Hello,
I have moved to Gnome Unstable some time ago and everything have micro stutter (no problem with KDE or XFCE) - movies, games, browser etc. I have tried everything that I can, but nothing works. I must add that I switched to Linux relatively recently, my knowledge about Linux is quite narrow.
I have tried:
- Low Latency Tuning Guide | Erik Rigtorp
- powertop --calibrate
- mutter versions
Additionally:
I have created a virtual machine with GPU Passthrugh. When I run Windows 10 (window manager shuts down) virtualized system runs without any stutters.
How stutter looks:
What I can do to find the issue?
My setup:
- AMD Threadripper 3970x OCed
- 64GB 3733 CL14
- Quadro RTX 5000
System: Host: manjaro Kernel: 5.14.6-2-MANJARO x86_64 bits: 64 Desktop: GNOME 40.4 Distro: Manjaro Linux
Machine: Type: Desktop System: ASUS product: N/A v: N/A serial: <superuser required>
Mobo: ASUSTeK model: ROG STRIX TRX40-E GAMING v: Rev 1.xx serial: <superuser required> UEFI: American Megatrends
v: 1402 date: 01/15/2021
CPU: Info: 32-Core (4-Die) model: AMD Ryzen Threadripper 3970X bits: 64 type: MT MCP MCM cache: L2: 16 MiB
Speed: 4075 MHz min/max: 2200/3700 MHz Core speeds (MHz): 1: 4075 2: 4074 3: 4000 4: 4004 5: 4000 6: 3998 7: 3988
8: 4000 9: 4160 10: 4146 11: 4149 12: 4161 13: 4080 14: 4142 15: 4138 16: 4145 17: 4163 18: 4008 19: 3995 20: 4009
21: 3992 22: 4094 23: 4065 24: 4084 25: 4066 26: 4072 27: 4074 28: 4084 29: 4090 30: 4062 31: 4075 32: 4075
33: 4074 34: 4072 35: 4070 36: 3998 37: 4000 38: 3993 39: 4000 40: 4000 41: 4000 42: 4011 43: 4000 44: 4149
45: 4159 46: 4063 47: 4145 48: 4128 49: 4158 50: 4149 51: 4144 52: 4153 53: 3983 54: 3998 55: 4000 56: 3997
57: 4060 58: 4079 59: 4072 60: 4074 61: 4075 62: 4075 63: 3997 64: 4011
Graphics: Device-1: NVIDIA TU104GL [Quadro RTX 5000] driver: nvidia v: 470.74
Display: x11 server: X.org 1.20.13 driver: loaded: nvidia note: n/a (using device driver) - try sudo/root
unloaded: nvidia resolution: <missing: xdpyinfo>
OpenGL: renderer: Quadro RTX 5000/PCIe/SSE2 v: 4.6.0 NVIDIA 470.74
Audio: Device-1: NVIDIA TU104 HD Audio driver: snd_hda_intel
Device-2: Advanced Micro Devices [AMD] Starship/Matisse HD Audio driver: N/A
Device-3: Creative SB X-Fi Surround 5.1 Pro type: USB driver: snd-usb-audio
Device-4: Logitech G35 Headset type: USB driver: hid-generic,snd-usb-audio,usbhid
Device-5: SM900 Microphon SM900 Microphone type: USB driver: hid-generic,snd-usb-audio,usbhid
Device-6: ASUSTek USB Audio type: USB driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.14.6-2-MANJARO running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.35 running: yes
Network: Device-1: Realtek RTL8125 2.5GbE driver: r8169
IF: enp67s0 state: up speed: 1000 Mbps duplex: full mac: 34:97:f6:32:62:ca
IF-ID-1: virbr0 state: down mac: 52:54:00:0c:ab:08
IF-ID-2: wg-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
RAID: Device-1: md0 type: mdraid level: raid-0 status: active size: 893.01 GiB report: N/A
Components: Online: 0: nvme0n1p2 1: nvme1n1p1
Drives: Local Storage: total: 10 TiB used: 8.8 TiB (88.0%)
ID-1: /dev/nvme0n1 vendor: A-Data model: SX8200NP size: 447.13 GiB
ID-2: /dev/nvme1n1 vendor: A-Data model: SX8200PNP size: 476.94 GiB
ID-3: /dev/sda vendor: Seagate model: ST2000DM008-2FR102 size: 1.82 TiB
ID-4: /dev/sdb vendor: Seagate model: ST8000VX0022-2EJ112 size: 7.28 TiB
Partition: ID-1: / size: 877.92 GiB used: 568.57 GiB (64.8%) fs: ext4 dev: /dev/md0
Swap: Alert: No swap data was found.
Sensors: System Temperatures: cpu: 45.8 C mobo: N/A gpu: nvidia temp: 32 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 33%
Info: Processes: 810 Uptime: 16m Memory: 62.66 GiB used: 3.65 GiB (5.8%) Shell: fish inxi: 3.3.06
