Hey Guys,
I got a problem with my audio being slowed down to like 0.25x as soon as I connect to a ts3 server. To demonstrate that I wanted to record it via OBS just to find out that it wouldn’t even open. I can’t tell if both problems are connected but I’ll try my best to provide all needed information:
Problem(s):
- TS3 works perfectly normal (even the sound test) until I connect to a server. After connecting all sounds are slowed down to ~0.25x
(- OBS won’t even start to record the Problem)
Troubleshooting done:
- Deleting TS3 config
- Reinstalling TS3
- Trying to get relevant information from the logs
Logs + System-info:
TS3
teamspeak3 ✔
QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
Crashdump ENABLED, directory is: /home/best/.ts3client/crashdumps
DUMP defined! Dumpdir is: /home/best/.ts3client/crashdumps
2023-10-01 17:53:57.260404|INFO | | |TeamSpeak Client 3.6.1 (2023-07-24 10:06:33)
2023-10-01 17:53:57.260432|INFO | | |SystemInformation: Linux 6.1.53-1-MANJARO #1 SMP PREEMPT_DYNAMIC Wed Sep 13 14:10:57 UTC 2023 x86_64 Binary: 64bit
2023-10-01 17:53:57.263171|DEBUG |PulseAudio | |connected to pulse audio server -
2023-10-01 17:53:57.272619|DEBUG |SoundDevManager| |Loading dynamic soundbackend from /opt/teamspeak3/soundbackends/libalsa_linux_amd64.so
2023-10-01 17:53:57.273618|DEBUG |SoundDevManager| |Soundbackend loaded.
2023-10-01 17:53:57.281431|INFO |ClientUI | |OpenGL Info: LibGL, Vendor: NVIDIA Corporation, Renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2, Version: 4.6.0 NVIDIA 535.104.05
2023-10-01 17:53:57.297471|INFO |Addons | |Checking for addon updates...
2023-10-01 17:53:57.309572|INFO |Plugins | |Loading plugin: libclientquery_plugin_linux_amd64.so
2023-10-01 17:53:57.310679|INFO |Query | |listening on 127.0.0.1:25639
QFont::fromString: Invalid description '(empty)'
libpng warning: iCCP: known incorrect sRGB profile
ClientQueryPlugin: currentServerConnectionChanged 1 (0)
QWidget::insertAction: Attempt to insert null action
2023-10-01 17:53:57.439153|INFO |ClientUI | |Failed to init text to speech engine
2023-10-01 17:53:57.439197|INFO |ClientUI | |Qt version: 5.15.8
2023-10-01 17:53:57.439209|INFO |ClientUI | |Using configuration location: /home/best/.ts3client/settings.db
2023-10-01 17:53:57.447171|INFO |Addon | |Addon up to date.
2023-10-01 17:53:57.603621|INFO |Addon | |Addon up to date.
2023-10-01 17:53:57.939062|INFO |Bookmarks | |Collecting autoconnect bookmarks
2023-10-01 17:53:57.939333|INFO |ClientUI | |Last update check was: So. Okt. 1 19:34:29 2023
2023-10-01 17:53:57.939533|INFO | | |Statistics report: User previously denied participation
2023-10-01 17:53:58.438933|INFO |Newsticker | |Newsticker next check: Mo. Okt. 2 17:34:29 2023 GMT
2023-10-01 17:54:01.261831|INFO |ClientUI |1 |Connect to server: www.demolished-esports.de
2023-10-01 17:54:01.265885|INFO |ClientUI |1 |Trying to resolve www.demolished-esports.de
2023-10-01 17:54:01.267410|INFO |TSDNS | |A/AAAA DNS resolve successful, "www.demolished-esports.de" =(h: 49.12.81.6 p:0)
2023-10-01 17:54:01.267488|INFO |TSDNS | |A/AAAA DNS resolve for possible TSDNS successful, "www.demolished-esports.de" =(h: 49.12.81.6 p:0)
2023-10-01 17:54:01.302679|INFO |TSDNS | |SRV DNS resolve unsuccessful, "_tsdns._tcp.demolished-esports.de" Domain name not found
2023-10-01 17:54:01.311805|INFO |TSDNS | |SRV DNS resolve unsuccessful, "_ts3._udp.www.demolished-esports.de" Domain name not found
2023-10-01 17:54:01.313745|INFO |TSDNS | |A/AAAA DNS resolve unsuccessful, "demolished-esports.de" DNS server returned answer with no data
2023-10-01 17:54:03.267798|INFO |TSDNS | |TSDNS queried unsuccessfully 49.12.81.6:41144
2023-10-01 17:54:03.268020|INFO |TSDNS | |No TSDNS found
2023-10-01 17:54:03.268092|INFO |ClientUI |1 |Lookup finished: ip=49.12.81.6 port=9987 query=www.demolished-esports.de error=0
2023-10-01 17:54:03.268158|INFO |ClientUI |1 |Resolve successful: 49.12.81.6:9987
2023-10-01 17:54:03.268179|INFO |ClientUI |1 |Initiating connection: 49.12.81.6:9987
2023-10-01 17:54:03.619848|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:03.619945|DEBUG |PulseAudio | |Opening echo stream alsa_output.pci-0000_05_00.0.analog-stereo -
2023-10-01 17:54:03.659256|INFO |ClientUI |1 |Connect status: Connecting
2023-10-01 17:54:03.677347|INFO |PktHandler |1 |server sent ciphers:1
2023-10-01 17:54:03.701914|INFO |PktHandler |1 |Selected cipher:0
2023-10-01 17:54:03.702017|DEVELOP |PktHandler |1 |Puzzle solve time: 6
2023-10-01 17:54:03.747856|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:03.760428|INFO |ClientUI |1 |Connect status: Connected
2023-10-01 17:54:03.795187|INFO |ClientUI |1 |Connect status: Establishing connection
libpng warning: iCCP: cHRM chunk does not match sRGB
2023-10-01 17:54:03.830993|INFO |ClientUI |1 |Connect status: Connection established
2023-10-01 17:54:03.939871|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:04.131830|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:04.323835|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:04.515847|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:04.707837|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:04.899834|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:05.091838|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:05.283838|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:05.475847|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:05.667856|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:05.859843|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:06.051849|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:06.243871|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:06.435899|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:06.627875|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:06.819852|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:07.011900|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:07.203848|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:07.395842|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:07.587866|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:07.779863|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:07.971853|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:08.163877|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:08.355854|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:08.547867|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:08.739867|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:08.931879|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:09.123872|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:09.315885|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:09.507877|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:09.699886|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
2023-10-01 17:54:09.891874|DEBUG |PulseAudio | |Underflow occurred on device ts.pa.dummy.playbackdefault -
OBS
obs ✔
debug: Found portal inhibitor
debug: Attempted path: share/obs/obs-studio/locale/en-US.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale/en-US.ini
debug: Attempted path: share/obs/obs-studio/locale.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale.ini
debug: Attempted path: share/obs/obs-studio/locale/de-DE.ini
debug: Attempted path: /usr/share/obs/obs-studio/locale/de-DE.ini
info: Using preferred locale 'de-DE'
debug: Attempted path: share/obs/obs-studio/themes/Yami.qss
debug: Attempted path: /usr/share/obs/obs-studio/themes/Yami.qss
info: Using EGL/X11
info: CPU Name: AMD Ryzen 9 3900X 12-Core Processor
info: CPU Speed: 4102.938MHz
info: Physical Cores: 12, Logical Cores: 24
info: Physical Memory: 32002MB Total, 12372MB Free
info: Kernel Version: Linux 6.1.53-1-MANJARO
info: Distribution: "Manjaro Linux" Unknown
info: Desktop Environment: KDE (KDE)
info: Session Type: x11
info: Window System: X11.0, Vendor: The X.Org Foundation, Version: 1.21.1
info: Qt Version: 6.5.2 (runtime), 6.5.1 (compiled)
info: Portable mode: false
info: OBS 29.1.3-1 (linux)
info: ---------------------------------
info: audio settings reset:
samples per sec: 48000
speakers: 2
max buffering: 960 milliseconds
buffering type: dynamically increasing
info: Initializing OpenGL...
info: Loading up OpenGL on adapter NVIDIA Corporation NVIDIA GeForce GTX 1070/PCIe/SSE2
info: OpenGL loaded successfully, version 3.3.0 NVIDIA 535.104.05, shading language 3.30 NVIDIA via Cg compiler
info: video settings reset:
base resolution: 1920x1080
output resolution: 1280x720
downscale filter: Bicubic
fps: 30/1
format: NV12
YUV mode: Rec. 709/Partial
info: NV12 texture support not available
info: P010 texture support not available
info: Audio monitoring device:
warning: Failed to load 'en-US' text for module: 'decklink-captions.so'
warning: Failed to load 'en-US' text for module: 'decklink-output-ui.so'
libDeckLinkAPI.so: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden
warning: A DeckLink iterator could not be created. The DeckLink drivers may not be installed
warning: Failed to initialize module 'decklink.so'
info: [pipewire] Available captures:
info: [pipewire] - Desktop capture
info: [pipewire] - Window capture
info: NVENC supported
zsh: segmentation fault (core dumped) obs
inxi
inxi --admin --verbosity=7 --filter --no-host --width ✔ 20s
Kernel: 6.1.53-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=c90f424d-dfd4-40ed-b50b-954c4a6162c8 rw quiet splash
resume=UUID=a32bb835-d984-4619-8921-50ba39bfc618 udev.log_priority=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 2 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-E GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4403
date: 04/27/2022
System RAM: total: 32 GiB available: 31.25 GiB used: 5.17 GiB (16.5%)
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 2789 high: 4375 min/max: 2200/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 2200
3: 2141 4: 3835 5: 3800 6: 2082 7: 2193 8: 2200 9: 2200 10: 3598 11: 3337
12: 2065 13: 3633 14: 2200 15: 2200 16: 4118 17: 4235 18: 2089 19: 2200
20: 4375 21: 2200 22: 2200 23: 3580 24: 2058 bogomips: 182460
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spec_rstack_overflow mitigation: safe RET
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: ASUSTeK driver: nvidia
v: 535.104.05 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Pascal code: GP10x process: TSMC 16nm
built: 2016-21 pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0c:00.0
chip-ID: 10de:1b81 class-ID: 0300
Device-2: HTC (High Tech ) Vive driver: snd-usb-audio,uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3.3.1.1.2:12
chip-ID: 0bb4:2c87 class-ID: 0102
Device-3: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3.3.4:9
chip-ID: 046d:08e5 class-ID: 0102
Display: x11 server: X.Org v: 21.1.8 with: Xwayland v: 23.2.0
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia display-ID: :0
screens: 1
Screen-1: 0 s-res: 7680x1440 s-dpi: 108 s-size: 1806x342mm (71.10x13.46")
s-diag: 1838mm (72.37")
Monitor-1: DP-0 pos: right res: 2560x1440 hz: 60 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
Monitor-2: DP-2 pos: primary,center res: 2560x1440 hz: 144 dpi: 109
Monitor-3: HDMI-0 pos: left res: 2560x1440 hz: 60 dpi: 109
API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 535.104.05 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.264 layers: 8 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1070 driver: nvidia v: 535.104.05
device-ID: 10de:1b81 surfaces: xcb,xlib
Device-1: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 1102:0012 class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: ASUSTeK
bus-ID: 0c:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: HTC (High Tech ) Vive driver: snd-usb-audio,uvcvideo type: USB
Device-5: HTC (High Tech ) Vive driver: hid-generic,usbhid type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3.3.1.1.5:13
chip-ID: 0bb4:2c87 class-ID: 0300 serial: <filter>
Device-6: Focusrite-Novation Scarlett Solo (3rd Gen.)
driver: snd-usb-audio,usb-storage type: USB rev: 2.1 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 1-3.3.3:7 chip-ID: 1235:8211 class-ID: 0806
serial: <filter>
Device-7: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.1.53-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 0.3.80 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-4: PulseAudio v: 16.1 status: active with: pulseaudio-alsa
Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp6s0 state: down mac: <filter>
Device-2: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 07:00.0
IF: enp7s0 state: down mac: <filter>
Device-3: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 08:00.0
IF: enp8s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: virbr0 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-6:4 chip-ID: 8087:0029
class-ID: e001
Report-ID: ID: hci1 rfk-id: 2 state: up address: N/A
Local Storage: total: 18.16 TiB used: 4.78 TiB (26.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B2QJXD7 temp: 39.9 C
scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Crucial model: CT2000P5PSSD8
lanes: 4 tech: SSD serial: <filter> fw-rev: P7CR403 temp: 41.9 C
scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 1TB
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST8000NM000A-2KE101
size: 7.28 TiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: HDD rpm: 7200 serial: <filter> fw-rev: SB2D scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Crucial model: CT2000MX500SSD1
tech: SSD serial: <filter> fw-rev: 032 scheme: GPT
ID-6: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD20EZRZ-00Z5HB0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: HDD rpm: 5400 serial: <filter>
fw-rev: 0A80 scheme: GPT
ID-7: /dev/sde maj-min: 8:64 vendor: Crucial model: CT2000MX500SSD1
tech: SSD serial: <filter> fw-rev: 033 scheme: GPT
ID-8: /dev/sdf maj-min: 8:80 vendor: Crucial model: CT960BX500SSD1
size: 894.25 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: R022 scheme: GPT
ID-9: /dev/sdk maj-min: 8:160 model: Scarlett Welcome Disk size: 192 KiB
block-size: physical: 512 B logical: 512 B type: USB rev: 2.1 spd: 480 Mb/s
lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 0.10 scheme: MBR
Optical-1: /dev/sr0 vendor: HL-DT-ST model: BD-RE BH16NS40 rev: 1.05
dev-links: cdrom
ID-1: / raw-size: 1.79 TiB size: 1.76 TiB (98.37%) used: 295.59 GiB (16.4%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: c90f424d-dfd4-40ed-b50b-954c4a6162c8
used: 292 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: 370D-E51A
ID-3: /run/media/best/8TB_Exos raw-size: 7.28 TiB size: 7.22 TiB (99.20%)
used: 2.97 TiB (41.2%) fs: ext4 dev: /dev/sdb1 maj-min: 8:17 label: 8TB_Exos
uuid: 9875de5e-d652-4b7c-95a5-726bc36cba1a
ID-4: /run/media/best/Spiele1 raw-size: 1.82 TiB size: 1.79 TiB (98.37%)
used: 1.51 TiB (84.6%) fs: ext4 dev: /dev/sdc1 maj-min: 8:33 label: Spiele1
uuid: 55aa4af8-a275-4b23-a8c0-191ddddb4814
ID-1: swap-1 type: partition size: 34.38 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: a32bb835-d984-4619-8921-50ba39bfc618
ID-1: /dev/nvme1n1p1 maj-min: 259:5 size: 100 MiB fs: vfat label: N/A
uuid: A29D-277E
ID-2: /dev/nvme1n1p2 maj-min: 259:6 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme1n1p3 maj-min: 259:7 size: 1.82 TiB fs: ntfs label: N/A
uuid: 381E9FF01E9FA602
ID-4: /dev/nvme1n1p4 maj-min: 259:8 size: 688 MiB fs: ntfs label: N/A
uuid: 787C85487C8501DC
ID-5: /dev/sdd1 maj-min: 8:49 size: 1.82 TiB fs: ext4 label: 2TB_WD
uuid: 0af9dc33-b67a-4b62-962a-bf64d2ab3a14
ID-6: /dev/sde1 maj-min: 8:65 size: 1.82 TiB fs: ext4 label: Spiele2
uuid: ef8b9370-4b64-4ca6-8746-52b073f23ad8
ID-7: /dev/sdf1 maj-min: 8:81 size: 894.25 GiB fs: ntfs
label: Spiele_Windows uuid: 4A07C4BF4F5EFAD4
ID-8: /dev/sdk1 maj-min: 8:161 size: 160 KiB fs: vfat label: SCARLETT
uuid: 8886-5B6C
Hub-2: 1-3:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2817
Hub-3: 1-3.3:5 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
Hub-4: 1-3.3.1:6 info: HTC (High Tech ) CB USB2 ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bb4:2210
Hub-5: 1-3.3.1.1:8 info: HTC (High Tech ) Vive Hub (SMSC USB2137B) ports: 7
rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0bb4:2134
Device-1: 1-3.3.1.1.1:11 info: Valve Lighthouse FPGA RX type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 100mA chip-ID: 28de:2000 class-ID: 0300
serial: <filter>
Device-2: 1-3.3.1.1.2:12 info: HTC (High Tech ) Vive type: video,audio
driver: snd-usb-audio,uvcvideo interfaces: 6 rev: 2.0
Device-3: 1-3.3.1.1.5:13 info: HTC (High Tech ) Vive type: HID
lanes: 1 mode: 1.1 power: 500mA chip-ID: 0bb4:2c87 class-ID: 0300
serial: <filter>
Device-4: 1-3.3.1.1.6:14 info: Valve Watchman Dongle type: HID
lanes: 1 mode: 1.1 power: 20mA chip-ID: 28de:2101 class-ID: 0300
serial: <filter>
Device-5: 1-3.3.1.1.7:15 info: Valve Watchman Dongle type: HID
serial: <filter>
Device-6: 1-3.3.1.2:10 info: HTC (High Tech ) Vive Hub Bluetooth 4.1
(Broadcom BCM920703) type: Hub driver: btusb interfaces: 4 rev: 2.0
speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 chip-ID: 0bb4:0306
Device-7: 1-3.3.3:7 info: Focusrite-Novation Scarlett Solo (3rd Gen.)
type: audio,mass storage driver: snd-usb-audio,usb-storage interfaces: 5
rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 500mA
chip-ID: 1235:8211 class-ID: 0806 serial: <filter>
Device-8: 1-3.3.4:9 info: Logitech C920 PRO HD Webcam type: video,audio
driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.1
Hub-6: 1-5:3 info: Genesys Logic Hub ports: 4 rev: 2.0
Device-1: 1-6:4 info: Intel AX200 Bluetooth type: bluetooth driver: btusb
power: 100mA chip-ID: 8087:0029 class-ID: e001
Hub-7: 2-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-8: 2-3:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0817
Hub-9: 2-3.3:3 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.1
Hub-10: 2-3.3.1:4 info: HTC (High Tech ) CB USB3 ports: 1 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0bb4:0210
Hub-11: 3-0:1 info: hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 3-4:2 info: ASUSTek AURA LED Controller type: HID
lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:18f3 class-ID: 0300
serial: <filter>
Device-2: 3-5:3 info: Genesys Logic Multislot Card Reader/Writer
type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
chip-ID: 05e3:0716 class-ID: 0806 serial: <filter>
Hub-12: 3-6:4 info: Genesys Logic Hub ports: 4 rev: 2.0
Hub-13: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-14: 5-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
Hub-15: 5-2:2 info: VIA Labs USB2.0 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2815
Device-1: 5-2.2:3 info: Logitech G502 SE HERO Gaming Mouse type: mouse,HID
lanes: 1 mode: 1.1 power: 300mA chip-ID: 046d:c08b class-ID: 0300
serial: <filter>
Device-2: 5-2.4:4 info: Corsair K95 RGB Platinum Keyboard [RGP0056]
type: keyboard,HID driver: usbfs interfaces: 2 rev: 2.0
chip-ID: 1b1c:1b2d class-ID: 0300 serial: <filter>
Hub-16: 6-0:1 info: super-speed hub ports: 4 rev: 3.1
Hub-17: 6-2:2 info: VIA Labs USB3.0 Hub ports: 4 rev: 3.2
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0815
System Temperatures: cpu: 27.0 C mobo: 33.0 C gpu: nvidia temp: 52 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 0%
Processes: 430 Uptime: 43m wakeups: 0 Init: systemd v: 254 default: graphical
tool: systemctl Compilers: gcc: 13.2.1 alt: 12 clang: 16.0.6 Packages:
pm: pacman pkgs: 1608 libs: 460 tools: octopi,pamac,yay pm: flatpak pkgs: 0
Shell: Zsh v: 5.9 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.30
