: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:34: multiple definition of `pin_to_gpio_rev1'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:34: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:33: multiple definition of `gpio_mode'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:33: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:33: multiple definition of `gpio_mode'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:33: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:40: multiple definition of `setup_error'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:40: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:39: multiple definition of `rpiinfo'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:39: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:38: multiple definition of `gpio_direction'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:38: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:37: multiple definition of `pin_to_gpio'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:37: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:41: multiple definition of `module_setup'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:41: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:36: multiple definition of `pin_to_gpio_rev3'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:36: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:34: multiple definition of `pin_to_gpio_rev1'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:34: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:35: multiple definition of `pin_to_gpio_rev2'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:35: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:42: multiple definition of `both_edge'; build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:42: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:41: multiple definition of `falling_edge'; build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:41: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:40: multiple definition of `rising_edge'; build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:40: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:39: multiple definition of `pud_down'; build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:39: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:38: multiple definition of `pud_up'; build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:38: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:37: multiple definition of `pud_off'; build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:37: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:36: multiple definition of `bcm'; build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:36: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:35: multiple definition of `board'; build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:35: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:34: multiple definition of `unknown'; build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:34: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:33: multiple definition of `spi'; build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:33: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:32: multiple definition of `i2c'; build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:32: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:31: multiple definition of `serial'; build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:31: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:30: multiple definition of `pwm'; build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:30: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:29: multiple definition of `output'; build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:29: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:28: multiple definition of `input'; build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:28: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:27: multiple definition of `low'; build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:27: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:26: multiple definition of `high'; build/temp.linux-x86_64-3.9/source/constants.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/constants.h:26: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_pwm.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:38: multiple definition of `gpio_direction'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:38: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_pwm.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/py_pwm.h:23: multiple definition of `PWMType'; build/temp.linux-x86_64-3.9/source/py_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/py_pwm.h:23: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_pwm.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:41: multiple definition of `module_setup'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:41: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_pwm.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:40: multiple definition of `setup_error'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:40: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_pwm.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:39: multiple definition of `rpiinfo'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:39: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_pwm.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:37: multiple definition of `pin_to_gpio'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:37: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_pwm.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:36: multiple definition of `pin_to_gpio_rev3'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:36: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_pwm.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:35: multiple definition of `pin_to_gpio_rev2'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:35: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_pwm.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:34: multiple definition of `pin_to_gpio_rev1'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:34: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/py_pwm.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:33: multiple definition of `gpio_mode'; build/temp.linux-x86_64-3.9/source/common.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/common.h:33: first defined here
/usr/bin/ld: build/temp.linux-x86_64-3.9/source/soft_pwm.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/soft_pwm.c:28: multiple definition of `threads'; build/temp.linux-x86_64-3.9/source/event_gpio.o:/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/source/event_gpio.c:60: first defined here
collect2: error: ld returned 1 exit status
error: command '/usr/bin/gcc' failed with exit code 1
Running setup.py clean for RPi.GPIO
Successfully built melopero-fan-hat melopero-autostart
Failed to build RPi.GPIO
Installing collected packages: RPi.GPIO, melopero-autostart, melopero-fan-hat
Running setup.py install for RPi.GPIO ... error
command: /usr/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/setup.py'"'"'; __file__='"'"'/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-3t55r26k/install-record.txt --single-version-externally-managed --compile --install-headers /usr/include/python3.9/RPi.GPIO
running install
running build
running build_py
creating build
running build_ext
| %lx
ERROR: Command errored out with exit status 1: /usr/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/setup.py'"'"'; __file__='"'"'/tmp/pip-install-juljirim/rpi-gpio_c6a207ccba674a00b7b92081ca2b3fae/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-3t55r26k/install-record.txt --single-version-externally-managed --compile --install-headers /usr/include/python3.9/RPi.GPIO Check the logs for full command output.
╭─ ~ ──────────────────────────────────────────────────────────────────────── 1 ✘ took 10s at 08:51:25 ─╮
Hi: many thanks for your efforts, I had the same errors. No problem, I appreciate your help.
What does “Building wheel for RPi.GPIO (setup.py) … error” mean?
The default RPi.GPIO-0.7.0 has been broken for a few months now since our python upgrade.
Try this and see what it does:
sudo pip install --pre RPi.GPIO
sudo pip install --no-cache melopero-fan-hat
It answers “sudo: pip: comand not found”
Should be pip3
This works for me. I use this for odroid led
sudo pip3 install RPi.GPIO==0.7.1a2
After running the above command you should have Rpi.Gpio installed then you can install the hat support pkg
Wonder why you all’s install is different from mine. Anyway the commands I posted above worked for me here with no errors. Use pip3 instead.
Summary
[ray@pi4 ~]$ sudo pip install --pre RPi.GPIO
Collecting RPi.GPIO
Using cached RPi.GPIO-0.7.1a4.tar.gz (29 kB)
Building wheels for collected packages: RPi.GPIO
Building wheel for RPi.GPIO (setup.py) … done
Created wheel for RPi.GPIO: filename=RPi.GPIO-0.7.1a4-cp39-cp39-linux_aarch64.whl size=75934 sha256=5695b6a7aae6f14879e2e8a9d06426ca2095ef965b38db12282245e3ed810bb9
Stored in directory: /root/.cache/pip/wheels/6f/1c/5c/113894ea5785c8856518ad0d88803c2ec7cbc6cb88e47f2e04
Successfully built RPi.GPIO
Successfully installed RPi.GPIO-0.7.1a4
[ray@pi4 ~]$
[ray@pi4 ~]$ sudo pip install --no-cache melopero-fan-hat
Requirement already satisfied: melopero_autostart>=0.0.7 in /usr/lib/python3.9/site-packages (from melopero-fan-hat) (0.1.0)
Requirement already satisfied: RPi.GPIO in /usr/lib/python3.9/site-packages (from melopero-fan-hat) (0.7.1a4)
Building wheel for melopero-fan-hat (setup.py) … done
Created wheel for melopero-fan-hat: filename=melopero_fan_hat-0.0.6-py3-none-any.whl size=2812 sha256=aedf43561d3fcfd6e6b5c06fda211c77f7d3a488ad62abf84268c3dd5eb02f7e
Stored in directory: /tmp/pip-ephem-wheel-cache-fbiynszk/wheels/84/0c/c7/d4f1773c776b7651cb2474e79c176454d68fc0978e83371b87
Installing collected packages: melopero-fan-hat
Successfully installed melopero-fan-hat-0.0.6
[ray@pi4 ~]$
Good.
I did yesterday installing pip2, then the Rpi.GPIO (I got the same your result) and then the melopero fan hat … it works!!!
Many thanks.
I also realized that a standard usb webcam works (in Raspbian not).
Now I shall test the bluetooth and try to understand why the pi camera is not recognized.
Many thanks really for your support.
Have nice week and Happy Easter
