Hallo Zusammen,
mit meinem aktuellen Gerät bin ich auf jeden Fall bereits arbeitsfähig.
Ich werde für meine Nebenstellen (so weit ich diese nicht hin bekomme) jeweils ein eigenes Thema eröffnen.
Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=42e9325b-30e0-4e85-935b-567bdc91070f rw quiet splash apparmor=1
security=apparmor resume=UUID=548284c1-8490-4d9d-abfa-e43e96a70ddd
udev.log_priority=3
Desktop: GNOME v: 48.5 tk: GTK v: 3.24.50 wm: gnome-shell
base: Arch Linux
Type: Convertible System: LENOVO product: 20LES4P71F v: ThinkPad X1 Yoga 3rd
serial: <superuser required> Chassis: type: 31 serial: <superuser required>
Mobo: LENOVO model: 20LES4P71F v: SDK0J40697 WIN
serial: <superuser required> part-nu: LENOVO_MT_20LE_BU_Think_FM_ThinkPad
X1 Yoga 3rd uuid: <superuser required> UEFI: LENOVO v: N25ET68W (1.54 )
date: 08/22/2024
ID-1: BAT0 charge: 31.2 Wh (79.5%) condition: 39.3/54.1 Wh (72.7%)
volts: 16.43 min: 15.36 model: Celxpert 01AV475 type: Li-poly
serial: <filter> charging: status: not charging control: start: 75%
end: 80% cycles: 736
System RAM: total: 8 GiB available: 7.51 GiB used: 2.93 GiB (39.0%)
Array-1: capacity: 8 GiB slots: 2 modules: 2 EC: None
max-module-size: 4 GiB note: est.
Device-1: ChannelA-DIMM0 type: LPDDR3 detail: synchronous unbuffered
(unregistered) size: 4 GiB speed: 2133 MT/s volts: curr: 1 width (bits):
data: 64 total: 64 manufacturer: SK Hynix part-no: H9CCNNNBJTALAR-NVD
serial: N/A
Device-2: ChannelB-DIMM0 type: LPDDR3 detail: synchronous unbuffered
serial: N/A
Info: model: Intel Core i5-8350U bits: 64 type: MT MCP arch: Coffee Lake
gen: core 8 level: v3 note: check built: 2017 process: Intel 14nm family: 6
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF6
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 400 min/max: 400/3600 scaling: driver: intel_pstate
governor: powersave cores: 1: 400 2: 400 3: 400 4: 400 5: 400 6: 400 7: 400
8: 400 bogomips: 30409
sgx smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm
tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic
vulnerable
Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5917
class-ID: 0300
Device-2: Chicony Integrated IR Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 04f2:b605
Device-3: Chicony Integrated Camera (1280x720@30) driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:4
chip-ID: 04f2:b604 class-ID: 0e02 serial: <filter>
compositor: gnome-shell driver: gpu: i915 display-ID: 0
Monitor-1: eDP-1 model: ChiMei InnoLux 0x14e1 built: 2017 res: 1920x1080
dpi: 158 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600
blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9
modes: 1920x1080
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics 620 (KBL
GT2) device-ID: 8086:5917 memory: 7.33 GiB unified: yes display-ID: :0.0
Info: Tools: api: eglinfo,glxinfo x11: xprop
Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo
driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
chip-ID: 8086:9d71 class-ID: 0403
API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.8 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-LM vendor: Lenovo driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
IF: enp0s31f6 state: down mac: <filter>
Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd
class-ID: 0280
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:3 chip-ID: 8087:0a2b
class-ID: e001
Local Storage: total: 238.47 GiB used: 43.52 GiB (18.2%)
model: MZVLB256HBHQ-000L7 size: 238.47 GiB block-size: physical: 512 B
fw-rev: 5M2QEXH7 temp: 34.9 C scheme: GPT
ID-1: / raw-size: 229.38 GiB size: 224.72 GiB (97.97%)
used: 43.52 GiB (19.4%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
label: N/A uuid: 42e9325b-30e0-4e85-935b-567bdc91070f
used: 320 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
uuid: D607-BC92
dev: /dev/nvme0n1p3 maj-min: 259:3 label: swap
uuid: 548284c1-8490-4d9d-abfa-e43e96a70ddd
Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
Device-1: 1-5:2 info: Chicony Integrated IR Camera type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b605 class-ID: 0e02
serial: <filter>
Device-2: 1-7:3 info: Intel Bluetooth wireless interface type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:0a2b class-ID: e001
Device-3: 1-8:4 info: Chicony Integrated Camera (1280x720@30) type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 04f2:b604 class-ID: 0e02
serial: <filter>
Device-4: 1-9:5 info: Synaptics Metallica MIS Touch Fingerprint Reader
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0
chip-ID: 06cb:009a class-ID: ff00 serial: <filter>
Device-5: 1-10:6 info: Wacom Pen and multitouch sensor type: HID
driver: usbhid,wacom interfaces: 2 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
lanes: 1 mode: 1.1 power: 400mA chip-ID: 056a:5148 class-ID: 0300
Hub-2: 2-0:1 info: super-speed hub ports: 6 rev: 3.0
Device-1: 2-3:2 info: Realtek USB3.0-CRW type: mass storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 800mA chip-ID: 0bda:0328 class-ID: 0806
serial: <filter>
System Temperatures: cpu: 48.0 C pch: 46.5 C mobo: N/A
Fan Speeds (rpm): fan-1: 0
Packages: 1498 pm: pacman pkgs: 1491 libs: 373 tools: gnome-software,pamac
pm: flatpak pkgs: 7
1: https://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
2: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
3: https://mirror.koddos.net/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 300
1: cpu: 100% command: ps pid: 4950 mem: 4.24 MiB (0.0%)
2: cpu: 14.5% command: kgx pid: 4834 mem: 195.5 MiB (2.5%)
3: cpu: 9.0% command: zsh pid: 4842 mem: 10.5 MiB (0.1%)
4: cpu: 3.6% command: vivaldi-bin pid: 3252 mem: 272.9 MiB (3.5%)
5: cpu: 3.4% command: gnome-shell pid: 961 mem: 313.8 MiB (4.0%)
Memory top: 5 of 300
1: mem: 341.4 MiB (4.4%) command: exe pid: 2356 cpu: 1.7%
2: mem: 337.2 MiB (4.3%) command: vivaldi-bin pid: 3138 cpu: 1.8%
3: mem: 313.8 MiB (4.0%) command: gnome-shell pid: 961 cpu: 3.4%
4: mem: 283.0 MiB (3.6%) command: ferdium pid: 2075 cpu: 0.7%
5: mem: 272.9 MiB (3.5%) command: vivaldi-bin pid: 3252 cpu: 3.6%
Processes: 300 Power: uptime: 20m states: freeze,mem,disk suspend: s2idle
avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
suspend, test_resume image: 2.99 GiB services: gsd-power,
tool: systemctl
Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: kgx
inxi: 3.3.39
Mein aktuelles Problem: Ich kann den Mauszeiger nicht verschwinden lassen (wie bei KDE mit Wayland).
Die Anwendung unclutter funktioniert bei wayland nicht; wollte aber bei wayland bleiben.
Bei den Erweiterungen finde ich auch das hide-Cursor nicht; bei pamac GUI habe ich auch nichts dazu gefunden.
Da stehe ich auf dem Schlauch.
Mein Ziel: Der Mauszeiger soll nach 5 Sekunden oder so ausgeblendet werden, im Tablet-Modus und im Tastatur-Modus.
