Since today, in the journal logs, I have errors about my disks (I have two SSD).
Four days ago, these errors were not present.
First of all: full inxi output:
inxi
Kernel: 5.10.206-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=0d37cf27-2ff0-4234-a80e-4be323299166 rw quiet
udev.log_priority=0 rd.udev.log_priority=0 loglevel=0 threadirqs
libahci.ignore_sss=1 pcie_aspm=force nowatchdog nmi_watchdog=0
mitigations=off nospec_store_bypass_disable noibrs noibpb nopti nospec
nospectre_v1 nospectre_v2 l1tf=off mds=off tsx=on tsx_async_abort=off
no_stf_barrier kvm-intel.vmentry_l1d_flush=never audit=0
rd.systemd.show_status=false net.ifnames=0 zswap.enabled=0 ipv6.disable=1
noresume mce=off i915.fastboot=1 i915.error_capture=N
i915.guc_log_level=0 i915.mitigations=off skew_tick=1 nohz=on
nosoftlockup transparent_hugepage=never drm_kms_helper.poll=N numa=off
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.36 info: xfce4-panel wm: xfwm
v: 4.18.0 vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Hewlett-Packard product: HP ProBook 6470b v: A1029D1102
Mobo: Hewlett-Packard model: 179C v: KBC Version 42.38
serial: <superuser required> BIOS: Hewlett-Packard v: 68ICE Ver. F.73
date: 08/07/2018
ID-1: BAT0 charge: 61.4 Wh (100.0%) condition: 61.4/61.4 Wh (100.0%)
volts: 12.5 min: 10.8 model: Hewlett-Packard Primary type: Li-ion
serial: <filter> status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400
Plus serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
Device-2: hidpp_battery_1 model: Logitech Wireless Mobile Mouse MX
Anywhere 2S serial: <filter> charge: 100% (should be ignored)
rechargeable: yes status: discharging
System RAM: total: 16 GiB available: 15.52 GiB used: 7.01 GiB (45.2%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: Intel Core i5-3210M bits: 64 type: MT MCP arch: Ivy Bridge
gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
model-id: 0x3A (58) stepping: 9 microcode: 0x20
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2536 high: 2613 min/max: 1200/3100 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 2519 2: 2577 3: 2438
4: 2613 bogomips: 19962
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
ida lahf_lm lm mca mce mmx monitor msr mtrr nonstop_tsc nopl nx pae pat
pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pts rdrand
rdtscp rep_good sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
xsave xsaveopt xtopology xtpr
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: spectre_v1 status: Vulnerable: __user pointer sanitization and
usercopy barriers only; no swapgs barriers
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled,
PBRSB-eIBRS: Not affected
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Hewlett-Packard
driver: i915 v: kernel arch: Gen-7 process: Intel 22nm built: 2012-13 ports:
active: LVDS-1 empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3,
VGA-1 bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Display: x11 server: X.Org v: 21.1.10 compositors: 1: xfwm v: 4.18.0
2: Picom v: git-b700a driver: X: loaded: intel dri: i965 gpu: i915
display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
s-diag: 414mm (16.31")
Monitor-1: LVDS-1 mapped: LVDS1 model: Seiko Epson 0x345a built: 2012
res: 1366x768 hz: 60 dpi: 112 gamma: 1.2 size: 310x170mm (12.2x6.69")
diag: 355mm (14") ratio: 16:9 modes: 1366x768
API: EGL v: 1.4 hw: drv: intel i965 platforms: device: 0 drv: i965
device: 1 drv: swrast gbm: drv: i965 surfaceless: drv: i965 x11: drv: i965
inactive: wayland
API: OpenGL v: 4.2 compat-v: 3.3 vendor: intel v: N/A glx-v: 1.4
direct-render: yes renderer: Mesa DRI Intel HD Graphics 4000 (IVB GT2)
device-ID: 8086:0166 memory: 1.46 GiB unified: yes
API: Vulkan v: 1.3.274 layers: N/A device: 0 type: integrated-gpu
name: Intel HD Graphics 4000 (IVB GT2) driver: mesa intel
v: 23.3.3-manjaro1.1 device-ID: 8086:0166 surfaces: xcb,xlib
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: Hewlett-Packard 7 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:1e20 class-ID: 0403
API: ALSA v: k5.10.206-1-MANJARO status: kernel-api with: aoss
Server-2: JACK v: 1.9.22 status: off tools: cadence,jack_control
Server-3: PipeWire v: 1.0.0 status: off tools: pw-cli
Server-4: PulseAudio v: 16.1 status: active with: 1: pulseaudio-alsa
type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl,pavucontrol
Device-1: Intel 82579V Gigabit Network vendor: Hewlett-Packard
driver: e1000e v: kernel port: 2060 bus-ID: 00:19.0 chip-ID: 8086:1503
class-ID: 0200
IF: eth0 state: down mac: <filter>
Device-2: Intel Wireless 7260 driver: N/A modules: iwlwifi pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b2 class-ID: 0280
Device-3: TP-Link Archer T9UH v1 [Realtek RTL8814AU] driver: rtl8814au
type: USB rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-3:2
chip-ID: 2357:0106 class-ID: 0000 serial: <filter>
Local Storage: total: 698.65 GiB used: 104.94 GiB (15.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT250MX500SSD1
size: 232.89 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 023 scheme: MBR
ID-1: / raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
used: 62.42 GiB (13.6%) fs: ext4 dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: 0d37cf27-2ff0-4234-a80e-4be323299166
ID-2: /home/<filter>/mounts/servicedisk raw-size: 232.88 GiB
size: 228.17 GiB (97.98%) used: 42.51 GiB (18.6%) fs: ext4 dev: /dev/sdb1
maj-min: 8:17 label: servicedisk
uuid: 8412b438-5d7b-48bd-bfb1-46666bb7ac64
Kernel: swappiness: 30 (default 60) cache-pressure: 200 (default 100)
zswap: no
ID-1: swap-1 type: zram size: 7.76 GiB used: 0 KiB (0.0%) priority: 100
comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 4 dev: /dev/zram0
Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
Hub-3: 1-1.2:3 info: VIA Labs VL813 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2813
Device-1: 1-1.2.1:4 info: Logitech Unifying Receiver
type: keyboard,mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 98mA
chip-ID: 046d:c52b class-ID: 0300
Hub-4: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
Hub-5: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
Device-1: 2-1.6:3 info: Broadcom HP Portable SoftSailing
type: <vendor specific> driver: N/A interfaces: 4 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0a5c:21e1
Hub-6: 3-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-7: 4-0:1 info: super-speed hub ports: 4 rev: 3.0
Device-1: 4-3:2 info: TP-Link Archer T9UH v1 [Realtek RTL8814AU]
type: Network driver: rtl8814au interfaces: 1 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 864mA
System Temperatures: cpu: 47.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 255 Uptime: 17m wakeups: 0 Init: systemd v: 255
Packages: pm: pacman pkgs: 1790 libs: 469 tools: pamac,yay Shell: Bash
v: 5.2.21 running-in: xfce4-terminal inxi: 3.3.31
journalctl | grep 'ata1\|ata2'
gen 24 11:56:55 manjaro kernel: ata1: SATA max UDMA/133 abar m2048@0xd0737000 port 0xd0737100 irq 27
gen 24 11:56:55 manjaro kernel: ata2: SATA max UDMA/133 abar m2048@0xd0737000 port 0xd0737180 irq 27
gen 24 11:56:55 manjaro kernel: ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
gen 24 11:56:55 manjaro kernel: ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
gen 24 11:56:55 manjaro kernel: ata2.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
gen 24 11:56:55 manjaro kernel: ata2.00: supports DRM functions and may not be fully accessible
gen 24 11:56:55 manjaro kernel: ata2.00: ATA-10: CT250MX500SSD1, M3CR023, max UDMA/133
gen 24 11:56:55 manjaro kernel: ata2.00: 488397168 sectors, multi 1: LBA48 NCQ (depth 32), AA
gen 24 11:56:55 manjaro kernel: ata2.00: configured for UDMA/133
gen 24 11:56:55 manjaro kernel: ata1.00: ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
gen 24 11:56:55 manjaro kernel: ata1.00: supports DRM functions and may not be fully accessible
gen 24 11:56:55 manjaro kernel: ata1.00: disabling queued TRIM support
gen 24 11:56:55 manjaro kernel: ata1.00: ATA-11: Samsung SSD 870 EVO 500GB, SVT02B6Q, max UDMA/133
gen 24 11:56:55 manjaro kernel: ata1.00: 976773168 sectors, multi 1: LBA48 NCQ (depth 32), AA
gen 24 11:56:55 manjaro kernel: ata1.00: configured for UDMA/133
gen 24 11:56:55 manjaro kernel: ata1.00: Enabling discard_zeroes_data
gen 24 10:57:49 hal9000 kernel: ata1.00: supports DRM functions and may not be fully accessible
gen 24 10:57:49 hal9000 kernel: ata1.00: disabling queued TRIM support
gen 24 10:57:49 hal9000 kernel: ata1.00: Enabling discard_zeroes_data
gen 24 10:57:49 hal9000 kernel: ata2.00: supports DRM functions and may not be fully accessible
In particular teh error ACPI cmd 00/00:00:00:00:00:a0 (NOP) rejected by device (Stat=0x51 Err=0x04)
I have run fsck on both disks, and no errors were found; the following is the output of smartclt:
smartctl for /dev/sda
sudo smartctl --all /dev/sda
[sudo] password for dave:
smartctl 7.1 2019-12-30 r5022 [x86_64-linux-5.10.206-1-MANJARO] (local build)
Copyright (C) 2002-19, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model: Samsung SSD 870 EVO 500GB
Serial Number: S6PYNX0T601255K
LU WWN Device Id: 5 002538 f426004e7
Firmware Version: SVT02B6Q
User Capacity: 500.107.862.016 bytes [500 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Form Factor: 2.5 inches
Device is: Not in smartctl database [for details use: -P showall]
ATA Version is: ACS-4 T13/BSR INCITS 529 revision 5
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Wed Jan 24 11:06:13 2024 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 0) seconds.
capabilities: (0x53) SMART execute Offline immediate.
Auto Offline data collection on/off support.
Suspend Offline collection upon new
command.
No Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x01) Error logging supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 2) minutes.
Extended self-test routine
recommended polling time: ( 85) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Error Recovery Control supported.
SCT Feature Control supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 1
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
9 Power_On_Hours 0x0032 098 098 000 Old_age Always - 7335
12 Power_Cycle_Count 0x0032 099 099 000 Old_age Always - 559
177 Wear_Leveling_Count 0x0013 099 099 000 Pre-fail Always - 3
179 Used_Rsvd_Blk_Cnt_Tot 0x0013 100 100 010 Pre-fail Always - 0
181 Program_Fail_Cnt_Total 0x0032 100 100 010 Old_age Always - 0
182 Erase_Fail_Count_Total 0x0032 100 100 010 Old_age Always - 0
183 Runtime_Bad_Block 0x0013 100 100 010 Pre-fail Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0032 063 041 000 Old_age Always - 37
195 Hardware_ECC_Recovered 0x001a 200 200 000 Old_age Always - 0
199 UDMA_CRC_Error_Count 0x003e 100 100 000 Old_age Always - 0
235 Unknown_Attribute 0x0012 099 099 000 Old_age Always - 32
241 Total_LBAs_Written 0x0032 099 099 000 Old_age Always - 7889030472
252 Unknown_Attribute 0x0032 100 100 000 Old_age Always - 3
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
SPAN MIN_LBA MAX_LBA CURRENT_TEST_STATUS
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
256 0 65535 Read_scanning was never started
Selective self-test flags (0x0):
After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.
smartctl for /dev/sdb
sudo smartctl --all /dev/sdb
Model Family: Crucial/Micron MX500 SSDs
Device Model: CT250MX500SSD1
Serial Number: 1801E109F5E0
LU WWN Device Id: 5 00a075 1e109f5e0
Firmware Version: M3CR023
User Capacity: 250.059.350.016 bytes [250 GB]
Sector Sizes: 512 bytes logical, 4096 bytes physical
Device is: In smartctl database [for details use: -P show]
ATA Version is: ACS-3 T13/2161-D revision 5
Local Time is: Wed Jan 24 11:07:05 2024 CET
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
Auto Offline Data Collection: Enabled.
been run.
capabilities: (0x7b) SMART execute Offline immediate.
command.
power-saving mode.
recommended polling time: ( 30) minutes.
Conveyance self-test routine
SCT capabilities: (0x0031) SCT Status supported.
SMART Attributes Data Structure revision number: 16
1 Raw_Read_Error_Rate 0x002f 100 100 000 Pre-fail Always - 0
5 Reallocate_NAND_Blk_Cnt 0x0032 100 100 010 Old_age Always - 0
9 Power_On_Hours 0x0032 100 100 000 Old_age Always - 22917
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 19095
171 Program_Fail_Count 0x0032 100 100 000 Old_age Always - 0
172 Erase_Fail_Count 0x0032 100 100 000 Old_age Always - 0
173 Ave_Block-Erase_Count 0x0032 100 100 000 Old_age Always - 9
174 Unexpect_Power_Loss_Ct 0x0032 100 100 000 Old_age Always - 90
180 Unused_Reserve_NAND_Blk 0x0033 000 000 000 Pre-fail Always - 27
183 SATA_Interfac_Downshift 0x0032 100 100 000 Old_age Always - 2
184 Error_Correction_Count 0x0032 100 100 000 Old_age Always - 0
194 Temperature_Celsius 0x0022 065 047 000 Old_age Always - 35 (Min/Max 0/53)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 100 100 000 Old_age Always - 0
202 Percent_Lifetime_Remain 0x0030 100 100 001 Old_age Offline - 0
206 Write_Error_Rate 0x000e 100 100 000 Old_age Always - 0
210 Success_RAIN_Recov_Cnt 0x0032 100 100 000 Old_age Always - 0
246 Total_LBAs_Written 0x0032 100 100 000 Old_age Always - 1169856132
247 Host_Program_Page_Count 0x0032 100 100 000 Old_age Always - 19845005
248 FTL_Program_Page_Count 0x0032 100 100 000 Old_age Always - 12991418
Warning: ATA error count 0 inconsistent with error log pointer 1
ATA Error Count: 0
CR = Command Register [HEX]
FR = Features Register [HEX]
SC = Sector Count Register [HEX]
SN = Sector Number Register [HEX]
CL = Cylinder Low Register [HEX]
CH = Cylinder High Register [HEX]
DH = Device/Head Register [HEX]
DC = Device Command Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Powered_Up_Time is measured from power on, and printed as
DDd+hh:mm:SS.sss where DD=days, hh=hours, mm=minutes,
SS=sec, and sss=millisec. It "wraps" after 49.710 days.
Error 0 occurred at disk power-on lifetime: 0 hours (0 days + 0 hours)
When the command that caused the error occurred, the device was in an unknown state.
After command completion occurred, registers were:
ER ST SC SN CL CH DH
00 ec 00 00 00 00 00
Commands leading to the command that caused the error were:
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
ec 00 00 00 00 00 00 00 00:00:00.000 IDENTIFY DEVICE
c8 00 00 00 00 00 00 00 00:00:00.000 READ DMA
Num Test_Description Status Remaining LifeTime(hours) LBA_of_first_error
# 1 Short offline Completed without error 00% 3605 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
As you can see from smartctl there are no serious errors, and I repeat: four days ago I didn’t seen the message error in journalctl.
