I have a Problem that output megasync won’t open:
Setting QT_SCREEN_SCALE_FACTORS= "DP-3=1.16667;eDP-1=1.16667"
Speicherzugriffsfehler (Speicherabzug geschrieben)
Megasync got an update this morning, have you tried the update?
no still not working with that 4.3.8-1 version
Fix:
sudo nano /usr/share/applications/megasync.desktop
Delete: TryExec line
Change: Exec
Exec=env QT_SCALE_FACTOR=1 megasync
Save
I had the segmentation fault as well and I tried this I found on github and it worked for me
"you can fix this by adding the env variable in the launch file: e.g.: nano /usr/share/applications/megasync.desktop
and then replace “Exec=megasync” with “Exec=env QT_SCALE_FACTOR=1 megasync”
remove the TryExec line and save. you can then copy the megasync.desktop launch file to your autostart folder, e.g.:
cp /usr/share/applications/megasync.desktop ~/.config/autostart/
if you don’t want to vi/nano, you can use sed, e.g.: sudo sed -i -r ‘/^TryExec/d;s|^(Exec=).*$|\1env QT_SCALE_FACTOR=1 megasync|g’ /usr/share/applications/megasync.desktop
and then copy the changed file to your autostart folder.
this worked even with the latest deepin-qt5integration 5.1.0.1-2 installed."
